Question about IBM Office Equipment & Supplies
Ibm selectric will not backspace - IBM Office Equipment & Supplies
  • IBM Master
  • 3,594 Answers
Probably needs a tab tensioner on the R. side. You probably need a tech.
DickyO
Posted on Sep 14, 2009
I have an IBM Selectric 11 Typewriter that will not backspace. Can you please help? tks
If it moves a little but not enough the tab tensioiner on the R. side is broken not a bad job but yuo must know how.
DickyO
Oct 30, 2012 | IBM Office Equipment & Supplies
IBM selectric II carriage stuck in right margin
There is a thin metal ribbon in the back that has come off the wheel. It is a devel of a thing to get back on.
Remove the cover and watch ... you will see what I am talking about.
It may have come un-attached ... equally difficult to fix without the little thingie the typewirter mechanic uses.
good luck
Oct 14, 2009 | Office Equipment & Supplies
My IBM selectric II typewriter carriage stuck in right margin
Sounds like the return lever arm is not putting enough pressure on the return clutch, or the clutch is slipping. The exp key uses the same clutch but the pressure comes from your finger. Theres no way you can fix this yourself. Get an IBM mechanic.
Oct 14, 2009 | Lexmark Wheelwriter 15 Series II...
I have an IBM Selectric II. It types but does
The tab tensioner on the R. side is probably broken, not a bad job but you have to know how.
DickyO
Sep 12, 2009 | IBM Office Equipment & Supplies
IBM Selectric II typewriter stuck in correcting position
If you know how to remove the right dust cover (black inside the T/W below the carrier) next to the R. side frame is the correction set up mech. spray some WD40 on the arms especially where they pivot, they should free up.
DickyO
Jul 02, 2009 | IBM Wheelwriter 30 Typewriter
On the IBM selectric 2 - the keys are locked up -
Try the shift key, then try pressing each key on the key board one may be partially tripped.
DickyO
May 07, 2009 | IBM Wheelwriter 30 Typewriter
IBM Correcting Selectric II backspace not working
The tab tensioner is probably broken you need a tech.
DickyO
Mar 17, 2009 | IBM Wheelwriter 30 Typewriter
IBM Correcting Selectric III backspace not working.
Since it hasn't been used in quite a while the lubrication in the machine has become gummy & sticky. The cam that operates the backspace is being activated, but the arm that drives the backspace mechanism isn't being pulled on.
Machine needs a deep cleaning and oiling and then readjusting to correct this problem. (Don't spray WD-40 in it...makes it worse !)
(This repair is usually beyond what a non-technician can do.)
Jan 17, 2009 | IBM Wheelwriter 30 Typewriter
Correcting IBM Selectric II Typewritter correcton ribbon won't engage
Selectric I and II type elements are identical (88 char) where Selectric III uses a different element (96 char). The 88 character element will have white lettering and the 96 character element will have yellow. Directly underneath the lift-up tab to remove the element will be a 3-digit number. That's the last 3 digits of the element's part number, which will be preceeded by 1167 for 88 character, or 1352 or 96 character. For example, if you have a '052" stamped on the element, and it's an 88 character style, the P/N will be 1167052.
The correcting mechanism is an intricate additional function of the backspace function. To test it/adjust it/or repair it requires the machine be hand-cycled using a hand cycle wheel which is screwed into the right hand side operational shaft. It's unlikely that an un-trained party would be successful repairing this..
May 15, 2008 | IBM Wheelwriter 30 Typewriter
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
jasbo
jasbo
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
