Question about Sakar Talking Caller-ID Speaker Phone
Sakar Telephone Problem
Removed what appears to be a brand new Sakar telephone from deceased
brothers house. Installed 4 AA batteries and charged over 24 hours.
Could never get dial tone and eventually notice when I plugged the Sakar
telephone line into the outlet it disabled the other two telephones I have in
the house.
What can I do to be able to use the telephone. There is no model number
and the unit was made in China.
  • 684 Answers
This Telephone doesnt have a capability to work with shared connections where u use more than one phone in one connection.......... And this phone cannot be charged it works in either battery or Adapter...... Good Luck......
Posted on Jan 19, 2009
Phone ring tone in house cannot hear it do not know house to fix as instructions are in greek
must be sure handset ringer volume is NOT set TO off
2) THE Telephone line cord and power adapter are plugged in properly.
3)the handset may be too far from the telephone base. Move it close to the telephone base.
4) many extension phone on the telephone line to allow all of them to ring simultaneously.
5) if other telephones in your home are having the same problem , the problem will e in service provider
6) other electronic products such as HAM radio detect the phones cause interferences.
7)test a working phone at the wall jack.
8)remove and install the battery again and place the handset in the telephone base
9) wait for the handset to synchronize.
God bless you
Sep 27, 2012 | Lands Phones
Today I purchased an EMERSON telephone, Model # EM2646WH and the LCD display will not light up. I have installed 3 AA batteries.
A. Hi, check the installed 3 AA batteries are in the right polarity.
B. Get new batteries, not cheap ones. Rechargeables have less voltage than normal ones.
C. Confirm you read the manual, and are starting it correctly, they are different from mobile phones.
D. Back to store.
thanks
Feb 17, 2011 | Cell Phones
Am trying to send a fax on brother 575. I placed the paper face down -- dialed the telephone number and pressed fax start. The receive messages comes up on my machine and the fax does not go...
My first assumption would be, since this appears to be a new fax machine for you, to ensure that the telephone line is plugged into the correct port on the fax machine. There are usually two ports, a telephone port and a line port, you want the telephone line to be plugged into the "line" port.
Let me know.
-David.
Nov 05, 2010 | Brother Office Equipment & Supplies
What does comm error 20 01 mean on my brother 2820 mean? how do I fix it?
This means that your Brother machine experienced a communications error when sending or receiving a FAX. This is generally caused by either interference on the line, phone line connection or another device on the line.
Try resending the documents and see if the message no longer appears.
If the message still appears, there may be a problem with the way the Brother machine is connected or you may have a bad telephone line. Disconnect any other equipment on the telephone line, i.e. answering machine, modem, extra telephones, switching devices, adapters, etc. Make sure the telephone line is connected directly from the jack (socket) on the Brother machine labeled "Line" to the telephone wall jack (socket).
Try resending again. If the transmission is successful, the problem was created by the connection of the Brother machine and the other devices on the line. Reconnect the other pieces of equipment one at a time to see which is causing the problem. If the error continues to appear on the report, try connecting the Brother machine to a different telephone line or have the line checked by the telephone company.
Nov 03, 2010 | Brother IntelliFax-2820 Laser Fax
I am recieving a comm.error when faxingit also shows memory full when the page prints
Hi
You usually get a Comm error due to poor performance of your phone line. Check for any visible issues with the phone line. Check whether the jack is plugged in properly and the wire is not cut.
If you are sharing the phone line then check that any other devices are not interferrring in device's performance. Disconnect any other equipment on the telephone line, i.e. answering machine, modem, extra telephones, switching devices, adapters, etc. Make sure the telephone line is connected directly from the jack (socket) on the Brother machine labeled "Line" to the telephone wall jack (socket).
There may be a problem with the way the Brother machine is connected or you may have a bad telephone line. Try resending again. If the transmission is successful, the problem was created by the connection of the Brother machine and the other devices on the line. Reconnect the other pieces of equipment one at a time to see which is causing the problem. If the error continues to appear on the report, try connecting the Brother machine to a different telephone line or have the line checked by the telephone company.
Daniel Scott
Jun 26, 2010 | Brother MFC-8460N All-In-One Printer
When i turn on my camera it will not extend or let me set the men
Check batery type suitble for your camera, also ensure correctly installed(+ -) Check contacts are clean
Sep 24, 2009 | Fuji FinePix A360 Digital Camera
My printer/scanner/copier brand brother not working now. i want to make reapir it want to use. please let me know the service centre in kuwait.
I found these details at the global brother website.
It appears to be an agent for brother products in Kuwait.
INTEGRATED OFFICES CO.
P.O.box 29709,SAFAT
Kuwait
Contact: OMAR SABBAH
Telephone: 009652463296/297
Hope this info helps you.
Regards,
Graemevm
Apr 22, 2009 | Office Equipment & Supplies
Sakar talking telephone
In this case just remove the battery and the connections and keep the phone idol for about 15-20 Min and after that replug it in and it will not do that again.... Good Luck..........
Aug 10, 2008 | Sakar Talking Caller-ID Speaker Phone
Durabrand telephone
the issue is that sakar phone does not support the option. you will hear a beep noise when you have a call waiting. they do not support to get you the number of who is calling..
Jan 15, 2008 | Sakar Talking Caller-ID Speaker Phone
Sakar amplifired caller id telephone
sakar wont give a refund.,.. only option is a replacement.. nothing else they support. if not contact the store for a refund..
Nov 03, 2007 | Sakar Talking Caller-ID Speaker Phone
Sakar Talking Caller-ID Speaker Phone Logo
179 people viewed this question
Top Sakar Lands Phones Experts
Marvin
Marvin
David Burbee
David Burbee
Are you a Sakar Lands Phone Expert? Answer questions, earn points and help others
