Question about Fantech Dryers
Fantech exhaust fan won't shut off.
Fantech dbf 110 exhaust fan won't shut off.
  • 63 Answers
Faulty switch (replace it) or Loose switch (wrap the body with electric tape)
Posted on Sep 12, 2009
I am renovating a basement bathroom that has no exhaust fan. Venting a fan to the attic would be a difficult and expensive option as there is no current ducting. Can I vent the fan out the side of the...
Yes and no. The answer to this question depends mainly on your local building code. I recommend you contact your local building code official and speak with him or her about recommended specifics. Another source of information will be your local plumbing or electrical supply house.
Thanks for your interest in FixYa.com
Jan 30, 2011 | Fantech Fans Exhaust Fan In-Line
The bathroom exhaust fan in our bungalow is leaking this past week every few days , we are not handy folks and so we are wondering what type of professional do we call in to deal with this leak and...
Sounds like the issue is simply condensation inside the exhaust pipe where it passes through the un-heated attic space. If you use the shower and the exhaust fan, lots of humid air is passing over the inside surface of a very cold duct, then running back down to your bathroom ceiling. You could get any non-specialist handyman to wrap insulation around that duct in the attic. But you can mitigate the problem by running the fan for a few minutes before you start the shower (thereby pre-heating the duct before you give it a blast of moist air) , and leaving it run for 20 minutes afterwards (thereby drying out the duct after use). Regarding the discolored ceiling, the handyman can apply some stain-covering white primer too.
Jan 14, 2011 | Fantech Fans Exhaust Fan In-Line
Size of vent pipe
You will be fine with 2 bends in an 8 inch pipe. If you bend it more than 3 times though you will loose fan force. If you up to a 10 inch duct you will not have good fan force because the space is bigger.
Good Luck and Please Rate FixYa!
Feb 25, 2009 | Fantech Fan FG8XL
Is EDF5 required to have intermitant running of Fantech HR 2005R?
The SHR2005R will turn on the furnace Blower if the furnace is not running to circulate the fresh air. The reason the furnace will not trun on the HRV is, the purpose of the HRV is continuous Ventilation in your home. It should not be turned off when your furnace is not running. That why Fantech has not design the HRV's to run that way. I hope this helps.
Jan 18, 2009 | Fantech EDF5 Intellitek 5MR Control for...
Vantech bathroom fan - the damper doesn't close. How can I clean
You can use Rubbing Alcohol and a Q-Tip.
or
You can take that one out and install one of their RSK Series Backdraft Dampers.
They work very well and they are not expensive.
They can be purchased at http://www.hvacquick.com or http://www.rewci.com
Note: RSK4 is 4", RSK5 is 5" and so on.
Dec 13, 2008 | Fantech Fans Exhaust Fan In-Line
Fan blades or motor in Nucor over the stove hood
it is hard to get the fan off. but if you are carfull you can do it. but any large home improvment store can help with a new fan.
May 03, 2008 | Kitchen Ranges
New bathroom venting in basement bathroom.
Install a window mounted exhaust fan if you can discharge to the outside of the house surrounding atmosphere.But undercut the door of the batroom to allow air coming in into the room.Alternatively firt a door grill 600 x 150 mm size which is more expensive.THe size of the fan should be 50 to 100 l/s of air flow.
Mar 24, 2008 | Fantech Fans Exhaust Fan In-Line
Moisture on bathroom exhause vent
the fan is pulling too many cfm (cubic feet per minute).you can replace the switch of the fan with a potentiometer type switch (this works like a light dimmer)you can reduce the speed of the fan,or you can use a couple of synthetic fiber filters to trap the condensation.good luck
Jan 04, 2008 | Fantech Fans Exhaust Fan In-Line
Dryers Logo
447 people viewed this question
Top Fantech Dryers Experts
Are you a Fantech Dryer Expert? Answer questions, earn points and help others
