Question about Mtd Garden
Why does my mower shut off after I turn the choke off?
After cleaning the carb on my 42in, 17.5 hp briggs and stratton mower, it will not stay running. It will start and run with the choke on but shuts off when I shut the choke off.
  • jgseeger Sep 12, 2009
    I actually did not take the carb off. I took off the bowl and sprayed carb cleaner in through the bottom.
  • 123 Answers
It sounds like you took the carb off the engine and did not replace the gasket or tore the gasket and it is sucking too much air. Also check to see if the carb and bracket ( if it has one ) are on straight.
Posted on Sep 12, 2009
3.5 hp Briggs & Stratton won't run unless I pour gas into carb
This sounds like a problem with the suction. If the air filter is clean then it will need new carb gaskets. There may also be an issue with the pressure being created by the engine.
Jun 18, 2014 | Briggs & Stratton Briggs Stratton...
17 hp briggs stratton ohc
Clean or change air filter. Clean, gap or change spark plug. Empty gas tank add fresh gas with Stabil. When spark plug is removed pull rope several times to blow out cylinder. Spray starter fluid in spark plug hole before replacing spark plug. Clean outside of carb so choke works freely. Spray starter fluid into carb breather hole with air filter removed and try to start. if running replace air filter and cover. If no start disassemble carb and clean. If no start replace carb.
Jun 19, 2013 | Garden
Briggs and stratton 35 classic. Need piccy of arrangement of carb/choke links and springs as think someone has changed them and mower no work. Model 9D902. Lever which may be choke, does not stay in place...
check youtube,guy on there has pics of spring set up,and still pics to follow the video.
check this name on youtube:4 HP Briggs & Stratton Quatro Motor Spring & Linkage Close Up Detail
Apr 25, 2011 | Briggs & Stratton Briggs Stratton...
Choke needs to stay on and engine backfires when
COULD BE A CARBARATOR PROBLEM
YOUR PROBLEM IS CALLED ENGINE RUN ON OR DIESELING THIS HAPPENS WHEN YOU TURN OFF THE KEY AND FUEL IS STILL BEING PUMPED INTO THE CARB. COULD BE DIRT UNDER THE NEEDLE VALVE FOR THE FLOAT
Aug 10, 2009 | Briggs & Stratton Briggs Stratton Intek V...
After about 30 to 40 minutes of use (varies, the
I have a 7 year-old craftsman mower with a 22 HP Briggs engine that has the same issue. After about an hour, the mower acts as if it is starving for fuel and then stalls. Then after about 5 minutes of sitting, it will run for a little while longer.
If your engine is similar to mine, then its carb has a fuel shut off solenoid which shuts off fuel to the Main Jet when Voltage is removed to prevent backfiring when the key is shut off.
Unfortunately, this solenoid can also cause the carb to starve for fuel when not working properly. In my case, when I cleaned the solenoid and the solenoid's connections, the tractor had no problem after that.
Hope that helps,
Steve
Jul 25, 2009 | Briggs & Stratton Briggs Stratton Vanguard...
Carburetor adjustment
have you checked the air filter,if that is clean I think I would replace the carb, diaphram.
May 05, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Garden Logo
397 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
