Question about Dryers
Whirlpool Gold Ultimate II Dryer will not start. Worked one minute and not the next. Light comes on when door opened. I took the top and front panels off and the belt is intact. Any suggestions?
  • 986 Answers
This is probably the motor going bad. The sensors wont cause this to happen. The start switch either, replacing all the sensors in the world wont make the motor be good again. But their is something you can do to try and make the motor last a while longer,their isn't any holes to oil the dryer motor so you must make some,using a 1/8th inch drill bit make a hole in either end of the motor where the bearings are (taking care not to hit the shaft), then add some hi temp oil such as zoom-oil, (dont use WD-40) and work the motor free as you can by hand. If this frees up the motor it may go a while longer. Also oil the rollers and check the slides to make sure they are not pinching and stalling the motor. If the motor can't reach top speed it will get hot,overload and stop.
Posted on Sep 12, 2009
Hello, I have a duet whirlpool dryer thats about 2 to 3 yrs old and it wont come on. Ive checked all the wires with a ohm meter and everything checked good. when I open the door the inside light comes on....
I suspect the thermal fuse may be open which will cause the dryer to not start. It is located and accessed by removing the lower panel. The fuse is available at http://aplusapplianceparts.com/searchquick-submit.sc?keywords=3392519
and is easily replaced. There is a picture of the part at above link for easy identification. Use coupon code 1050 for a discount on your order!
Jan 02, 2011 | Whirlpool GEW9250 Electric Dryer
Whirlpool Ultimate Care II dryer trips breakers.
No way to know unless you do some checking. This video shows how to get into the machine: HERE
I have a repair manual that features the same basic style of dryer you may want to take a look through: HERE
Feb 14, 2010 | Dryers
Whirlpool electric dryer ultimate care II - Won't start
Hi, make sure the breakers haven't tripped, and the motor may have tripped on internal over load. If this happened, let it set and cool down for awhile to see if it will start. Also, check the small door switch to make sure a screw didn't come loose as the will cause it to do nothing. Please keep me posted and safety first. Sincerely,
Shastalaker7
Nov 27, 2009 | Dryers
I have a whirlpool gold ultimate II electric dryer and would like to know how to remove the front and side panels to remove the lint on the inside.
Hello, If the lint filter is under the flap at the top lift the flap up and remove the 2 screws. Slide a putty knife under the lip between the top and the front panel about 3 inches from each end and push in the clips holding the top down. Lift the top up and look inside the machine either side and remove the 2 screws you see. now lift the front panel off. you now have access to inside the dryer :) Hope this helps! Mike
Oct 30, 2009 | Whirlpool LGB6300 Gas Dryer
Door switch tab is broken so dryer does not stay in the on position whirlpool gold ultimate care II the tab switch that lets the dryer know it is on is broken, I have to tape it down but it only stays...
will need to replace actuator. door swich can be accessed through the top. Unplug first, pull screws under lint filter door and pull top toward you. top should release and flip back
Jul 17, 2009 | Dryers
Whirlpool Gold Ultimate Care II Electric Dryer
Hi, there sould be a two piece door catch. One piece on the door and another on the front panel that the door closes to. Look at the piece on the door. You will probably find it is bad. You can buy just that piece and change it. I hope this helps. If I can assist you further please let me know.
Thanks
Vic
May 13, 2009 | LG DLG2524 Gas Dryer
Washing machine starts by itself
going through to the next wash not na normal function, perhaps the machine is advancing to an extra rinse cycle?? this EXTRA RINSE will start after the normal wash is complete, i would check your dial settings perhaps some one has mistaknely switched extra rinse "ON". if htis os not tyhe case the n i would jave to blame a faulty timer mechanism and you would need to replace the timer
Feb 15, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
I need help in opening my Ultimate Care II washer's housing
two screws on top usually on front take out flip up top you will see two gold clips on each side.take a flat tip screw driver put them in slots and pop loose remove unplug spin switch and lean cabinet forward and slide off .leak could be coming from pump tilt back first look inder it have a paint can or coffe can or tilt it way back and look under it pump on motor is probably leaking then take off case
Sep 15, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool ultimate care II gold electric dryer
the top and the front has to come off
Feb 04, 2008 | LG DLG2524 Gas Dryer
Dryers Logo
115 people viewed this question
Top Dryers Experts
