Question about BenQ FP737S-D 17" LCD Monitor
Can't find an inverter board for my X9G Komodo III
I found two busted Caps and need to replace my main board because it is three years old. I can find one any where except at Sceptre and they want $110.00 plus $25.00 to ship and that is not worth the price.
Can any one tell me where to buy this inverter board?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • BenQ Master
  • 848 Answers
Can't find an inverter board for my X9G Komodo III? This trouble maybe power supply or inverter boards is defective.
first you can test the voltage of the multr,and then check which part is defective.From Wisiny.com can find those parts
if you have any question,please let us know email:service@wisiny.com.thanks,we sincerely hope we can help you!
you can also check this boards whether suit you:
Sceptre LM004 Power Supply Backlight Inverter for X9G KOMODO
Posted on Mar 22, 2015
You can try http://providencedata.com/. They have a huge selection of inverter boards. If you are using the monitor and are confident in your souldering skills you can usually buy the capacitors for about 20-30 cents each... Bit of a risk if it goes and burns up on ya though ;)
Posted on Dec 11, 2007
Scepyre 17 in X7
This board is out of my Sceptre X9G Komodo. The 740uf capacitors are clearly marked 25V. The 1200uf Caps are 10V. I ordered parts for mine to try. The darker 740 has a slightly "popped" top.
470 is about 10mm dia X 16-17mm long
1200 is about 10mm dia X 20? long
two leads on each about 5mm apart. They are soldered to the board.
Jul 16, 2008 | Sceptre X9G Komodo IV 19" Flat Panel LCD...
Sceptre X9G Komodo IV 19 in
check out any dry solder or burnt and re solder it , hope it helps AJ
May 03, 2008 | Sceptre X9G Komodo IV 19" Flat Panel LCD...
X9g komodo v screen just turned blank (white)
Go to ebay, type X9g kimidi logic board. Usually, some seller might have pulled working parts from other monitors and sell them individually. If you cannot find them, google "buy x9g komodo logic board". Some website, I'm quite sure will sell them.
Mar 17, 2008 | Sceptre X9G-KomodoV (Black) 19 inch LCD...
Sylvania 42
Check the fuses on YSUS & ZSUS boards, if found the fuse blown on that board, just try to replace the board.
Dec 30, 2007 | Sceptre X23gv-Komodo 23 in. LCD TV
Where to find capacitor
www.bluestar-online.com, mcmelectronics, tritronics etc. You will need to heat up the soldering trace, or legs of capacitor and pullout gently.
Oct 01, 2007 | Sceptre X9G Komodo IV 19" Flat Panel LCD...
Sceptre X9G-Komodo IV
I recently came accross one of these monitors (Planar PE191M) with the identical issue. The resolution was to replace the two 470ufd 25V capacitors that are located on the main power board. The main power board also contains the audio circuit and more importantly the inverter circuit that drives the CCFL backlighting. The suspect caps were identified using an ESR meter; if you happen to have one of these meters you can confirm this is the issue with your unit(s), alternatively you can just replace the two capacitors and see if it resolves your issue. Hope this info helps someone out there.
Sep 05, 2007 | Sceptre X9G Komodo IV 19" Flat Panel LCD...
Pe 191m power
try the capasitos in the in line of the circuit they have to be electrolitic condencer some times with the time they open and made the monitor not work try it wiht analog multimeter is more easer know if the condencer are bad
Sep 05, 2007 | Planar PE191M 19" Flat Panel LCD Monitor
BenQ FP737S-D 17" LCD Monitor Logo
82 people viewed this question
Top BenQ Computers & Internet Experts
JP Services
JP Services
Tommmix
Level 1 Expert
Computer Links
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
