Question about Haier (B000194UBA) Compact Refrigerator
My fridge wont stay cold.
The freezer part is extremely cold and its building ice everywhere but the fridge part wont get cold at all and all my food is going bad. what can i do?
  • 78 Answers
It is not frost free , there is no fan , this fridge for light office use , also make sure gasket is ok , good luck:)
Posted on Sep 12, 2009
Freezer stays cold. Why is fridge part warm?
if freezer gets iced up the fan designed to pass cold air from the freezer to the fridge stops working. The freezer is meant to go into a defrost mode when its trtansducer senses too much ice. If the transducer goes fault the ice builds up. Some fridges use a timer to work this out so it could be a timer fault. Talk to a service man about how much ice the freezer should have for them to sucessfully diagnose the fault. Too much ice may prevent the service man from working out if temperature sensor is working and no ice can prevent him from testing sensor. To get rid of ice you have to trun off the power to the fridge and let it melt.
BEWARE remove food to another freezer and fridge to prevent food going off or getting food poisioning
Sep 17, 2015 | Estate TT14DKXKQ Top Freezer Refrigerator
Samsung rf217acpn/xaa fridge not staying cold and ice build up.
Be sure the drain is clear these are well known for drain blockage. the area behind the shelves is where you would find the evaporator and drain hole.
"Always disconnect power before trying to repair any appliance."
Jul 11, 2017 | Samsung 19.7 Cu. Ft. French Door...
Why wont my fridge stay cool?
MAKE SURE THE FAN IN THE FREEZER IS RUNNING THATS THE ONLY WAY THE REFRIGERATOR STAYS COLD DO YOU HAVE AN ICEMAKER IF YOU DO IS IT WORKING OR A DEFROST PROBLEM ANY ICE OR FROST BUILD UP IN THE FREEZER
IF YOU SEE IT ON THE WALLS ITS FULL BEHIND THE WALLS OF THE FREEZER
Jul 11, 2014 | Frigidaire Refrigerators
The fridge has stoped workingbut the freezer is fine
if it starts working ok after the defrost then you might find it will build up ice again.
There might be a fault with a small device called a thermister that senses the ice build up for the defrost controller.
What most likely is happening is the ice build up freezes the fan that blows the cold air to the fridge compartment.and around the freezer.
May 14, 2017 | Bosch KGU6655
My freezer all of sudden isnt keeping things frozen..and the fridge isnt staying cold
ck in back of freezer for ice build up . if so the defrost system has failed . if may need a heater or timer( control ) to correct problem . the frost in the back of freezer blocks air flow and the fresh food area does not get any cold . and then the freezer gets warmer . and ice cream is not hard .. hopt this helped ****
Feb 10, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
My bottom freezer is making ice but not keeping the food frozen
The flow tubes are blocked.You will need to defrost the unit,unplug and pull off as much ice as possible.You can put pans of hot water in the freezer.
Feb 12, 2009 | Whirlpool GB9SHKXL Bottom Freezer...
Freezer not freezing
It sound like you may be having defrost issues,Check to see if you have a build up of ice on the inside rear wall of the freezer.If so,You will need to have the defrost timer,defrost element,and the defrost thermostat checked.
Please rate this.
Dec 27, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Fridge not cold
HI thanks for your question. check to see if the fan motor is running in the freezer. that could be the problem. thanks the appliance doc. please rate my answer. thanks
Oct 08, 2008 | Frigidaire FRT18B4A Top Freezer...
Fridge wont stay cold in the bottom.
Your frost free is not defrosting properly. There should be no ice buildup in the freezer section. Frost in the freezer section stops air circulation to the refrigerator section.
Jun 28, 2008 | GE Refrigerators
Haier (B000194UBA) Compact Refrigerator Logo
468 people viewed this question
Top Haier Refrigerators Experts
John Tripp
John Tripp
geob91
doggzzz
Level 1 Expert
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
