Question about Casio EXILIM Card EX-S770 Digital Camera
Broken plastic top by power button
Top of camera is broken... This plactic cover around the power button is cracked. Can anyone tell me where i can get a new plastic cover??
tannerphx@yahoo.com
Thanks...
Remove two screws and then remove C-CASE-ASSY
Posted on Dec 15, 2007
The touchscreen of my Z22 is broken
The Z22 is a bullet-proof device for securely saving your personal data, and full marks go to the team at PALM for its solid design. However, the AGE of the Z22, over the last decade, results in 3 problems - the batteries are all dying, and the delicate plastic touchscreen top layer is deteriorating - simply through AGE. When you say the touchscreen is "Broken", I would guess you mean that it does not respond to touch commands from the black plastic stylus that sits in the slot on the back, side, of the unit, when stored. I have never actually seen or heard of a screen that is physically "broken" - like the thousands of iPod, iPhone, Motorola RAZOR, and other touch screen phones that you see today, with cracks running across the broken GLASS. It "Could" happen that the glass screen under the top plastic touch layer is, actually "BROKEN", with the resulting cracks, but this is unlikely, since the trim around the screen is raised a HUGE distance, compared to today's touchscreens.
You can easily replace the screen for $9 if you wait for free shipping from CHINA, or, you can try a few tricks I learned on my Z22 over the years. I have put it in the freezer - which worked temporarily, heated it with a hair dryer - which worked temporarily, and peeled the top plastic layer off the screen- which worked temporarily. I have also replaced the screen with a new one. It is IMPERATIVE to put a hard plastic cover on the Z22 at all times- or you will eventually loose the screen again...
My Z22 page is at:
kidbots.com/WEBADD/Z22_PALM_PILOT/Z22_PALM_PILOT.html
I hope this helps you to get your Z22 back up and running
have fun
good luck
robin dusty graves
Z22 PALM PILOT touchscreen-z22-broken-ngl0e1lc0ft3j10pmz4xzklk-1-0.jpg touchscreen-z22-broken-ngl0e1lc0ft3j10pmz4xzklk-1-1.jpg touchscreen-z22-broken-ngl0e1lc0ft3j10pmz4xzklk-1-3.jpg
Dec 12, 2009 | Palm Z22 Handheld
Digital camera screen broken
A cracked screen will cost you, but maybe not as much as you think. Instead of replacing the whole , you can spend about $300 and replace the screen yourself. All you need is a small screwdriver.
1)Turn off the power to your screen and unplug all cables connected to it.
2)Remove the battery, if one is installed.
3)Locate the covered screws around the cracked screen. Remove the rubber/plastic covers, then unscrew the screws.
4)Gently remove the plastic frame around the cracked screen and set it aside.
5)Disconnect any power cords or cables going into the LCD screen.
6)Remove the cracked screen and slide the new screen into place. Replace any tape or plastic fasteners that hold it in place.
7)Reconnect all internal cords to the screen.
8)Screw in the frame and replace all the screw covers.
9)Reconnect the power supply and all external cables to the LCD screen and switch it on.
Aug 31, 2009 | Sony Cyber-Shot DSC-P150 Digital Camera
Dometic rm2804 door hinges are worn and plastic strip retainer is broken off. On the lower door the hinge pins fit into round metal guides. In turn, the metal guides are held in place on the door corners...
I had this problem. I reversed the decorative plastic strips, both ends of the strip have hinge pin holes, so the doors can open left or right. I put the TOP decorative plastic strip on the bottom and BOTTOM on top.
Jun 25, 2009 | Dometic Refrigerators
Power Board Problem and Power Button Hinges Top Cover broken
It would be cheaper to have the power board repaired but the replacement is around $55 from ebay. I'd get a new moulding for it if its available or even if you got somthing plastic welded up.
http://cgi.ebay.com/Acer-Aspire-3050-3680-5050-Power-Board-w-dc-jack-usb_W0QQitemZ120415274982QQihZ002QQcategoryZ158887QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Hope this helps
May 06, 2009 | Acer Aspire 3680 Laptop
Power up button (internal) broken
That hinge cover connects the top up above the keyboard. What needs to happen is the bottom part of the over needs to go over the holes near the keyboard and then the rest of the cover you will need to snap into place so its flat all around
Apr 17, 2009 | Dell Inspiron 2200 Notebook
The connection where you plug in the power on my compact presario R3000 laptop is broken. The female part that you plug into is loose and probably broken away from the solder on the mother board it self. I...
Before you pull apart your laptop, check the male connector and power cord of the adapter, check it with a multimeter and or plug it into another Compaq. You could have a broken wire in the power cord, it could save you a lot of work.
To pull apart the laptop, remove the battery, hard drive and CD drive first.
Then remove all the screws from the bottom of the laptop, plus the screws on the back that holds the LCD's hinge to the laptop base.
Take a note of where the screws come from, some may be shorter that others.
The remove the keyboard (the screws should already been removed from the bottom of the laptop).
Carefully remove the plastic cover next to the base of the LCD screen, This may also cover the hinges, if necessary fold the screen flat to enable you to carefully pry this cover up and off.
The plastic top cover is clip fastened to the bottom of the case, carefully prize apart from one side and gradually work around the other sides.
You can now remove the LCD, there are two connects attached to the motherboard, unclip these.
The motherboard is under the keyboard and plastic top cover, there are screws securing it to the plastic base, remove these and you should be able to free it from the base.
Now you can solder/fix the power connector.
I suggest you use a temperature controlled soldering iron.
Don't use too much force, you might crack the plastic parts.
Best of luck and have fun.
Jan 12, 2009 | Computers & Internet
My Minolta 7000 camera's rewind switch won't budge.
I have seen this on several of these, a small bit of plastic breaks off on the top cover and jams the rewind switch assembly.
To repair this you would have to take the top cover off and then remove the rewind swtich assembly from the top cover remove the bit of plastic and hey presto. You will find after removing the bit of plastic you will have to hold the lever to keep the camera rewinding, the lever will no longer stay in place as it used to (the bit of plastic held it in place)
Post back re Palmyman if you want to attempt this
Oct 12, 2008 | Minolta Maxxum 7000 35mm SLR Camera
Lens cover cap broken
There are no Spares for these I feel Canon Technical Support may have a solution or a little bit of imagination and a suitable bottle/jar top may serve- with a little piece of fine cord to loop around the camera body
Jun 26, 2007 | Canon PowerShot SD750 / IXUS 75 Digital...
Casio EXILIM  Card EX-S770 Digital Camera Logo
35 people viewed this question
Top Casio Cameras Experts
mohamed salim shaikh
pontelemon
pontelemon
Are you a Casio Camera Expert? Answer questions, earn points and help others
