Question about Canon EOS 40D Digital Camera
I have a eos40d.. when shooting in AF the camera wont focus nor shoot.. i have to set it to MF to be able to get pics...
  • jbrinquis Sep 12, 2009
    nope, is not that.. im in daylight and far away object
  • 10,515 Answers
A few things to try. (you may have done all this already.
1. Make sure your battery is fully charged.
2. Remove the lens from the camera and inspect the 9 copper contacts that are on the bottom of the inside part of the lens. Ensure there is no damage or gook on any of them.
3. Do the same on the camera body. You'll see there are 9 spring loaded contact pins. ensure there are no damged pins and all move freely in and out.
4. Mount lens on camera, turn camera on, move mode dial to auto and press shutter release button to see if it will focus now. Make sure you AF is set to S-AF. Do this in plenty of available light.
5. if your indoors and the lighting is not great. Turn the flash on by pressing the button on the top left hand side of the camera. The flash will pop-up and you should be able to press the shutter release button.
One last thing to look at. With the lens mounted to the camera, press the MENU button and scroll down to firmware. It should be somewhere in tool list. Access the firmware. If the camera is recognizing the lens, the display should show the firmware for both the camera and the lens. If not, then........
You may want to contact manufacturing company. They should be able to give you further instructions. Failing that, they can give you an ideas as to the cost to repair.
If there is no response. you may just have a bad lens.. Many people have reported this problem and there is not much you can do about it then returning..
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Sep 12, 2009
  • 123 Answers
You are trying to focus to close to and object or in light that is too low.
D90 wont shoot in auto mode. gives me r21 error. Manual mode works fine
Did you switch the Focus-mode selector to MF?
It is the switch with number 8. Perhaps you are used to switching on the lens, but on the body is also a switch. Normaly used for the older AF lenses.
Apr 22, 2014 | Nikon D90 Digital Camera with 18-105mm...
Nikon N65 with Nikkor 35~80mm AF lens will not focus or shoot
N65s were notorious for bad shutter release buttons. The metal is thinner than a strand of hair and they break. Search Ebay and see if the part is available to replace (note: Nikon stopped selling parts last year).
Feb 17, 2014 | Nikon N65 35mm SLR Camera
My D3100 will not autofocus or take pictures even if the lens is set to Auto Focus. If the lens is set to Manual, all works well. How do I get auto focus to work again
Go to your settings when your in shooting-mode (Press the 'i' button on the bottom left).
There, change your focus mode from MF to AF-S or AF-C or AF-A.
Should work.
Feb 05, 2011 | Nikon D3100 Digital Camera
I have a eos40D, when in AF it wont focus nor shoot pics
Hi. Good Camera... Not being funny.. But do you have the instruction manual. If not first try resetting the camera. Once done, if you can live without live view don`t bother setting it up.
How to reset:-
-set the mode to manual
-press menu, scroll to the third yellow box with the spanner icon.
-scroll to Clear all camera settings,choose clear and confirm your choice.
When you are shooting make sure your lens is switched in AF mode.
Try this first and get back to me.
Sep 12, 2009 | Canon EOS 40D Digital Camera
Iso to auto
On the back of the camera to the Right of the LCD there is a up-down-left-right-center switch. push the up one. (Labeled ISO) then use the same selector switch to select the ISO you want and then press the shutter half way down. If you are shooting in a low light situation, the auto focus sometimes will not work. Change the switch on the lens from AF to MF and focus manually.
Sep 26, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Nikkon d50 wont auto focus
the D50 will only auto focus with an AF-S lens...make sure you are using an AF-S lens.
Also, check the swithc on the lens is set to "A" not "M" ...
Also, in the menu, check you set the camera as autofocus, not manual focus
Jun 07, 2008 | Nikon Cameras
Canon Rebel will not shoot in AF mode
the mirror is problem of your camera,it alway been close that why the sensor is functioning properly cause that sensor is working in af mode....check the post at the side of the mirror if not broken and the spring of the mirror if not dislocated....doing this you should removed the lens from the body......
Aug 25, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Sequential shooting modes
There are four sequential modes: Sequential shooting, High-speed Sequential shooting, AF Sequential shooting and Auto Bracketing. Sequential shooting modes can be selected from the CAMERA menu: Sequential shooting: A maximum of 11 frames can be shot sequentially at approximately 1.7 fps in HQ mode. Focus, Brightness (exposure) and White Balance are locked at the first frame. High-speed Sequential shooting: A maximum of 4 frames can be shot sequentially at approximately 3.3 fps. Focus, Brightness (exposure) and White Balance are locked at the first frame. AF Sequential shooting: Focus is individually locked for each frame. The AF Sequential shooting speed is slower than for normal sequential shooting. Auto Bracketing: When Auto bracketing is set, exposure is changed automatically for each frame when you start shooting. The exposure differential can be selected in the menus. Focus and white balance are locked at the first frame.
Sep 04, 2005 | Olympus Camedia C-8080 Wide Zoom Digital...
There are four modes: Sequential shooting, High-speed Sequential shooting, AF Sequential shooting and Auto Bracketing. Sequential shooting modes can be selected from the DRIVE mode menu: Sequential shooting: A maximum of 11 frames can be shot sequentially at approximately 1.7 fps in HQ mode. Focus, Brightness (exposure) and White Balance are locked at the first frame. High-speed Sequential shooting: A maximum of 4 frames can be shot sequentially at approximately 3.3 fps. Focus, Brightness (exposure) and White Balance are locked at the first frame. AF Sequential shooting: Focus is individually locked for each frame. The AF Sequential shooting speed is slower than for normal sequential shooting. Auto Bracketing: When Auto bracketing is set, exposure is changed automatically for each frame when you start shooting. The exposure differential can be selected in the menus. Focus and white balance are locked at the first frame.
Sep 04, 2005 | Olympus Camedia C-60 Zoom Digital Camera
There are four modes: Sequential shooting, High-speed Sequential shooting, AF Sequential shooting and Auto Bracketing. Sequential shooting modes can be selected from the DRIVE mode menu: - Sequential shooting: A maximum of 11 frames can be shot sequentially at approximately 1.7 fps in HQ mode. Focus, Brightness (exposure) and White Balance are locked at the first frame. - High-speed Sequential shooting: A maximum of 4 frames can be shot sequentially at approximately 3.3 fps. Focus, Brightness (exposure) and White Balance are locked at the first frame. - AF Sequential shooting: Focus is individually locked for each frame. The AF Sequential shooting speed is slower than for normal sequential shooting. - Auto Bracketing: When Auto bracketing is set, exposure is changed automatically for each frame when you start shooting. The exposure differential can be selected in the menus. Focus and white balance are locked at the first frame.
Sep 04, 2005 | Olympus Camedia C-5060 Wide Zoom Digital...
Canon EOS 40D Digital Camera Logo
21 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
