Question about Whirlpool 24 in. DU1055XTP Built-in Dishwasher
Whirlpool dishwasher top spinner and top rack spinner is not putting out water or very little and not spinning. I have taken apart and cleaned everything including the sump / chopper, can't find any blockage in the tubes that deliver water from the pump to the spinners. Is the Pump or Motor done? how can that be it's less than 5 years old? Its a Whirlpool Quiet Partner I Model DU1055XTPQ3
  • Dave Stack Sep 15, 2009
    I found the fix myself. It turned out that the water inlet valve, which is a selenoid controled valve was plugged and needed to be replaced. The valve was not letting enough water to flow into the tub before the wash or rinse cycles. Not enough water for the pump to pump up to the top and rack spinners. It cost me `$53 for the part from a local appliance store. I could have got it for about ~$33 plus shipping online but I did not want to wait. Put the new Water Inlet valve in and it works like a charm. The way I figure it out was to run the dishwasher with the door slightly open by defeating the door latch sensor switch with a small flat blade screw driver. I could see that hardly any water flow was coming out of the water inlet and the wash cycle did not have enough water, to run right after the fill cycle stopped.
  • 423 Answers
First, confirm that the holes are not blocked on these arms. (I did not want to assume you have done this.)
Then check the impeller on top of the motor stem for being loose or worn/damaged - to rule the impeller out. If it is fine, then the motor is failing and too weak to drive the spray arms.
To answer your question, I think the answer is "They don't make them like they used too!"
Posted on Sep 12, 2009
  • Jeff Meyer Sep 15, 2009
    Stackable1,
    I am glad you are back up and runing.
    /jeff
Recently my dishwasher KUDSO1FLSS2 is not cleaning the top rack very well requiring multiple washings. Both the top spinner and mid rack spinner (under top rack) turn freely by hand but limited water...
If there afilter on the inlet hose it might need clening,if you have a partial blockage it will reduce the volume of water entering your appliance.Hope this helps.
May 14, 2011 | KitchenAid 24 in. KUDS01FLSS Built-In...
Whirlpool Gold Dishwasher - GU2700XTSB The top rack of the dishwasher is not cleaning. The bottom rack dishes clean fine. There are no clogs in either the bottom or top spinner arms, the plastic tube...
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
Dishwasher Residue and Film on Dishes
heatman101
Jan 20, 2011 | Whirlpool GU2700XTSB / GU2700XTSQ /...
Dishes on top rack don't get washed. Water
replace the wter conduit that runs up to the top and center spinner arms,after while these plastic conduit outlets get worn by water going thru them and leak past the o-rings installed on them
Apr 15, 2010 | Kenmore 24 in. 15689 Built-in Dishwasher
Clean on bottom rack but dirty on top
Clean the filter at the bottom of the tub. If it is dirty or clogged the water pressure may not be strong enough to spin the top arm. Make sure also the there is nothing blocking the holes of the spinner arm. If the filter and arm are clear then the pump may be failing.
Aug 13, 2009 | Whirlpool 24 in. DU1100XTP Built-in...
Top rack not cleaning, possibly spinner not spinning?
Try twirling the spinner by hand to see if it is binding. If it looks ok then there could be something plugging the water passage to the spinner. If you have access to a water hose you could run water into that verticle passage pipe and see if there is an obstruction. If so it can be taken apart for cleaning.
May 13, 2009 | GE GSS1800H Built-in Dishwasher
I have a Kenmore Ultra Wash Dishwasher and the 3rd level spinner broke off. I have a new one and now need to know how to replace it.
the manifold in the back of the dishwasher needs to come out. you can either pop it all the way out it only undo it halfway if your arm is small enough.. there are either 2 tension clips or 2 screws holding it to the top and back. if you undo the top of the manifold and pull it down you should be able to slide the new part in place. the plastic push pin goes on top of the manifold and the spinner goes on the other side. it may be a little difficlt to push the 2 together..
Mar 06, 2009 | Dishwashers
Whirlpool Dishwasher GU1100
ill asume that were talking about the upper most spray arm,maybe 5 inches across and mountsto thte top of the tub??? if this is so, the new spinner comes with a clip that closes together after placing in proper position, its a "push" style pin lock, so no tools are required, simply pushe the pinin from the borrom ofspinner through the top of manifold and pushe second ave of connecter down onto it , ther should be no problem with this
Jan 25, 2009 | Whirlpool GU1100XTLB / GU1100XTLQ /...
Need to install a new top spinner on the roof of our dishwasher
the medium sized plastic piece slides into the spinner and you put it upto the manifold. you have to remove the manifold so that you can push the smaller piece of plastic through the top of the manifold into the medium sized piece which would be holding the spinner up.
Dec 18, 2008 | Dishwashers
Dishes and Flatware Don't Get Clean
Check to see that the removable cup rack on the left is seated correctly. One of the support legs of this rack is located above center of the spinner. If this leg is sitting on the top of the spinner rather than the center cross member of the main rack, the spinner will not move after that rack has been loaded.
Also check that the spinner is free moving once the draw is fully loaded, some plates can sit low enough to obstruct the spinner.
Mar 20, 2008 | Fisher DD603FCSS Dishwasher
Whirlpool 24 in. DU1055XTP Built-in Dishwasher Logo
1,247 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
