Question about Dishwashers
Water is not draining from the hot point dish washer:it collects in the little hole inside in the rear of the compartment
  • a_levasta Sep 12, 2009
    I am a kind of do it yourselfer and my common sense told me that it must be a blockage because I dont see foam coming from the drainage hose connected to the garbage disposal and the disposal is working.
  • 10,865 Answers
When the dishwasher doesnt drain you must remove the lower front panel. then remove the drain hose and check for a blockage. if none there dis connect the pump [ which is what the hose is connected to and look it in. finally check the drain under the sink and the garbage disposal if you have one.
chances are you will find a blockage. if you don't get back as there are other rare but possible causes.
Posted on Sep 12, 2009
I have two questions regarding my washer. Q1) What do you think the problem is when the water selection is on cold only, or warm and cold, or the hot and cold, barely any water gets inside the washer even...
chnage the water valve for the water problem and if it doesn't drain you could have a bad lid switch or something going on with the pump,something could be stuck in it or it's bad.open and close the lid down if you don't hear a clicking sound it's broke or stick a screw driver into the hole that the lid switch closes into,keep the washer in spin and see if it drains when you push the screw driver down in the hole
Feb 22, 2011 | Kenmore 15864/15862 Top Load Washer
Water leaking inside
Hi,Open the freezer compartment, unsrew the two nuts. pour a little warm water to defrost the bult up ice on the freezer compartment. At the estreem end, a shining drain pan might full of iced remove the ice at the center of the pan you will see a hole blocked with ice, pour hot water on it till all melted away. open the back of your refrigeration there is a water drain hole, around the left hand corner. see if the hot water driping off. this resolve the problem.
Thanks and Good luck
Jun 04, 2010 | Maytag MTB2176 Top Freezer Refrigerator
I have a 1 1/2 year old fridge, I'm getting a
yes the drain plug hole is blocked.get two pipe cleaners and screw them togather and plunge them down the drain hole to unblock..adrian;;;
Nov 14, 2009 | Refrigerators
Water is driping from the upper rear vent inside the fridge collecting under the drawers and driping out the front
Remove the food from the freezer and remove the rear panel (inside freezer) . If you have an icemaker , it too , needs removed . After removing the panel , use a hair dryer to defrost the drain , below the coils , until you see the drain hole . Then concentrate on defrosting the hole until water flows into and out of it . Sometimes hot water helps in the defrosting process . After the hole is cleared , use a hose inserted into the drain and blow thru it to clear any debris collected in the line . Get a piece of ALUMINUM wire (14-16 guage ) about 8 " long and insert one end into the drain hole as far as it will go without any force . May have to bend it slightly to get it to go farther . Wrap the other end about 1-11/2 turns around the black rod (heating element) and discard the rest of the wire . When thr fridge goes into defrost , heat will transfer to the aluminum wire , keeping the drain hole from iceing up again . reassemble freezer .
Aug 25, 2009 | Whirlpool Refrigerators
GE REFRIGERATOR SPILLS OUT WATER COLLECTED BELOW VEG. BINS, HEAVY CONDENSATION ON WALLS OF REFRIG. CANT FIND A DRAIN HOLE AT BASE OF FREEZER OR FRIG.
Remove the food from the freezer . Remove the rear freezer panel , inside the freezer . At the base in the rear , use a hair dryer and defrost (you'll see a drain hole possibly in the middle of the drain ) . Defrost drain hole until hot water can be poured and go thru the hole . I use a small hose to blow thru the drain hole to remove any debris which could have accumulated inside the drain line .
Aug 02, 2009 | GE Refrigerators
The refrigerator is dripping water at the bottom of the fridge. Everyday we walk by the fridge and see lots of water dripping from the fridge.
Hi, The defrost drain is plugged. Remove the rear panel inside the freezer section and locate the drain hole. Remove all the ice and flush the drain out with hot water to make sure it is open. Some models require an after market drain heater kit. If you will get me a model 3, I can look this up and let you know if you need the kit.
Vic
Jul 04, 2009 | Refrigerators
Water collects on shelves in refrig.
sounds like a drain clog in the freezer compartment above. remove the freezer rear panel and totally defrost the evaporator area, directly under the evap you see( under all taht ice) a small drain hole that has become frozen over, try defrosting with either a hair dryer( not a heat gun too much heat youl melt everything) or by pouring hot water donw the drain until you get a free flow of water down the tube. after its clear reassemble and you should be fine
Nov 26, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Water leaking inside refrigerator
If water leaks inside your refrigerator
(and it WILL, at some point) you can fix
it yourself. My 26 year old fridge was leaking
and I fixed it completely. It is a Kenmore
top freezer, bottom refrigerator model.
In the good old models, one had to defrost the
fridge every few months manually.
In the recent models, the fridge defrosts automatically,
once or twice a day, and the water is supposed to drain
down a long drain tube into a pan located at the bottom of
the fridge. This collected water in the pan evaporates
by the heat under the fridge.
Now the drain tube can get clogged, by food debris and/or
ice. Thus when the water cannot drip through the drain tube
the water drips inside the fridge.
The drain tube is located behind the fridge, which is pretty
easy to take it out and clean. However usually the clog is
not in the long tube but in the connector assembly located
in the backside of the fridge that leads to the long drain tube.
To get to the connector assemble, you need to unscrew and
take out the back panel of the freezer compartment. You would
see the evaporator coil and a tray under the coil where the water
is supposed to drip through. If you find the tray completely frozen
with ice, let it melt off. To speed up melting, you may blow
hot air via a hair dryer. Once the ice is clear, you should see
a drain hole in the middle of the tray. This could be clogged,
which needs to be unclogged.
Next unscrew and open the thermostat control assembly located
in the inside of the back of the refrigerator compartment just above
the light bulb fixture. Once you take the take the cover off (you will
also have to take the knobs out) you will see a small tray cup about
2" x 2" x 1/2" into which water from the top freezer compartment
drain hole is supposed to drain. Pull out the tray cup, and if clogged,
unclog it, clean it and put it back.
To check if the drain works ok, pour some water on the tray
under the evaporator coil (top freezer compartment) and see if it
immediately drains into the tray located at the bottom of the fridge
at the floor level. If it does, you got it; and you can assemble things
back in the reverse order you took the pieces apart.
Needless to say, use a vacuum cleaner with a long suction tube to clean
out all the collected mess under the fridge. No matter how good
your housekeeping is, the bottom of the fridge will be full of dust.
With lot of patience (I mean lots of it) you should be saving hundreds of dollars.
If you still have problems e-mail me at walkhill@cox.net
May 31, 2007 | Kenmore 18.3 cu. ft. Top Freezer...
Front load washing machine
There's usually a little drain hole tucked away out of sight at the lowest point of the gusset between the inner and outer seals. Before you try anything else, suggest you check this hasn't got blocked with wet lint (the place I'm trying to describe is the bit that's filling up with manky water). A.
Mar 28, 2007 | Frigidaire GLTF2940ES Front Load Washer
Water draining is premature
In my case, I had the same problem until I realized the drain hose was not looped high enough. Once I looped the drain hose higher than the dishwasher, the problem went away and it washes dishes perfectly.
When the drain hose is installed too low, the water in the machine will only stay as high as the hose is installed because of the laws of physics.
The same applies to laundry machines - that is why the drain hose is set to drain from a higher point than the drum of the washer.
Good luck and Blessings!
Apr 26, 2017 | Kenmore 17252 Free-standing Dishwasher
Dishwashers Logo
12 people viewed this question
Top Dishwashers Experts
Owen Barnes
