Question about iLO 3200 32 in. LCD Television
Television wont respond on/off
No response from remote or side panel controls. only blinking red light where on/off display light appears
  • 3 more comments
  • Anonymous Dec 11, 2007
    the tv will turn on/off but no other conrtoles will work
  • rockchick57 Jan 02, 2008
    My Ilo has been pretty good til today.All of a sudden it just shut off and the red "off" button just keeps blinking.Tried unplugging,no help.Fortunately I purchased extended warrenty.But I'm gonna be without a tv for a month at least!
  • Anonymous Jan 02, 2008
    I have the same problem and Wal-Mart would not take it back. They told me to call iLo to return the item but every time an iLo representative called I was on the road or working. Each time they wanted me to trouble shoot the TV with them over the phone. My iLo remote and side controls don't respond.
  • mjjt420 Jan 03, 2008
    I read the coments my tv just shut off and will not power on the cable box is on and working but the remote won't turn it on nor will the side buttons, I read the website that I am responding to now I see no solution what do we do to get the tv on
  • wingfldk Jan 04, 2008
    I am having the same problem the on/off will not work on either the side panel or remote. Red light is there but not on/off.
Sylvesteru8
I do not see any customer support phone number.....
What EXACTLY did the management of Wal-Mart tell you
Chicken217
Posted on Dec 11, 2007
Sanyo LCD-32K30TD (Australian model) no picture, audio only.
If it appears that your panel is lighting but you have no picture you have one of two problems. Either your T-con is bad ( most likely ) or your main board is bad.
Mar 18, 2013 | Televison & Video
I have a 30" Targa Visionary TV, model LT 3020. I cannot find a code to make it respond to the latest, rev 9 (or older) Sky Remote.
you will have to ask for the sky operator for the code sir.
mostly there wont be any code. just ask him if you need to change some settings to make it respond.
Aug 02, 2008 | Televison & Video
Program remote for comcast
Check these codes: 11144, 11240, 11331
programmmming TVTV control
The Comcast DTA remote control is preprogrammed at the factory to operate the DTA receiver. The Comcast DTA remote also contains a universal TV library to allow you to control the Power and Volume of your TV.
1. Turn on the TV
NOTE: Please read steps 2 to 4 completely before proceeding. Highlight or write down the codes and device you wish to program before moving on to step 2.
2. Press and hold Setup until the Red Light blinks twice, then release Setup.
3. Locate the code for your device in Manufacturer's Codes on the back of this user guide. Brands are listed in alphabetical order with the most popular codes listed first.
4. Enter the first five-digit code for your TV. If you perform this procedure correctly, the Red Light will blink twice
NOTE: If you enter an invalid code, the red light will display one long blink and exit the programming mode. Repeat steps 2 to 5 with a valid code.
5. Aim the remote control at your TV and press Power once. The device should turn off. If it does not respond, repeat steps 2 to 4, trying each code listed for your brand until you find one that works. If it still does not work, try Searching For Your Code.
Jul 16, 2012 | Olevia 227-S11 27 in. LCD TV
Need code for comcast remote for symphonic dvd wf104.
Hello
Universal remote code for Syphonic TV with Comcast remote control are:
10180, 10171, 11904, 11913
1. Turn on the TV
2. Press and hold SETuntil the Red Light blinks twice, then release SET.
6. For future reference, write your TV code in a safe place.
OK
Jan 17, 2011 | Televison & Video
How to program radioshack 3 in one remote to a panasonic dvd home theater sound system sa-dm3?
hi,
try any one of the following code. if not work do the following steps to find out code.021, 107, 035, 081, 110, 162,225, 454,035, 162,051, 054, 055, 250
MANUAL CODE SEARCH
If the 3-in-One Easy Remote Control does not op-erate your remote-controlled devices when you
first set it up, you might have to manually find the correct code for your devices. you can
follow these steps to search the remote control's entire library.
1. Manually turn on the device you want to set
up.
2. Press the corresponding device key (TV,
VCR, or CBL).
3. Hold down P until the red light blinks twice,
then press 9, 9, and 1. The red light blinks
twice again.
4. Aim the remote control at the device you
want to operate.
5. Repeatedly press PWR then the device key
for the device until it responds to the command.
6. When the device responds to the command,
press P within 5 seconds to save the code.
Note: If you do not press P within 5 seconds,
the remote control does not save the code.
• Because the remote control's library has
so many codes, this procedure can take
several minutes.
