Question about Dell 47JFR - (Refurbished) ( 47jfr )
Set up raid 1 with win xp--------47JFR controller
Set up raid 1 with win xp------47JFR controller scsi
  • steve johnson May 11, 2010
    what is the issue your asking about?
    Scholar:
  • 180 Answers
Load the software driver for this card
then open the window of this software by opening it from program files , you would see help on this soft ware . select raid 1, else is done auto .you must have minimum two drives to make a raid
Posted on Sep 19, 2009
Can I boot from a SATA drive and access pre-existing SCSI Drives?
You need to install the driver of your scsi controller for win7/64. Then you'll see your datas on win7.
Jul 08, 2012 | Dell Precision Workstation 670 PC Desktop
Proliant does not boot from raid controller if external SCSI drive is powered on.
Try to disable boot to other device on your bios setting.
Make sure that your Smart Raid is set on the first boot device.
Nov 01, 2011 | HP Compaq ProLiant ML350 G3 Server
Acer aspire one starts to boot up stops at windows xp screen
Hi there !
I suggest you try to run your computer on safe mode by pressing F8 when booting up. Advance menu options will pop up and choose run on safe mode. When it load the Windows, try to figure out what you installed or you before your computer happens. I suggest that you download also windows registry cleaner to fix some errors in your computer that prevent you to go to windows screen when booting up on normal mode. Run the FULL SCAN and press the fix errors button.
I should somehow help your computer.
Feb 05, 2011 | Acer Aspire One Netbook 8.9" Notebook
Boot problem with IBM xseries 206 - SCSI Drive and SATA drive
Refer to user's manual how to set the boot order in BIOS.
Jul 17, 2009 | IBM eServer xSeries 206
Not getting a drive letter from Compaq SCSI RAID setup
Did you see any new drives in the disk managemen screen? To get to the disk management, hold window key down and hit 'R', then type diskmgmt.msc and hit enter.
If you do see the drive in the lower half of the screen, you need to initialize the drive either as dynamic disk or basic disk. Then you need to add a new partition and format it.
Good luck.
Jul 04, 2009 | Compaq (128293B21) (128293-b21) SCSI...
I am tring to install win XP with sata drive and
Make sure it is listed in your system CMOS before starting the XP install. Make sure cables are correct, and the drives are not turned off in CMOS. Some setup will allow you to set the drive types to AUTO, so you can also try that.
Jun 30, 2009 | MSI 661FM3-V Motherboard
Pci ide controller for third hard disk
You need to enter into scsi bios first, then do an autodetect for hard drive, this will set the IDE/SCSI hard drive on raid controller.
To enter SCSI control you need to press the same key stated on screen on startup (F6 I assume) I think F3 is just boot settings.
If the card do not enter regularly in CMOS settings for the raid then this card is defective.
Mar 28, 2009 | Sabrent SBT-RDIT PCI IDE Silicon Image...
Raid 0 on Intellistation 6221?
That particular work station comes with both IDE and SCSI drive interface controllers. The IDE drive should be used for your OS. The SCSI drives for your data storage. Now, the issue is to get the SCSI to work in RAID_0 as I understand.
You iwll need a RAID controller such as Adaptec AHA-3940AU WD SCSI Host Controller, which may be found on eBay (used) for a very affordable price. The driver software may be downloaded directly from Adaptec, so I suggest you do that in the iterim peroid, and store drivers on a USB thumb drive.
Hope this helps you.
Dec 21, 2008 | IBM IntelliStation Z Pro 6221 PC Desktop
How to make raid 10 with Tyan M7902?
Yes. Unless you're using HP-Ux's LVM or some other Logical Volume Management software package, the controller can only perform mirroring on the same channel. I see no value in running Raid 10... all it does is strip the mirrored data on the 2nd set of disks. It uses the same overhead as mirroring and offers minimal benefit with the potential for more overhead in slowed bandwidth. Make it simple and just mirror the drives with Raid 1.
Sep 05, 2007 | Tyan M7902 (m7902tarosodimm) SCSI...
Dell 47JFR - (Refurbished) ( 47jfr ) Logo
107 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
