Question about Epson Stylus CX6000 All-In-One InkJet Printer
Inserting usb cord
Where to connect it to my laptop. there is no input for my usb cord?
How to connect mouse to Toshiba laptop
First of all, I am assuming you are using a current laptop with USB connectors. For a corded mouse, insert the USB plug into a USB socket. After the computer recognizes the mouse, use the computer control panel software to set up the mouse. For a USB wireless mouse, insert the dongle into a USB socket. After the computer recognizes the dongle, use the computer control panel software to set up the mouse.
Mar 03, 2015 | Toshiba Computers & Internet
Sound settings wont allow sound through hdmi cord
Sound is separate from the HDMI cord. You have to get the sound through the audio portion in the input at the laptop audio using a Y type device one end is stereo input and the other end is the two RCA jacks White and Red then get a cable Audio and insert into input on laptop and then plug in the White and Red to Audio White and Red to whatever component your using to hear the audio. Just a suggestion......John
May 01, 2012 | Acer Computers & Internet
Hp camera help
Hi
Different cameras have different cords which connect to your laptop USB. You can connect to your laptop using the cord or you can also remove the memory card and insert it in the card reader to access the memory card.
Regards.
Javeed
Feb 02, 2012 | HP Cameras
How to conect it with laptop
You must have a AV card connected via the USB which can be used to link the laptop to the TV. The video and audio from the AV card can be connected using the RCA cords to the video input( yellow) and audio inputs( red and white).
Oct 31, 2011 | Panasonic TX-32PM1 32" TV
How do I set up my Elmo to a data projector & a laptop? Specifically, Where do I put the RGB cords - what get's hooked up to what? Thanks!
I am going to bet you got a manual with the TT-02rx that explains the connectivity. If not, you can go to www.elmousa.com and download the manual from the TT-02rx page. Look on page 30.
TT-02rx can be connected in a couple of ways:
1. Directly to Projector - connect a standard VGA cable from the RGB output on the TT-02rx to a RGB (VGA) input on your projector. This will allow you to directly display anything you put under the Elmo camera.
2. USB to laptop, VGA from laptop to your projector. You can connect a standard USB cable from the Elmo to an open USB port on your laptop. From the laptop, you will need to connect VGA cable from output jack to projector input. To view images from the Elmo, you need to have installed the Imagemate software on your laptop first. Elmo can only be viewed thru the software interface.
3. The last option is run VGA from your laptop to VGA input on the Elmo. Then run VGA from Elmo to your projector. This offers the greatest amount of versatility as you can switch between the image on your computer screen and the image on the doc camera. Adding the USB cable as described in 2 above will also allow you to use the digital features such as image capture, reveal, spotlight, etc.
Dec 09, 2010 | Elmo Projectors ELMO TT02RX DIGITAL...
I'M TRYING TO CONNECT MY DVD PLAYER [GE 1101P] TO MY PHILLIPS HDTV. WHICH CORDS GO WHERE?
there should be 3 colored cords,if that's the way you are trying to hook it up.There is that or HDMI.For colored cords,insert the color into the matching color on the OUTPUT labeled portion of the DVD player.Take the other 3 ends and insert them into the INPUT labeled part of the TV.To access it on the TV,you will need to press the input or input select button (whatever it is labeled) on the TV remote,and select input 1 or input 2,depending on which on it is connected to on the TV.Just about all TV's these days have at least 2 inputs for an external source.Your TV remote button may even be labeled source select.You should be all set from there. Good luck!
Jul 28, 2010 | GE 1101P DVD Player
HOW DO I CONNECT A AN EZPRO 610 PROJECTOR TO A LAPTOP COMPUTER.
1. You will need a VGA or S-video cable and a 1/4 inch stereo plug that will go from the earphone jack to the EZpro then out to a amplified system for the sound.
2. I believe the EZpro has connections for HDMI which will supply sound as well as High definition video. You should have an adapter for the HDMI also if you
3. connections port as follows:
1. USB Connector (Connect to PC for Remote Mouse function)
2. RS-232 Connector
3. Audio Input Connector
4. S-Video Input Connector
5. DVI-I Input Connector
(PC Digital (HDCP)/PC Analog/Component Video Input)
6. VGA In/SCART Connector (PC Analog Signal/Component
Video Input, HDTV/SCART Input)
7. VGA Output Connector (Monitor Loop-through Output)
8. Power Socket
9. KensingtonTM Lock Port
Looking at the usb port go counter clockwise the numbers are in succession. 1- 9
1 Power Cord
2 VGA Cable
3 DVI-I to VGA Cable (Optional accessories)
4 Audio Input Cable (Optional accessories)
5 RS232 Cable (Optional accessories)
6 USB Cable (Optional accessories
Apr 24, 2010 | CTX Optoma EzPro 610 Multimedia Projector
Specific Ethernet Cord Input?
Some cords are designed for desktops and laptops and some are also ethernet phone cords for dial up users and if the short one works congrats. hope this mke you understand better.
Jan 08, 2010 | Compaq Presario 700 470024-192 Notebook
I have a new sony laptop with windows 7 and sony XBR6. Trying to hook up the laptop to the tv via HDMI. The laptop can 'see' the tv and the inputs menu on the TV shows there is something connected to that...
Hello. Do not use HDMI for this purpose, instead go to Walmart and get a usb cord that plugs into your tv. Then use the remote control for your TV to push input and locate your computer, usually at the bottom of the list. Regards, Joe
Dec 22, 2009 | Computers & Internet
Can I upload photos through the USB cord? If so, I am having trouble getting the computer to recognize that the camera is connected. What do I do!?
use the alternative. Obtain a card reader and insert it into the reader which in turn is connected to the USB port
Generally the USB should be recognised, but there is quite often this problem due to different levels of USB ( 1 and 2)
Oct 08, 2009 | Kodak EASYSHARE M1063 Digital Camera
Epson Stylus  CX6000 All-In-One InkJet Printer Logo
20 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
