You need to find out what ports your ip cameras use, and then setup port forwarding on your router. If you have 1 box that controls all the cameras, you just need to forward port 80 traffic to that box. If you have multiple cameras with NO main junction box, you will need to go into the setup on each camera, and specify a port to use. Then in the router, set up port forwarding to forward each different port, to the camera it goes with. Then when you want to see the camera from home you would type the ip address in the browser, then a colon, then the port number --> IPADDRESS:81
Was this helpful?
Yes
No
Popular Solutions for 2wire HomePortal 1100 Router
I am trying to connect my Xbox 360 directly to my 2wire homeportal 1100 modem/HPNA device.
I...
(More)
I connected an ethernet cable into the Xbox, and then into the ethernet port of the 2wire homeportal.
90% of the time my Xbox will not pass the IP test.
One time I was able to pass the IP and DNS tests only to fail the MTU test.
I have tried power cycling and opening ports.
Thank you
Can not get them to communicate. All lights are lit up but lose all internet connection. How do I...
(More)
Can not get them to communicate. All lights are lit up but lose all internet connection. How do I fix this?
