Question about Kenmore Washing Machines
Water coming out from the bottom of washing machine
    President:
  • 2,187 Answers
Have the unit panel taken of to see where the source of the water comes from. It could come from a leak or the water overflows or is not draining. Check for leaks in the valves or hose, as you inspect where the water comes from. To check if it is not draining see after wash if the water drains while the panel is taken off. IT could be caused by the water level sensor (usually a floating device on the tray) may have been dislocated or needs replacement or a faulty water pump.
Posted on Sep 12, 2009
  • 25 Answers
SOURCE: Amana washing machine
prob faulty door seal or iff really bad hole in outer tub
Posted on Jul 03, 2008
jtate9
  • 68 Answers
SOURCE: Maytag MAV2755AWW Washing Machine is leaking water
It sounds like you have a leaking pump. The pump is easy to replace:
#1 Use a shop vac and pull all the water out of the drain line. This will keep you from having to clean up about 1 gallon of water off of the floor.
#2 Lift the front of the machine enough for you to get under and see.the pump just inside the front of the washer.
#3 Lift the 2 retaining clips off of the pump. This will allow you to pull the pump off of the motor.
#4 Remove the 2 clamps off of the hoses.
#5 Install the new pump into the hoses, and reinstall the clamps.
#6 With the retaining clips installed into the motor housing, install the pump.
#7 Attach the retaining clips, and set the washer back on the ground.
You have now replaced the washer pump.
If you have any questions, let me know
Please rate this solution
Posted on Jul 29, 2008
SOURCE: There is water draining from underneath the machine?
I have the same unit, I had to replace my drain pump and clean the entire machine out. THis unit has many design flaws however once they are corrected with new parts it is a good machine.
Posted on Mar 07, 2009
  • 132 Answers
SOURCE: washing machine water comming out from bottom
Check the hose that connects from the tub to the water pump. Next time you do a load remove the front panel and set the machine for a "small load" so there won't be alot of water. When the machine begins to agitate shut off the timer and move it to the final spin mode and turn it on. Here is where you want to watch that hose (maybe with a flashlight) as the tub begins to spin and the water is being pumped out, focus on where the hose connects to the drum. Usually as the spin increases the vibration will cause the hose connection to become loose and water will start spitting out. If you don't see any leaks in the hose, check the water pump itself. NOTE: DO NOT PUT YOUR HANDS IN THE MACHINE WHILE IT IS IN OPERATION! JUST LOOK IN AT THE HOSE, DO NOT TOUCH ANYTHING AND KEEP YOUR HAND BEHIND YOUR BACK! THE OTHER HAND ON A FLASHLIGHT FROM OUTSIDE THE MACHINE.
Posted on Mar 26, 2009
  • 155 Answers
SOURCE: There is a leak at the bottom of the washing
The leak is from the drain hoses or the fill pipes.
No need to worry.It's a common issue and easy
to fix of your own.
Posted on Sep 01, 2009
Water doesn't come out through the bottom of the machine. It comes out only through the tools. I have turned the dial but it still doesn't come out the bottom. What is the problem?
Dear David,
You gotta help me out here!
I have never seen a washing machine with tools, unless some children put them in there in their playing.
And, all the washers I've seen, you do not want the water to run out of the bottom of the machine, it will flood your laundry room floor!
Dec 18, 2017 | Washing Machines
I have Beco WM616 7W washing machine...when I start washing...water should filled in washing machine but it comes out from somewere..all programms working...just water comes from bottom..
Check all your hose connections. Sounds as if the drain hose has come loose or burst. (common fault in all machines).
Open soap drawer, and check that water is flowing into it.
If no water is flowing into it, looks like the water connection hose at rear is not secure.
If water is flowing into the drawer, but not staying in the drum, then check the drainage outlet hose is secure and undamaged.
Jan 21, 2013 | Washing Machines
HL04932940 27" FRONT LOAD WHIRLPOOL HE WASHING MACHINE LEAKING WATER FROM BOTTOM
First check is the standpipe drain. The hose that comes from washer should not be inserted more than 4". More than that can cause a syphoning situation that can cause leaks from beneath. If that seems okay you will have to see where water is coming from by observing the machine in action with back or bottom service panel removed (if it has one.)
Jan 06, 2013 | Whirlpool LHW0050PQ Front Load Washer
Water coming out of the bottom of the machine
Sometimes, what may seem like a washing machine leaking from bottom locations is actually one that leaks slowly from other spots. Slow leaks can accumulate beneath your washing machine making it seem like you have a bottom leak. For more help identifying the exact point of the leak, see Washing machine leaking.
Bottom leaks may be better identified using a newspaper. Just dry the floor and lay the newspaper beneath the washing machine before you test for leaks. Darkened sections map out your water leak. This method is not always foolproof, however. The best diagnosis will come from a qualified service professional inspecting your machine.
If your washing machine is leaking from bottom in the rear, you may need a replacement pump and professional installation. The leak could also be caused by a faulty air dome seal or a hole in the tub. For more troubleshooting steps to tackle that leak, see Washing machine leaking from bottom. I hope that helps!
Sep 27, 2012 | KitchenAid KHWS01PMT Front Load Washer
I have to drain my washing machine through a front hole drain opening in the bottom corner of machine. Water comes out, it has been left in machine. I drain my machine every six loads. WHY did Bosch design...
you have a blockage some where in the drain hose.most likely in the hose the comes form the bottom of the tub to the pump.you attach a wet dry shop vac to the end of the drain hose and remove the water this way while the vaccum is working look at the hose that comes form the tub to the pump and if it colapses then there is something restricting the water flow.also make sure to check in side the drain pump cover for any thing that is obstructing the pump
Feb 23, 2010 | Bosch Axxis WFL 2060 Front Load Washer
My speed queen top loader is leaking water during the washing period. Water is coming out of the bottom of the washing machine while it is washing
It is probably the pump. Run the washer with the front off of it. The pump is on the bottom of the motor.
Easy repair.
Nov 08, 2009 | Speed Queen AWS52NW Top Load Washer
Water leaking from the bottom of the machine
Some times there my be minor loose and also check at hose which is connected to wash tub meant for switchin washin machine
Oct 03, 2009 | Fisher Paykel EcoSmart GWL15
Maytag top load washing machine leaking water from bottom
The machine is leaking water from the bottom, I think the leak is in the area near where the motor is mounted. Before we noticed the water comes from underneath the washer, we smelled like burning rubber.
Al Bana
Jun 26, 2009 | Maytag PAV2300 Top Load Washer
Jul 02, 2008 | Amana Washing Machines
Washing Machines Logo
69 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