• If your device turns off during the search,
but does not operate after you lock in the
code, begin the search again, pausing
longer between key presses.
Determining the 3-Digit Code
After you set up your remote control using manual code search, you can find which 3-digit code the
remote control is set to by following these steps.
1. Press the device key you want to get the
manufacturer's code from, then hold down P
until the red light blinks twice.
2. Press 9 9 0 . The red light blinks twice again.
3. Press 1 then count the number of times the
red light blinks. This is the first digit of the 3-
digit code.
Note: If the red light does not blink, the digit
is a 0.
4. Repeat Step 3 twice to find the second and
third numbers of your 3-digit manufacturer's
code, pressing 2 and 3 respectively for each
additional digit.
ok
Dec 14, 2010 | Panasonic Televison & Video
Hi i have lost instruction manual for my total remote urc 11-4110 b02 Universal Remote could you tell me how to code it to tv manually please
@font-face { font-family: "Cambria"; }p.MsoNormal, li.MsoNormal, div.MsoNormal { margin: 0cm 0cm 10pt; font-size: 12pt; font-family: "Times New Roman"; }div.Section1 { page: Section1; } SET UP
TV
The Search Method
If your device does not respond to the TOTAL CONTROL after you have tried all the codes listed for your brand, try searching for your code. The Search Method allows you to find the code for your device by scanning through all the codes contained in the memory of the TOTAL CONTROL.
To search for your TV code:
1 Switch your television on (not on standby) and aim your TOTAL CONTROL at your TV.
2 Press the TV key on your TOTAL CONTROL.
3 Press and hold down SET UP until the red light blinks twice. (The red light will blink once and then twice)
4 Press 9 9 1. The red light will blink twice .
5 Now slowly, alternate between POWER and TV, over and over, until your television turns off. You may have to press these keys many times (up to 150!), so please be patient.Remember to keep pointing the TOTAL CONTROL at your television when you press these keys.
6 As soon as your television turns off, press SET UP.
The TOTAL CONTROL remote should now be ready to operate your device. Turn your device back on and try all the remote’s functions to ensure they are working
properly. If some of the TOTAL CONTROL’s commands are not operating correctly, try the search method again. You may be using the wrong code.
Once you have Set-Up your TOTAL CONTROL, you can blink back your SET-UP CODE for future reference.
Example: To blink out your Television code:
1 Press TV once.
2 Press and hold SET UP until the red light blinks twice (The red light will blink once and then twice).
3 Press 9 9 0. The red light will blink twice.
4 For the first digit of your four-digit code, press 1 and count all the red blinks. If there are no blinks, the digit is "0".
5 For the second digit, press 2 and count all the red blinks. If there are no blinks, the digit is "0".
6 For the third digit, press 3 and count all the red blinks.
7 For the fourth digit, press 4 and count all the red blinks. If there are no blinks, the digit is "0". Now you have your four-digit code.Make sure you write your Television code for easy future reference.
Aug 12, 2010 | Televison & Video
62HM15 Toshiba DLP TV won't respond to remote or control panel
Blinking is a trouble code. Try unpluging for a longer time then hold power button in when pluging back in to try and reset.
Mar 15, 2010 | Toshiba 62HM15 62" Television
I'm trying to program my ''Comcast'' cable box remote control to operate my byd:sign model d:5032M plasma TV. Comcast does not have a standard 4 digit TV code to use. How can I get the code as there is no...
If your brand of TV does not respond to the remote control after trying all of the codes listed, or if your brand is not listed at all, try searching for your code.
1. Turn on your TV.
3. Enter in 9 - 9 - 1. The Red Light will blink twice.
4. While pointing the remote control at the TV and press and release the CH + key until the TV turns off. (Note: You may need to press [CH+] numerous times).
NOTE: In the search mode, the remote control will send IR codes from its library to the TV.
5. Press SETonce to lock in the code. The Red Light will blink twice.
Sep 19, 2009 | byD sign d:5032 50 in. HD-Ready Plasma...
Plasma tv wont respond to the buttons being pushed on the tv
ok ,try cleaning the remote, first.open it up and clean it with alcohol and soft cloth.let it dry.then,assemble it.be sure your batteries are ok.
May 28, 2009 | Panasonic TH-42PD50U 42 in. Plasma EDTV
iLO 3200 32 in. LCD Television Logo
24 people viewed this question
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Jason Morris
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
