I am getting the stop 000218 message on my windows xp can't start in safe mode or anything...please help
  • 39 Answers
Hello
I am sure this will help (read it all):
http://support.microsoft.com/kb/307545/
Best Regards
3B00DX
Posted on Sep 12, 2009
Start my pc on safemode
Windows 2000 and XP users Tip: If you are running Safe Mode because you cannot get into Windows, you may want to first try loading the last known good configuration.
To get into the Windows 2000 and XP Safe mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Note: With some computers, if you press and hold a key as the computer is booting you will get a stuck key message. If this occurs, instead of pressing and holding the "F8 key", tap the "F8 key" continuously until you get the startup menu.
Trouble Getting into Windows 2000 or Windows XP Safe mode - If after several attempts you are unable to get into Windows 2000 or Windows XP Safe Mode as the computer is booting into Windows, turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice. Once you're done in Safe mode if you want to get back into Normal Windows restart the computer like you normally would and let it boot normally. Click here to get additional information about getting out of Safe mode.
loading the last known good configuration.To get into the Windows Vista and Windows 7 Safe Mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Note: With some computers if you press and hold a key as the computer is booting you will get a stuck key message. If this occurs, instead of pressing and holding the "F8 key", tap the "F8 key" continuously until you get the startup menu.
Trouble Getting into Safe mode - If after several attempts you are unable to get into Safe Mode as the computer is booting into Windows, turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Choose Advanced Options for: Microsoft Windows Vista
Safe Mode
Enable Boot Logging
Enable low-resolution video (640x480)
Last Known Good Configuration (advanced)
Debugging Mode
Disable automatic restart on system failure
Disable Driver Signature Enforcement
Description: Start Windows with only the core drivers and services. Use
when you cannot boot after installing a new device or driver. Once you're done in Safe mode if you want to get back into Normal Windows restart the computer like you normally would and let it boot normally.
Aug 13, 2014 | Computers & Internet
Can only start pc in safe mode keeps doing windows inconsistency check. Seems to be on loop. Blue screen shows Tech info stop 0X0000007F (0X0000000D, 0X00000000, 0X00000000, 0X0000000. Windows XP. Please...
Try start up in Safe Mode press F8. Choose Safe Mode, when at the choice window, to select either Safe Mode Desktop, OR System Restore, chooses system restore and choose a time before you had the "Problem" and follow instructions. This should get you back.
Mar 15, 2010 | Computers & Internet
Hi I get a "signal out of range" message until windows xp starts. This means I can't get into safe mode or see start up messages. Any ideas please?
You see "Signal Out of Range" does not mean you cannot go to Safe mode or see startup messages. It shows up when you dont have a display. The refresh rate of your monitor is a little slow. So when you wana go to safe mode, press the Power button and start pressing F8 option and you will get the safe mode option and you will see startup messages when you will get one. Your computer is perfect. :)
All the best.
Regards,
Shrey
Oct 09, 2009 | HP L1955 19" LCD Monitor
PC BOOTS HALF WAY
Try booting into safe mode. If it's a driver problem, safe mode will allow you to start Windows with only the bare minimum of hardware and drivers being engaged. To get to safe mode, press the F8 button on your keyboard during the Windows boot process until it takes you to a screen to let you select Normal, Safe Mode, Safe Mode with networking, etc. I would suggest not using anything other than just Safe Mode. From there, uninstall any software or new drivers that you recently installed. Alternatively, you can use the System Restore feature to rollback to a previous restore point.
Aug 10, 2009 | HP Computers & Internet
Safe mode
You can also force the system into safe mode. You click on startup and type in msconfig. Click the general tab and select diags and the system will reboot to safe mode. Change it back to normal to get your system out of safe mode.
Please rate my response.
Feb 17, 2009 | Microsoft Windows XP Home Edition
When starting up Windows XP - the process stops and I get the message C0000135 application failed because user32.dll wasnot found. I have tried to start in safe mode but the same problem re-appears. ie:...
I've just seen this on another users pc, here is how i solved it:
Start from your xp disk (recovery disk that you got with your machine or retail copy of xp), when prompted go into recovery mode (press r at the menu)
when in the recovery mode go to c:\windows\$NtServicePackUninstall$ and type
copy user32.dll c:\windows\system32\
then type 'exit' without quotes to reboot
your system will now boot up fine
(note there may be a copy of the user32.dll file in c:\windows\system32\dllcache\ as well)
Dec 10, 2008 | Computers & Internet
Unable to boot the computer
start the sys and press F8 KEY to go to safe mode.
then run chkdsk
Apr 03, 2008 | Microsoft Windows XP Home Edition
Windows XP fails to load and Computer will not start up.
Boot from startup floppy disks or CD-ROM, choose repair option during setup, and run Recovery Console. When you are logged on, you can run FIXMBR command to fix master boot record. This should solve your problem.
Sep 20, 2007 | HP Compaq Presario V2000 Notebook
Computers & Internet Logo
141 people viewed this question
David Payne
David Payne
