Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
Will not drain properly-clothes are soaking wet
I too get a code f-51.never cyles through the entire spin and drain cyle.
  • 18 Answers
If your serial number is prior to CU13-----, you will need part # W10130544.
Posted on May 10, 2008
I had same problem and Whirlpool factory service had to replace motor position sensor board. He is info from another posting:
Best Solution posted on Oct 20, 2007 will not drain properly-clothes are soaking wet - 2%20stars.png
446will not drain properly-clothes are soaking wet - wizard_s.gifass= By wizard_s.gif eagle338
Rank: Wiz
Rating: 75%, 482 votes
there is a motor rotor position sensor(RPS) failure.
Refer page 10 of the manual below
http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208567036.pdf
Posted on Dec 17, 2007
  • 89 Answers
Perhaps Lid switch is broken...
Posted on Dec 15, 2007
I washed a batch of wool/hand wash cyle. The washer did not automatically complete, the door would not open.
Remove the wall plug and leave 15 minutes for it to reset. Then choose low speed spin cycle. Dry woollies flat.
Jan 25, 2017 | Washing Machines
Spin cyle does not come ,but water drain
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Jun 24, 2010 | Maytag PYE2300AY Electric Dryer
Washer not draining
Probably the pump filter needs cleaning.
It should be located at the bottom front of washer behind drop down cover, turn anti-clockwise to remove and clean.
May 04, 2010 | Bosch Nexxt 100 Series WFMC1001UC Front...
Spin Cyle won't work and it will not drain. Any
hi,
Turn the machine on its side and check the riv belt for the spin cycle or the coupler.It might have been broken.
Mar 29, 2010 | KitchenAid KAWS850L Top Load Washer
Towels come out soaking wet, too wet to put in dryer. When placed back in dryer, noticed the spin cyle runs slowly, never spinning fast. The drum itself isn't solid, but oscillates when spinning.
The clothes are wet after spinning When the clothes are wet at the end of a cycle, check these: Motor coupler Spin cycle Siphoning Water-inlet valve Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning: If it's spinning when you lift the lid, the coupler is fine. If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely. Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component. Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician. Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess. Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Jan 01, 2010 | GE WSXH208A Front Load Washer
When cyle is finish clothes are still soaking wet
Sounds like a slow drain. Recheck the drain hose if it looks ok get a bucket to put the hose in to see how fast it comes out. If it comes out slow the drain pump impellor may be broken.
Apr 17, 2008 | Frigidaire GLWS1233A Top Load Washer
Wont spin out
are the clothes out of balance? sometimes it can take quite a few trys to rebalance the load. if that is the case, it probably could use new drum springs.
Mar 05, 2008 | GE WSRE5260D Top Load Washer
Maytag front load washing machine Model MAH5500B misses spin cycle
either balance load sensor or machine failing to drain in the allocated time, check pump/filter for blockage
Nov 01, 2007 | Maytag Neptune MAH5500B Front Load Washer
Washer not spinning right and not completing a cycle
Sounds like you need to replace the carbon brushes on your washing machine motor
Sep 26, 2006 | Hoover H130E Front Load Washer
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
235 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
