Question about Olympus FE-230 Digital Camera
LENS DOESN'T OPEN
Camera has worked fine for about 50 shots over 3 months. I was travelling to Germany, so charged the battery to ensure full charge available for holiday shots. Wouldn't you guess - since I replaced the battery after charging, the lens doesn't fully open - it just cycles as if under powered. However, I am still able to review all pictures and select Review menu options. Is this likely to be a battery charge problem? I'm reluctant to spend another £15-ish if the camera is irrepairably blown!
  • hellonelee Jun 26, 2008
    my lens dont open. i dropped it in the streets and now the len wont open. i hve coneccted it to the computer but that doesnt work.
  • Olympus Master
  • 4,738 Answers
The following blog outlines some repair options for a lens error:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
By the way, try Fix #1 first with different fresh batteries.
Posted on Dec 23, 2007
Canon 55o d will not turn on
Try another battery first. Many of the cheap Chinese batteries won't hold a charge.
Otherwise it sounds like you might have water damage to the circuit board that his shorting out the battery
Mar 18, 2013 | Canon REBEL T2i EOS 550D Digital Camera...
I have a Samsung TL100 camera and it will not take a charge
If you haven't used it for the last 8 months and before it was all fine then the most common reason would be the battery. Your battery is absolutely dead but then again if you plug it to AC then it must show some sign of life. But give it a go by replacing new battery. To check get it from a friend and then test the camera on it.
If the battery replacement doesn't work then take it to an authorized dealer for inspection.
Oct 30, 2012 | Samsung TL100 Digital Camera
Lens won't close and On/Off button doesn't work
Even though the battery appears to be charging it may be shot. Some batteries if they run down too far can not be recharged. You need to try a new battery in the camera.
Jul 25, 2012 | Nikon COOLPIX S6000 Digital Camera
My Canon SX120 suddenly stopped working after about ten months of regular use. I was uploading abpout 50 photos and ten videos to Picasa as usual and even freshly charged battteris do not work now. It...
Ten months ur camera still under warrenty,call and talk to the Canon customer services.Ten months the camera litum battery should not have ben in trouble already,could be the transformer or the power A/C cord adaptor itself it is not functions properly for the battery to be charging or it could be damages to the A/c power cord itself than it is not taking in the A/C power juices to charges the litium battery.Litium Ion battery last at least a 1 1/2 or 2 years by of 8 hrs of charging and able to used the equipments for the battery juices like 2 1/2 to 3 hrs of battery power to be used.
Oct 28, 2011 | Canon PowerShot SX120 IS Digital Camera
When I turn the camera on the screen shows a white light. No image
  1. Verify that the lens cap is not covering the camera lens.
  2. If operating the camera with a battery, ensure the battery is fully charged.
  3. If operating the camera with the power adapter, ensure it is plugged into a working AC outlet.
  4. Verify that the LCD screen is turned on.
  5. Adjust the LCD brightness control.
  6. Change the shutter speed or aperture settings.
  7. If the issue is not resolved, try resetting the camera.
Using an Initialize option in the menu
Since Cyber-shot cameras have different menu system layouts, refer to the instruction manual specific for your camera model.
Using a RESET button
  1. Locate the RESET button on the camera.
  2. Use a pointed object (like a ballpoint pen) to press and hold the RESET button for 2-3 seconds.
  3. After 2-3 seconds has elapsed, release the RESET button.
Performing a manual power reset
  1. Turn off the camera.
  2. Remove the battery pack.
  3. Remove the button-sized lithium battery.
  4. Allow the camera to remain without power for 30 seconds.
  5. Reinsert the button-sized lithium battery.
  6. Reinsert the battery pack.
  7. Turn on the camera.
Jan 01, 2011 | Sony Cyber-Shot DSC-S40 Digital Camera
After charging my battery I installed the battery and turned the camera on. The lens came out and the screen came on. All of a sudden the screen turned solid white and faded to black. Now the camera will...
Hi there please follow the steps and let me know the result.
1. Ensure batteries are fully charged.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. turn on camera and see.if working then fix the memory card & again turn on the camera. If working then fine . Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec .. in not done the press both Menu & self time key for 2 - 4 sec.
i hope it will gives you success. Thanks & Before you leave, if you have found my information helpful and if you haven't already done so then please press the ACCEPT button, this is how I am paid for helping you today. POSITIVE feedback & bonus is appreciated
Apr 23, 2010 | Sony Cyber-shot DSC-W50 Digital Camera
Full battery cyber-shot turns self off, leaving lens out
Your problem is likely due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your batteries may be to weak/worn to take/hold a charge and properly power the camera, or the camera may require professional repair.
Oct 16, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
My camera lens isn't working, how can I reset it?
it sounds like there is dirt, dust or something else in the lens mechanism. I'm assuming you don't want to take the camera to a repair shop. I've had several cameras and this issue comes up periodically.
You can try:
1. using compressed air (with as thin a nozzle as you can find) to blow out the dust,
2. try powering on the camera and zooming the lens at the same time, 3. gently knocking the camera on a hard surface to loosen the lens mechanism,
4. manually forcing the lens to go back in. This can potentially damage the camera, but it's not working now, so you don't have a lot to lose.
5. Googling the camera model to see if you can find instructions on opening the camera up to clean the lens mechanism.
Oct 09, 2009 | Panasonic Lumix DMC-TZ3 Digital Camera
Camera does not turn on.
I had a similar problem and it was a result of the battery not charging correctly. I bought the travel battery charger and an additional battery from amazon to see if maybe the battery was just old or just not charging. I figured out that the internal camera charging mechanism just wasn't working b/c the battery charged fine with the travel charger. I like the travel charger better and with two batteries I can charge one while the other is in use. I haven't had a problem since. When you buy the new battery you still have to charge it before it's first use. I hope this works for you as it did for me.
Jan 06, 2007 | Sony Cyber-Shot DSC-F707 Digital Camera
Olympus FE-230 Digital Camera Logo
76 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
