Question about Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835)
HELP Hi i have a question now... I have a Belkin G Plus Mimo router sorta old out of date has no NAT option im trying to connect to friends on xbox doesnt work how to fix it
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 168 Answers
Go HERE
scroll down and find make and model of your router. click on it and follow directions; it will show you how to configure your router for different systems and programs. ^_^
Posted on Sep 12, 2009
Problem with NAT type for xbox live? I have a Belkin wireless G Plus Mimo router and i have strict Nat type when geting on XBL. Any way to make this open?
yup....you can login to the router setup page by typing 192.168.23.1 in internet explorer...
on the left side you will find an option called firewall....click on that..it ll prompt for the password..(password: leave ot blank and click submit)
go ahead and disable it...
also click on DMZ on the left side of router setup page and enable it for the IP address assigned to the XBOX...
also get into virtual servers on left side and open common gaming ports like,
port 80
port 88
port 3074
port 53
port 443
for both tcp and udp....
in addition to that you need to open ports suggested by XBOX vendor...
thats it, you are done with that....as you open ports for xbox in virtual servers
the particular ports for xbox gets bypassed from NAT...so you need not worry about NAT hereafter...
also make sure that the modem provided by the ISP is not NAT enabled...if so ask the ISP to Bridge the
modem,so that you would not face further issues with XBOX....
Apr 02, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Change NAT to open
maybe instead of nat, set you xbox as a DMZ host. This would be done on the router itself. It will allow the Xbox to bypass the firewall and nat on the router/gateway, and at the same time keep your computer safe.
Apr 16, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Belkin g plus mimo nat problem
Step 1 : Check the IP Addressof the Xbox And take a note of it
Step 2 : Open RSP By typing 192.168.2.1 on the Address bar of the internet explorer
Step 3 : On the left side Click Firewall
Step 4 : Leave the Password blank and click Submit
Step 5 : Disable it And Apply Changes
Step 6 : On the left side Under Firewall Click DMZ
Step 7 : Add the IP Address of the XboX in DMZ
Step 8 : Click Apply Changes
Step 9 : Restart the Router
Step 10 : Test the Connection
Apr 12, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Belkin G plus mimo
Hi never ever disable nat on your router as that is the one which gives ip address to computer , x-box etc. You can make your x-box live work by just opening some ports
1. open rsp by typing in 192.168.2.1
2. On the left hand side under firewall you"ll find virtual servers
3. Click on that --- You"ll find some fields then check on enable for 1,2,3(ie three rows)
4.Description - x-box for all three
5.Inbound Port: 88-88 ,connection type : udp ,private port : 88-88 for the first row
6. Inbound port : 3074-3074 , connection type : udp , private port : 3074-3074 for second row
7. Inbound Port : 3074-3074 ,connection type : tcp , private port : 3074-3074
8. As FOR the private ip address it is that of your x-box which you can find on the dash board of your x-box . Same for all three rows .
9. Best of luck And do rate me
Jan 31, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Belking g plus mimo 928995 NAT open help
when you solve the issue you have can I borrow a guru to help upgrade from my 2wire modem to my Linksys wireless Router?
Jan 25, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
I need to open the nat on my router for xbox live and dont know how
go into the router settings and look for uPnP and enable this it will then open the firewall for your xbox automatically
Sep 09, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Belkin g + mimo and xbox 360
are you typing the correct upper or lower case and not confusing zeros with the letter 'O'
Sep 02, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Playing eve
Under System Settings on the Router: Extend the time of the "Time Out" or inactivity under NAT or, if that option is not available, then turn NAT off.
Jul 23, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
How to change my NAT
You need to check first if your router is Xbox Live compatible (all routers will work, but only certain ones will allow an open NAT):
http://www.xbox.com/en-us/support/connecttolive/xbox360/homenetworking/equipment.htm
If your router IS on the list, make sure you have a compatible firmware version (usually the firmware version is written on the router somewhere). If you do not have the proper firmware, you will need to downgrade your firmware (reply to me for instructions on this).
If your router is not on the list, you're outta luck.
May 21, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Nat settings
try going to http://192.168.1.1 default user name and password is admin for both. go to your wireless security and set up security as xbox allows. i think i set mine up with wpa and all i had to do was put the code into the xbox settings after the router page generated an encrypted key sequence.
Nov 13, 2007 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835) Logo
65 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
