Question about Harman Kardon AVR 30 Receiver
SOURCE: When I go to power
Depending on your ablilities there might be a quick fix. It sounds like the contacts in your on/off switch are either corroded or worn out due to heat. Ensure the unit is unplugged from any electrical source. By opening up the unit you will have to detach the on/off switch, and by bending the prongs carefully, open the casing up. Clean all internal part using contact cleaner. If the contacts are worn or corroded, you can try replacing or what I did was added some solder to the contacts and put the unit back together reversing my steps.
Good Luck.
Posted on Jun 27, 2008
SOURCE: I have a Harman Kardon AVR 235 Receiver that go's into Protect
To avoid making the avr go into protect mode when you power up your Hafler 4000 that is connected in the avr's pre-out, you must power up the set up in the correct sequence.
1. Turn off your avr
2. Connect Hafler 4000 to the avr's pre-out it it is not yet connected
3. Turn on your Hafler 4000. The avr will not go into protect mode becasue of the transients from the Hafler because it is still not powered on.
4. Turn on you avr. There should be no more transients from the Hafler at this stage unless it is not functioning correctly, so the avr shouldno longer go into protect mode.
Posted on Dec 16, 2008
SOURCE: can I conect harman Kardon avr 230 to apple tv
Yes, although it (AVR) does not support HDMI only component video.
Connect the audio to the receiver and the video directly to the TV if you have inadequate video inputs, or want to take advantage of the HDMI.
Posted on Jan 01, 2010
Testimonial: "cheers, have a good year."
SOURCE: Harman Kardon HK 3270. The receiver looses the
I believe it is actually a memory capacitor that has to be replaced. It is soldered directly into the board and requires quite a bit of know-how to replace.
Hope this helps,
Thanks,
Posted on Jan 20, 2010
SOURCE: My Harman Kardon AVR 330 is locked. Can't unlock
youtube
myspace
facebook
Posted on Feb 12, 2010
Oct 09, 2017 | Harman Kardon Audio Players & Recorders
Mar 22, 2013 | Harman Kardon Audio Players & Recorders
Dec 13, 2011 | Harman Kardon AVR 25 MKII
May 21, 2011 | Harman Kardon AVR 130 Receiver
Apr 29, 2011 | Harman Kardon AVR 500 Receiver
Mar 07, 2011 | Harman Kardon AVR 210 Receiver
Jan 10, 2011 | Harman Kardon AVR 55 Receiver
Dec 22, 2010 | Audio Players & Recorders
Nov 12, 2009 | Audio Players & Recorders
67 people viewed this question
