I only have the big speaker not 2 small ones that actually go with it so I'd like to know how to hook it up to my pc and what other speakers may be compatible
    Problem Solver:
  • 5 Answers
Connect the sound card of the PC with a recommended amplifier and then connect your big speakers to the amplifier, you can get the big speakers working. Note that the amplifier watts must be in respect to the maximum watts of your big speakers. Either the amplifier should have more watts producing capacity than your speakers or should be of the same watts in order to give you full output volume.
Posted on Sep 12, 2009
Speaker setup
you should be able to get speaker wire from walmart or local automotive store like advance,orileys, or lowes. its a small 2 conductor wire that you strip the ends back and place under each tab. be sure you have the white to white and red to red. hope this helps jake
Jul 05, 2013 | Cars & Trucks
My speaker is no sounds
connect the front speakers to the 2 Big Banana plug/screw type connectors marked speakers A and not the 2 color coded ones that are push in style. the B channel speakers are actually color coded and I hooked mine up this way and had similar issues.
Dec 12, 2012 | Onkyo HT-S5300 Theater System
Why does the hifonics bxi1608d 1600 watt super D-class mono have 2 postive terminals and two negative terminals? would that cause my speakers to blow?
That is still a single channel cass D amp. Each (-) and each (+) terminal are connected so its actually like only having one. This is so you can hook speakers up in a series circuit to lower impedance, because this amp is 1ohm stable. What causes your speakers to blow is too much power. What kind of speakers are you running? This hifonics amp is very powerful, they are getting big in the competition industries beacuse they put our true power for less money and they are tough. That 1600 amp you have may be putting out more like 1800 watts at 14.4 volts which is 900 per sub at 1ohm so be careful this amp has tons of power and its true rated its not like a sony or rocksford or kenwood that says 1800 max and then in small writing it says 500 rms. This amp puts out true. I have 3 hifonics amps and love them.
May 07, 2010 | Hifonics BXi1608D Car Amp
Need a manual for Technics Receiver SA-160
Go and google it as you can buy it on line ... how tough can it be the hook up speaker wires? The small speakers are front and back, left and right in pairs. red wire to red jack on back , black wire to black jack. big speaker goes to sub wolf. jack in back. Now get those wires and play your Christmas music. note jacks may be marked fr fl rr rl sub
Dec 10, 2009 | Audio Players & Recorders
Speaker linking
You know, watts is a heat dissipation unit... It tells nothing about your speaker, the usage you wanna do with it, and what about the amp! Usually on proffessionnal amplifier ( i mean touring power amp) we rely 2 speakers in parallel per side of amp. It turns the amp working at 4 ohms and ifs it pushed by a good amp, and a reasonnable operator, things goes find. If amp ''clip'' it sending DC in the speakers and you actually in the way of a repair. So its now having too much power amp that usually breaks speakers, but too small amp. Check the specifications of what your amp can gives at 20hz to 20khz, both channel driven at 4 ohms. You find out that the amp you believe was sending you 500watts is giving you only 250... Thats why pro series of amp cost so much. Because they are not playing on words but giving power... Cheap series of pro amp counts wattages at 4ohms one channel driven at 1khz at 1% distortions wich is unnaceptable. 0.1% is the max acceptables. Go meet the tech at your local big touring sound contractor and ask for the real thing. You'll get the right answer and analysis of your kit...
Aug 04, 2009 | Behringer EUROPOWER EP2500 Amplifier
New (old) house with stuff installed when we got it
IF YOU HAVE THE SAME AMOUNT OF CABLES AS SPEAKERS HOOK THESE UP TO YOUR AMP THEN SUB TO SUB OUT PUT ON YOUR AMP WITH A SUB CABLE OR PHONO THAT REACHES FROM AMP TO SUB.SET AMP TO ALL CHANNEL STEREO OR MODE THAT SENDS STEREO TO ALL SPEAKERS,ALSO SET SPEAKER SIZE IN SETUP OF AMP TO SMALL AND SUB OUT PUT TO SUB ONLY.YOU SHOULD GET MUSIC AROUND THE HOUSE.IF SOUND IN SAY BEDROOM IS NOT AS LOUD AS BATHROOM USE THE TEST TONE TO LEVEL OUT EACH SPEAKER.
HOPE THIS HELPS.
CABLE GUY.
Jun 26, 2008 | Audio Players & Recorders
Dont know whats wrong
You can check the fuses if it has more than one. Or another thing that might be wrong is that you might have to big of a speaker hooked up. Or your power wire might be to small because if its two small then the amp cant get enough power to power a big speaker.
Jan 25, 2008 | Earthquake Sound PH-D3 Car Audio Amplifier
How to add more speakers?
In the end I biwired the speakers and that's worked fine.
Aug 12, 2007 | Denon D-M71DVS System
Speaker Hook Up - Non-Technical (single) Female
bought the same amp second hand and had same problem as there are two seperate amp chips inside one for front speakers and one for the centre and rears it could be the actual amp chip that drives the front speakers has died as there is no built in speaker protection so over driving these speakers will result in the amp chip blowing . it may be something simple but it was not on mine had to buy new amp chip and solder in that sorted the problem for me !
Jun 02, 2007 | Technics SA-DX950 Receiver
91 people viewed this question
 Grubhead
Grubhead
