Question about Netopia 2247NWG-VGx Wireless Router (2247NWGVGX)
I cant find my driver for my netopia 2247nwg wireless router.
    Sergeant:
  • 168 Answers
You don't need a driver for the router. If you go to the netopia website, they will have directions to allow you to get into the box through your browser with step by step instructions. An alternative is to call your DSL provider. Their tech support should be able to walk you through all the steps. I hope that helps.
Posted on Sep 12, 2009
JRSavage
  • 15 Answers
SOURCE: how can i unlock my router?
Ratrideen,
I'm not entirely sure what you are saying the problem is. Is it that you can't access the Internet from your PC once the netopia router is hooked up? If this is the case check your IP setting on the PC. The following documentation from the Netopia site should help.
Good luck.
J
http://www.netopia.com/support/hardware/2247w.html
Posted on Feb 13, 2008
  • 58 Answers
SOURCE: How can i unlock netopia 2247NWG
Firstly... avoid showing your SSID (eircom-123456789) here, as the WEP key can be reverse engineered from the SSID.
To change your SSID, connect your router to your PC with an ethernet cable, go to your web browser (Intenet Explorer, Forefox, etc) and type 192.168.1.254, and press return.
This will open the control panel for the router.
Select 'EXPERT MODE' from the menu on the right, and accept the warning prompt. Then click on 'CONNECTION' and the 'WIRELESS' on the menu on the right.
In the main window you can then change the SSID for your network.
You can also change some of the other options in this window such as enabling closed mode, change security protocol, password, etc.
Posted on May 10, 2008
  • 58 Answers
SOURCE: wlan key for netopia 2247NWG-VGX WIRELESS ROUTER
Select 'EXPERT MODE' from the menu on the right, and accept the warning prompt. Then click on 'CONNECTION' and then 'WIRELESS' on the menu on the right.
In the main window you can then change the SSID, WEP/WPA key for your network.
SOURCE: How do you hook up a Netopia 2247NWG-VGx Wireless
HI! I bliv u are having some issue setting up ur router.. I will be more than glad to assist u. . here are the steps u need to do:
1. press the reset button on the back of the router for 20sec..while pressing the reset button, unplug the power plug and after 2secs while pressing the reset button plug it back in and press for 30secs after that unplug the router for 15secs then plug it back in..once all the lights are solid and ok
2. connect the ethernet cable to port1 of the router and the other end to the lan port of your computer..
3. pull up ur browser then type at the url:192.168.1.1.or 192.168.0.1 or u can check the routers default gateway by right clicking the network icon on the lower right of your task bar and click on status and it will show the ip address of the computer, subnetmask and default gateway, the default gateway is the routers ip address, once u type in to the url, it will ask u the username and password, by default the username is admin and the password is 1234 or just leave it blank
4. it will show the setup page of the router. u can set the router on the specific internet setup that u have.
a. if ur isp is a cable company, normaly u need to do a mac clone on the router setup page by cloning the computer that is reg to the cable company, how to determine it. ex. the computer that is reg to the cable company is a desktop or laptop, if this computer is connected to the modem directly and u can access internet.
b. once u determined it u need to connect this computer directly to the router and do a mac clone and set ur internet settings to auto-dhcp..then save the settings and after that, unplug to the power of the modem and router, plug in 1st the power of the modem then once all lights lit, plug in the router, then once all lights lit, try to pull up a browser that ur computer is connected directly to the router.. ur cable connection shud be, cable from the modem will go to the WAN port of the router and connect ethernet cable on port1 going to the lan port of the computer..once u can access the internet, u can now access again the setup page of the router by typing at the url:192.168.1.1 and u can setup the wireless settings, u need to create a ssid or wireless name and a security..
5. If ur isp is a dsl normaly they give u a username and password to connect to the internet, ur settings on the router should be PPPoe
6. If ur isp gives u a static ip address settings, u need to set the router to isp setup.
a. how to check the isp of the isp given to u..
1. click on start
2. run
3. type cmd
4. it will show a dos prompt
5. from the dos prompt type ipconfig/all
6. it will list the ip address, subnet, default gateway, dns server
this settings should be type in to the settings on the router for static ip addressing..
7. Once your done on the innternet setting, go to your wireless connection settings and you can create a wireless network name or ssid, set a security by selecting wep, wpa, wpa2.
8. once all is set. save the settings and to check if your laptop can access the wireless network that you did, turn on the wireless switch of your laptop, once its on, it will show the wireless network icon on the lower right of the taskbar, right click it and select on view available network, the network name that u did should list, just select it and connect and it will ask for the password, just type the password and connect, you should be connected to the wireless network and have internet access..
9. If you are going to hook up your desktop to the wireless connection, you need to install a wireless network adapter, install the driver and do the same thing as u did to the laptop, for the desktop no need of turning on the wireless switch, once you install the driver correctly, it will show a network icon..
if you have any querry pls feel free to get in touch.. good luck
Posted on Sep 03, 2009
Evan_royer26
  • 60 Answers
SOURCE: how do i turn off the wireless on my netopia
Type 192.168.1.254 Enter your password default Username-Admin Pass-Admin
Once in there find your wireless setting and turn it off. I personally do not have a netopia router but these are the usual steps, if you have any problems comment back and i will be glad to help.
Posted on Mar 20, 2010
Testimonial: "That worked. Thanks for your help."
HOW TO FORWARD PORTS 8090 AND 37766 TO SPECIFIC IP ADDRESS
Go to this web site and follow the instructions.
These instructions are specifically for your router and a host of different apps you can forward the ports for
http://portforward.com/english/routers/port_forwarding/Netopia/2247NWG-VGx/2247NWG-VGxindex.htm
Jan 18, 2011 | Netopia 2247NWG-VGx Wireless Router...
I need the dns server address for netopia 2247nwg-eir
Connect pc to the the router using ethernet cable. Go to "Run". Type "cmd" (command prompt). In the command prompt, type ipconfig /all then enter. On this point, information in your connection will seen. see picture below.
Mar 28, 2010 | Netopia 2247NWG-VGx Wireless Router...
How do i turn off the wireless on my netopia 2247nwg router
Mar 20, 2010 | Netopia 2247NWG-VGx Wireless Router...
Ps3 setting up static nat
are you in ireland and with eircom?
Feb 19, 2009 | Netopia 2247NWG-VGx Wireless Router...
Xbox live
your xbox should work using your netopia but you need to setup some settings. click here on how to.
hope this'll help you
ciao
Sep 28, 2008 | Netopia 2247NWG-VGx Wireless Router...
Xboxlive on netopia 2247nwg
Have you tried http://portforward.com/ i've had alot of problems with this router fixed my xboxlive issues with portfoward but am having problems with my blueface voip
Feb 26, 2008 | Netopia 2247NWG-VGx Wireless Router...
Netopia 2247NWG-VGx Wireless Router (2247NWGVGX) Logo
277 people viewed this question
Top Netopia Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Netopia Computer and Internet Expert? Answer questions, earn points and help others
