Question about Husqvarna 450 e-series 18" Chain Saw
I need to take the clutch off to get the the spraket what tool do i need to take it off tried allen wrenches nothing I have workes
  • 123 Answers
The clutch on a saw is a left hand thread. It turns to the right to loosen it. To the left to tighten it.
Posted on Sep 12, 2009
I need to adjust my clutch cable on a 1994 1200 sportster harley,wont fully engage and hold bike while it is in gear
That is not a difficult task. There is an adjustment on the cable at the front of the frame. This adjustment should be loosened up and the derby cover removed. After removing the derby cover (that is on the Primary on left side of bike) there is an adjustment screw on the clutch. It takes a allen wrench (dont remmember size) and an 11/16 wrench. Loosen the lock nut with the wrench and screw in the allen in about three turns. Then pull clutch lever all the way in and leave it there. Take the allen wrench and turn out the screw while watching the clutch lever when the lever comes all the way out and the screw tightens then turn it back in 1/2 of a turn and hold it with the allen wrench in that position while tightening the lock nut with the wrench. Then go to the cluctch lever and hold the cable tight looking at the gap between the end of the cable and the clutch lever housing there should only be 1/16 to 1/8 inch play there if there is more or less then adjust the cable at the cable adjustment on the front of frame of bike till you get that spec. A quick way to check the cable is use a nickel if it fits tight it is right. I hope this helps you.
Dec 06, 2010 | Harley Davidson XL 1200 C Sportster Custom...
How do I change the keyless chuck on a cordless drill/
Remove the REVERSE-THREAD screw at the bottom of the chuck. Set the clutch collar to the highest setting, and set the gear to the slowest setting if this drill has a 2 speed transmission. Remove the battery! I have performed this with the battery in back in my noob days, and getting an allen wrench in your rib because you accidently hit the trigger will only happen once. You will never forget that experience. Get the biggest allen wrench you can fit in the end of the chuck(the shortest leg) and tighten the chuck down around it, allowing the jaws to rest and tighten on the flats of the wrench. Lay the drill on its side(chuck toward you, handle to the left, and allen wrench to the left, horizontal to the deck. Then with a hammer(soft hammer if you care about the allen wrench) quickly and deliberately hit the allen wrench in an attempt to cause the allen wrench to spin counter clockwise. You have only a few to several attempts at this before you risk damaging the clutch, so make the first one count. Follow through like you are attempting to hit something 6" below the allen wrench. If this does not do the trick before you shell the clutch/gearbox, you are looking at an expensive undertaking, most likely a new drill. I have only shelled 2 clutches out of literally tens of thousands of chuck repairs, so don't worry, just be aware. Let me know how it goes!
Nov 23, 2010 | Black & Decker 18V Cordless Drill/Driver
How do I remove the chuck from the drill. I have removed the star screw and have tried to turn the chuck counter clockwise to remove the head.
Remove the REVERSE-THREAD screw at the bottom of the chuck. Set the clutch collar to the highest setting, and set the gear to the slowest setting on the transmission. Remove the power source! Get the biggest allen wrench you can fit in the end of the chuck(the shortest leg) and tighten the chuck down around it, allowing the jaws to rest and tighten on the flats of the wrench. Lay the drill on its side(chuck toward you, handle to the left, and allen wrench to the left, horizontal to the deck. Then with a hammer(soft hammer if you care about the allen wrench) quickly and deliberately hit the allen wrench in an attempt to cause the allen wrench to spin counter clockwise. Let me know if this works for you!
Sep 22, 2010 | Bosch PS312A 12Volt Max 38Inch DrillDriver
How to remove the chuck from a dewalt cordless hammer drill?
Sep 19, 2010 | Dewalt DC925B Heavy Duty Xrp 18V Cordless...
Trying to disassemble Ladylux Cafe faucet. Grohe
If it is just replacing the handle you will only need a smaller screwdriver set (pretty common) and an allen wrench. I don't know exactly what size you need but you can get a set of these wrenches pretty cheap at any tool or hardware store. Basically the tool is a hexagonal rod that is bent in the shape of an "L". You'll need the smaller set for this job sold usually in sets that have a range of sizes from .05" to 3/8" diameter. I would guess your hex nut is 1/8" or less.
On the bottom of the handle between the sink bed and the handle you'll be able to feel a small hole. When you stick the allen wrench in there it should fit snuggly if the allen wrench wiggles a lot go to the next size up. Since the screw is facing up you will pull the other end of the wrench toward you. This will loosen the screw. It will not take a lot of effort so if you have to force it make sure the allen wrench is actually seated. Kind of a pain but you'll have to reposition the wrench as you get it loosened to fully extract the screw.
Once the screw is out the handle will drop down and the cap just pulls off. Assembly is reverse but make sure that your screw is going into the threads without resistance before tightening. This will prevent cross threading.
Feb 15, 2010 | Grohe Model 28 206 OOO: Ladylux Plus...
How to r4elease the brake once the plate is off the saw to replace the chain?
A model and serial would have been helpful, Reset Chain Brake by Dolfoff
Please follow this link, http://www.fixya.com/support/t3102817-re_install_side_cover_after_chain
Cursor down to “Best Solution”, while there click the “Was this helpful? [Yes]” button
If you do not have a vise a large C clamp to a work surface might work, you may still need a block or two of wood.
If the Chain brake and front hand guard are not part of the clutch cover, many say a crescent wrench works as a reset tool. In the clutch cover it is the uppermost left component. It wull require some amount of force.
Lou
Jan 23, 2010 | Husqvarna Chain Saw 20" Bar
Can't get the keyless chuck off cordless Makita 6095D drill.
If this is a newer tool it is probably a Torx drive screw usually a T20. The screw is LH thread and after removing it you will need to put some screws back in tool to remove the chuck. First shift the gear selector to the low setting and the clutch to the drill only. Next get a bent handle allen wrench about the capacity of the chuck install the short end of wrench in chuck and tighten. Put the chuck on a block or wood or a workbench to support is and turn the wrench to about a 30 degree angle in the counterclockwise position. The chuck has standard threads so you want to hit the wrench with a hammer to loosen it. This might take a few tries but it will work. Good luck
Dec 31, 2008 | Makita 12V Cordless Impact Driver -...
1996 chevy s10
it has an allen wrench end but is better for that type of stuff
Nov 19, 2008 | 1998 Chevrolet S-10 Pickup
Chuck change
After removing the screw and inserting the allen wrench shift the drill to the LOW position and turn the clutch to the drill only position. Use an allen wrench about the size of the chuck capacity so that it will not flex when hitting it with a mallet. Sometimes they are stubborn because of the torque but this should work. Put the allen wrench at about a 30deg angle and hit the wrench. I support the chuck on a workbench or a block of wood will do fine. The chuck has standard threads.
May 10, 2008 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
Husqvarna 450 e-series 18" Chain Saw Logo
79 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
