Paper go through to right side corner and jammed
SOURCE: paper jamming and feeding unevenly
I have the exact same problem. Until last night it worked perfectly, and when it ran out of paper, I put more papers in the back of the printer correctly and since then it won't print, it pulls paper to the right and the paper jams. I tooked the printer to the service and they say that I'm lucky that the warranty did not expired yet, cause the problem is a "manufacturing mistake", and that they will take it to the Canon service.
I realy hope they will do the job. I'm expecting to repair be done till tomorow.
Posted on May 08, 2008
Ajkill
  • 2035 Answers
SOURCE: paper jamming at right hand
  1. Turn the printer off and open the access cover.
  2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
  3. Turn the printer on, load some paper, and press the Form Feed button.
  4. Watch the paper as it feeds through and try to determine where the jam is occurring.
  5. Check to see if all the rollers are turning.
    If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
    If not, there is probably a feed motor or a gear problem and the printer may require service.
  6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
  7. Turn the printer off.
  8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
  9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Posted on Jul 16, 2008
  • 4 Answers
SOURCE: Epson Stylus CX8400 Paper Jam Error
I have the same exact problem of paper half torn removed but I can not see the other half anywhere. The printer has hardly worked for at the most six pages and now showing paper jam error. How do I fix it?
Posted on Aug 12, 2008
  • 199 Answers
SOURCE: Canon ip1800 will not feed paper...One side jams
canon has a friction feed system,
clear the paper path and check if there are any small paper peace,
clean the pickup roller by a waterized cloth,
proper set the paper guide and try print again.
Posted on Jun 25, 2009
pineworks
  • 4041 Answers
SOURCE: Starts to print but jams on left side.
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Mar 16, 2010
Lexmark s605 paper jamming
Sounds like an obstruction on the right hand side of the feed mechanism. All-in-ones are a pig to find these - I've had one HP almost completely stripped before I found a chad of plastic stuck in a corner. Nine times out of ten it's a torn corner of the first bit of paper to get chewed jammed in the feed slot.
Apr 06, 2012 | Lexmark Interact S605 All-in-One Color...
WILL FEED PLAIN WHITE PAPER BUT WILL NOT FEED PHOTO PAPER
Follow the steps:
•1
Turn on the printer and press the Paper Feed switch until the Auto Sheet Feeder indicator light turns on.
•2
Pull up on the paper sheet feeder on the top and back of the printer and slide out the paper support.
•3
Take a stack of no more than 10 pieces of photo paper and flatten the corners, if they are curled. Curled corners may cause jams within the printer.
•4
Place the paper in the paper sheet feeder with the printable side of the paper facing up. The printable side of photo paper is the shiny or whiter side of the paper.
•5
Print your documents as needed.
Paper Cassette :
•1
Switch on the printer and press the Paper Feed switch until the Cassette indicator light turns on.
•2
Pull on the cassette on the bottom of the printer to slide it out of the printer.
•3
Flatten the corners of a stack of no more than 10 sheets of photo paper if the corners are curled. The paper may become jammed in the printer if the corners are curled.
•4
Place the stack of paper in the cassette so the paper is touching the right side and the printing side of the paper is facing down. Adjust the plastic paper guides so they touch the paper. The paper stack guides help facilitate the paper moving into the printer.
•5
Slide the cassette back into the bottom of the printer. The printer is ready for printing.
Oct 20, 2010 | HP PSC 2355 All-In-One InkJet Printer
Printer pulls paper in from one corner
this problem occurs only when one side of the paper spooler is jammed and stuck. the spooler pulls the paper causing the paper to rotate inside the printer and getting stuck.
take professional help in clearing the jam and freeing up the spooler.
Mar 15, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Paper Jams in Right bottom corner
it must be a small piece of paper inside your paper tray...
you need to open your printer cover...
its easy,you just need a screwdriver...
believe me,its easy to do it....
Jan 06, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Ok i have a problem. my lexmark x6150 won't take in paper right. it only takes it in on the right side. what is wrong?
Did this start with a paper jam? There could be a piece of paper(ripped corner) binding up the wheel on the left side.
Nov 05, 2009 | Lexmark X6150 All-In-One InkJet Printer
It says it has a paper jam and where the jam is their is no door? on the screen it shows the paper jam where the words digitial are imprinted.
Are you pushing the grey button on the right side of the copier? Just around the right front corner of the front door. This button releases the right side door. Opening and closing this door also resets paper jams. This is also where a jam would most likely be located and right where the digital sign is.
Oct 22, 2009 | Sharp AL-1655CS Copier
Printer Jammed
If you unplug the machine when the printhead is out of the corner, you can shine a light in and see where the crumpled paper is, usually on the right side where the cleaning assembly is.
Aug 12, 2009 | Brother MFC-5840CN All-In-One InkJet...
Paper jam
Hi! In you case, you have to put not thick photo paper in your printer.
Mar 20, 2009 | Kodak EASYSHARE Printer Dock Thermal Photo
Paper Jams
most likely there is paper or something stuck in that corner
use a flash-light an carefully inspect the area
hope this helps
thanks for rating
Jan 09, 2008 | Canon PIXMA MP160 All-In-One InkJet...
62 people viewed this question
k24674
