Question about Canon NP 6050 Copier
How to fix eror 000 on canon np 6650 II - Canon NP 6050 Copier
    Guru:
  • 389 Answers
This problem take a part? then the fusers lamp is wrong or disconnect. Please, be shore, that the connections of fuser lamp, it's on fusers part of the copiers, is on work?, The second, tes please the thermistor section, if the thermistor dous notwork, the eror 000 will be the same. And then, u mast test the thermo fuze, this own, and all about I told u is situated in fusers part and remooved very easy. Weel, then u test will be finished your copier dous not started, u must push the buttom wich is on ander the back cover in to the right and down place near the controller of DC. Than u push it, u can starting the copier. My email goodgold@inbox.ru Good lark
Posted on Sep 12, 2009
  • Sergey Artuganov
    Sergey Artuganov Sep 20, 2009
    http://all-drivers.org/?dsps=48&gcli...
  • Sergey Artuganov
    Sergey Artuganov Sep 23, 2009
    • Thermistor (TH1; displacement,
    poor contact, short circuit)
    • Fixing heater (H1; open circuit,
    cracking)
    • Thermal fuse (FU1; malfunction)
    • DC controller (faulty)
    • The detection temperature of the main
    thermistor (TH1) does not reach 50°C 15 sec
    after a press on the Copy Start key.
    • Initializing Back-Up Error Codes
    If the self-diagnosis mechanism has turned ON,
    you can reset the machine by turning OFF and then
    ON the power switch, unless the error is represented
    by ‘E000’, ‘E001’, ‘E002’, “E003', or ‘E004’.
    This is to prevent the user from resetting the machine
    thereby damaging the fixing assembly.
    If ‘E000’, ‘E001’, ‘E002’, “E003', or ‘E004’ is
    indicated, remove the cause of the error and perform
    the following:
    1) Open the front door, and insert the door switch
    actuator.
    2) While holding down the service mode switch
    (SW850) on the DC controller, turn the power
    switch OFF/ON.
    3) When the power has been removed in about 2
    sec, turn ON the power switch once again
    E000
    Cause
    Sub thermistor
    (TH2)
    Main thermistor
    (TH1)
    Thermistor
    Thermistor
    Checks
    Turn off and then on the power
    switch. Is '000' indicated for about
    5 sec and then is the power
    switch turned off automatically?
    Execute 'ERROR' in service mode
    ( ) to reset 'E000'.
    Check that the fixing assembly is
    installed properly.
    Turn OFF the power switch, and
    disconnect and connect the power
    plug.
    Does the fixing roller heater turn
    ON when the power switch is
    turned ON?
    Caution:
    Take extra care. Repeating this
    procedure causes the fixing
    temperature to rise abnormally,
    damaging the fixing roller and
    the separation claw.
    wait until the upper fixing roller is
    cool; then, turn ON the power
    switch. Select the screen showing
    'FTMP' in service mode ( ).
    Does the value under 'FTMP'
    remain the same? (Turn OFF the
    power switch after the check.)
    Is the thermistor in even contact
    with the upper fixing roller?
    Clean the contact face of the thermistor.
    Is the problem corrected?
    Action
    Check the sub thermistor
    (TH2).
    Replace the DC controller
    PCB or the SSR.
    Check the wiring from
    J108A on the DC
    controller PCB to the
    thermistor (TH1); if
    normal, replace the
    thermistor (TH1).
    Install the thermistor
    properly.
    End.
    Cont’d
    Cause
    Environment
    Main thermistor
    (TH1)
    DC controller
    Checks
    Does the problem occur only
    when the power is turned ON for
    the first time in the morning?
    Replace the thermistor. Is the
    problem corrected?
    Step
    Action
    •Advise the user that the
    site environment is
    outside the standards.
    •Advise the user to wait
    until the room is warm
    enough before turning
    on the power.
    End.
    Replace the DC
    controller.
Conon ir 2520 erore code e000750
E000 errors are usually a bad fuser (also called fixing assembly by canon) You should buy FM4-3367-000 (for US/ Canada / Mexico 110V version.
Sep 11, 2014 | Canon imageRUNNER 2520 Laser Multifunction...
Mesin saya canon np 6650 II, mesin tidak jalan, pada layar monitor tertulis E210 remettre copieur sous tension, bagaimana ?
Mesin saya canon np 6650 II, mesin tidak jalan, pada layar monitor tertulis E000 remettre copieur sous tension, bagaimana ?
Feb 07, 2013 | Canon NP 6650II Copier
What means of po cont on canon np 6650?
PO cont means Drum Potential Control,
If po cont set to 0, it means scanner system adjust the document darkness automatically but you may face many printing problems such like auomaically over dark, over light, heizzy, dull, etc etc.
if you want to trouble free printing, please set PO-Cont to 1
Aug 11, 2011 | Canon NP 6650II Copier
Eror 003 and 000 a new problem his show ,check document
error 003 and 000 means fixing assy fault, temperature fails to raise.
under service mode ( menu and # ) select clear and err or all.
If these doesnt helps, you need to change the fixing lamp or thermistors.
Hope that helps!
Feb 22, 2011 | Canon imageRUNNER 2000 Copier
Mesin saya canon np 6650 II, nesin tidak jalan, pada layar monitor tertulis E001 ! turn the power on again, bagaimana solusinya?
PAGI gan saya mau tanya foto copy saya NP6650 II di monitor ada tulisan nya 002 ! TURN THE POWER ON AGAIN BAGAIMANA SOLUSINYA TRIMA KASIH
Nov 11, 2010 | Canon NP 6650II Copier
I need service manual for canon np6650 photo copier
I can't guarantee the validity of the source, but if you try this site:
http://www.uploadcity.com/?q=canon+np+6650+service+manualyou may find what you are looking for.
Hope this helps!
Oct 17, 2010 | Canon NP 6650II Copier
Error E010
"E010" Drive problem
http://www.manualshark.org/m/canon-np6150-6650-6650ii-7050-7550-8070-8530-8570-8580-black-994/
http://eshop-manuals.com/index.php/cPath/4
Above is a service manual a MUST HAVE in order to fix, above that is a user manual, for troubleshooting.
Apr 28, 2010 | Canon NP 6650II Copier
Copy result is blur and I see the acceleration of paper too fast
When you say Blur? Is it a scattering of toner or is the whole image blurred or out of focus? You may have a problem with the lens HP or a problem with the scanning mirrors. Do you get a error code? Is the blur like toner strikes down the page? Check you corona wires and look for any small pieces of paper that maybe lodged in or around the drum unit. You may want to give a little more info. on the exact problem, to narrow down the cause
Dec 27, 2008 | Canon NP 6050 Copier
Specificatios
GO to CanonUSA.com and download a spec sheet.
Aug 21, 2007 | Canon NP 6050 Copier
Canon NP 6050 Copier Logo
383 people viewed this question
old marine
old marine
