Question about Toshiba 50H82 50" Rear Projection Television
Toshiba Rear Projection TV picture color is now a greenish hue
I have a Toshiba Theatherwide HD rear projection TV that I bought 6 years ago. For about a month when I watch movies (I don't have cable so I don't watch TV) the color hues are wrong. Everything is a greenish hue. Any suggestions?
  • 60 Answers
Hi, I used to work in Best Buy and one of the key things about rear projection TVs and the reason they push those service plans on you is that the tubes/colors need to be calibrated each year. You can do this yourself by checking out the following website:
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=3229
If you are not able to adjust the convergence using the remote you will need to replace the convergence chips.
Typical Symptoms
1) Convergence menu does not work for one or more colors.
Such as: Red moves up,down, but left or right fails.
2) Screen is bowed looking.
If you have one or more of the problems above you need to replace the convergence chips. You can get a kit and instructions from www.TvRepairKits.com
Hope this helps :)
Posted on Sep 17, 2009
Problem with sony 60" rear projection TV
I'm afraid, it is problem of optical block unit (light engine) that produce picture by 3 lcds inbuilt, the blue lcd and its related uv filters become defective and causing this kind of blue hue on screen.
Complete optical unit block (light engine) will be replaced by qualified tech to get tv fixed, light engine is costly part so ask an estimate before sending tv in.
Thanks.
May 21, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
Toshiba Theaterwide HD 51h84
It is your projector tub if you are getting alot of blue in the picture. Those guns are very expensive to replace. I am sorry to tell you that. It would be cheaper set from wal-mart for your kids to play on.
Nov 23, 2009 | Toshiba 51H84 51" Rear Projection...
Sony KP-53HS30 Projection TV has pink and blue hue w/timer blink
Depending on your TV, you may have a Color Temperature (Color Temp) and/or Hue setting in the menu. Use these options to adjust the picture to the setting that best suits your viewing preference.
If your TV has a Color Temp setting, you will normally have the following options to select from:
  • Cool: Gives the picture a cooler, slightly bluish appearance.
  • Neutral: Gives the picture a neutral, more natural look and appearance.
  • Warm: Gives the picture a warmer, slightly reddish appearance.
If your TV has a Hue setting, follow the appropriate step below to make adjustments:
  1. Move the setting to the right to reduce the reddish appearance.
  2. Move the setting to the left to reduce the greenish appearance.
Aug 03, 2009 | Sony KP-53HS30 53" Rear Projection...
Toshiba rear projection TV 43VH9UA
have toshiba 43vh9ua picture is purple to blue in colour does anyone have a fix... thanks nev
May 12, 2009 | Toshiba 43H72 43" Rear Projection...
I HAVE A 57 IN. TOSHIBA HD TV AND THE TV SCREEN IS A GREENISH
take the front panel off the tv, the bottom, you will see 6 little nobbs :::, use them to adjust your picture, the left 2 should be for red, the middle 2 dlue, and right green, top 3 are for focas, those are probabily the ones you want to adjust, bottom 3 are for turning the colors up and down, mess with those untill pic looks good
Jan 07, 2009 | Toshiba 57H81 57" Rear Projection...
Toshiba 65H80 has yellow hue.
Check you HD inputs or source. Sounds like the red stream is missing; maybe a loose cable.
Nov 17, 2008 | Toshiba 65H80 65" Rear Projection...
Uneven Color on JVC Projection TV
hello i have a jvc 52" made in july 2004 replaced bulb twice under warranty plus replaced ballast board in 2005 replaced bulb dec 2008 my tv was before and after install having a blue hue reversed words
Sep 01, 2008 | JVC HD-52Z575 52" Rear Projection...
Greenish color when using component to RGB connection
either the problem of convergence ICS or the problem of convergence settings.
for replacement of ics click this link
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
for the settings click this link
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
thanks.
Aug 28, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
Toshiba 50H82 50" Rear Projection Television Logo
167 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
