I want to uninstall Cool Max Xtreme Files 3.5'' HDD External Enclosure.
    President:
  • 1,884 Answers
Hughes, I f using Windows Start->Control Panel->Add/Remove Progs. When the new windos gets populated then locate the device that you want to remove. Select it and remove it.
Posted on Sep 12, 2009
  • 37 Answers
If it is USB use Control Panel>Add/Remove Hardware. Select drive. Remove cable.
Can't get Windows to see the GT Max 3.5in on the new computer
Not sure what your trying to do here sorry iam a bit thick but are you trying to use the hard drive out of the external box into another computer and boot it up or trying to use it in its casing and plug it in via USB to another working computer .
Dec 30, 2011 | GTMax Black 35 INCH IDE HDD External Hard...
I have got an 2.5 hdd external case that xp say's
hurm..i not sure..but you try change the case or converter first..
Aug 03, 2011 | Eforcity USB 20 25 HARD DRIVE SATA HDD...
Having problems with my Dell laptops' hard drive so I ran diognostics and came back with the 2000 0146 error code and after a bit of research found out a good way to try and save my files is with a "USB...
Hi Lofimodernis
Regarding your inquiry unsing a USB 2.0 external or HDD enclosure is basically used to connect a laptop HDD to another computer to be used to extract or back up files on to new HDD or another device. regarding with the error 2000 0146 as far as i can remember as a technician when it comes to dell laptops it would really be a HDD replacement
Hope I have answer your inquiry about the USB 2.0 external enclosure
Thank you for choosing fixya support
Sep 15, 2010 | Dell Vostro 1710 Notebook
3.5 HDD external enclosure
One or more of the hints below will probably sort out most USB problems with most USB portable / external hard drives and OTHER devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
6. For FLASH DRIVES you should ensure that the device is set for "quick removal" using the drive control panel properties or use the USB "Safely Remove Hardware" option. If you don’t do this there is a very strong chance that any files you transfer may not be there when you plug into another computer.
7. It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
You should also do this to check the drives connections are not bad inside the enclosure.
8. If none of the above steps help look at updating the drivers from the manufacturers web site in the support section.
9. If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
10. Ensure that you have set removable drives for "quick removal" or that you use the "Safely Remove Hardware" option often shown on the lower toolbar. It is possible that files my not be fully written to external devices before they are removed. This corrupts the file itself and even on occasion the drive.
SPECIAL NOTES
USB flash drives can fail for no apparent reason.
Sandisk Cruzers are especially bad for this.
USB hard drives should be treated with extreme care.
This is a real hard drive ! And knocks and bumps can quite literally kill them.
Note that if you hear a drive clicking or pinging this could be the worst thing you would hear.
Known as "The Click of Death"
Hope this gives you the information you need
Bob
Moderator
It would be very decent of you to consider the quality of our expert’s answers and judge them accordingly as you pass through FixYa.
Thank you
Mar 23, 2010 | Western Digital imicro IM35ST320SI 3.5 IDE...
External IDE enclosure problem
here's what a sata hdd connection looks like
here's what a IDE hdd connection looks like
here's a page that shows them side by side
Hopefully that should help with what you have there.
Jan 21, 2010 | Toshiba Satellite 2455-S305 Notebook
Code 10. The device cannot start
Go to, Start > Settings > Control Panel > Administrative Tools > Computer Management > Disk Management. See if the drive starts under Disk Management.
I sounds like the drive enclosure is shot. You may need just a case. Click this link: http://cgi.ebay.com/USB-2-0-2-5-EXTERNAL-HARD-DRIVE-ENCLOSURE-CASE-NEW_W0QQitemZ120099119775QQcmdZViewItem?hash=item120099119775
Or you can get the whole unit and swap out the drives so you won't lose your data.
http://cgi.ebay.com/NEW-MAXTOR-ONETOUCH-4-MINI-120GB-HARD-DRIVE-USB_W0QQitemZ160267138312QQcmdZViewItem?hash=item160267138312&_trkparms=72%3A552%7C39%3A1%7C66%3A2%7C65%3A12&_trksid=p3286.c0.m14.l1318
Aug 02, 2008 | Maxtor OneTouch III Mini Edition 120GB...
Simple Drive
ive had to open the enclosure and recover the files with success many times due to bad usb to ide card in enclosure.
i got him a new 2.5' hdd enclosure and new laptop hdd with 5 yr warr seagate.
Aug 01, 2008 | Computers & Internet
Nexstar.3 Sata external drive woun't start
I also have the same problem. I bought a 500gb WD HDD and it worked great via USB for about 4 days, not the computer does not have it. i am running windows xp home. i can also hear the drive working and the blue light comes on, but it is delayed. When it was working correctly it came on instantly and the computer found it instantly.
May 19, 2008 | Vantec NexStar-3 External 3.5inch...
Accessing
if you can get another hard drive and place it in the enclosure plug usb cable in then turn on the enclosure and see if this works if doesnt place it on another unit or pc and see if it accepts if it does then the usb drivers need to be re-installed goto my computer device manager and find usb it looks like a trident hilight this and click uninstall from menu list in properties then on the top of manager there will be a computer with a spyglass click on this and windows will find new devices let it continue then reboot then re-try enclosure if all goes well it will come up found new device. retry other hdd you first placed in enclosure if it dosen't feel hdd is turning the platters then get rid of hdd. hope this goes well
Apr 20, 2007 | Vantec 1 Bay NexStar 3 USB 2.0 External...
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
