Question about T-Mobile Sidekick® 3 Cellular Phone
My sidekick lx wont power on
I plugged it to the charger for the whole day and nothing and all that appears is a small icon botton
what to do?
Sidekick lx2009 wont turn on & when charging it turns on & OFF!
try plugging it in to the computer or try a new battery
Sep 01, 2009 | Sharp Sidekick LX Smartphone
SiDEKiCK LX CHARGER PORT BROKEN??
sound like you need a new battery or charger or maybe both. try useing a diffrent battery and charger befor buying one
Aug 27, 2009 | Cell Phones
Low battery signal on ohone ,phone wont turn on
check the shorting and update software by flashing
Jul 30, 2009 | Sharp Sidekick LX Smartphone
Sidekick lx
obviously not.
because the sidekick lx have usb port that is use with the usb charger only.
Jul 18, 2009 | T-Mobile Sidekick® 3 Cellular Phone
Sidkick lx lcd backlight malfunction
how to connect my datacable to my sidekick mobile? it when i connect it shows malfunctioned.
May 12, 2009 | T-Mobile Sidekick® 3 Cellular Phone
My side-kick LX will not turn on
Try this, though is used for when the device is randomly rebooting aswell, it might help you to force your Sidekick to come back on:
  1. Check the device's battery level for at least two bars of strength.
  2. If the battery level is low, charge the battery.
  3. If the issue is not resolved, remove the back cover.
  4. Remove the battery.
  5. Wait 10 seconds.
  6. Press and hold the W key.
  7. While pressing down the W key, re-insert the battery.
    • The device restarts and after approximately 15 seconds, the 'Recovery' screen appears.
  8. Select the desired language.
  9. Select Reboot to restart the device.
  10. Your Sidekick should go back to the main screen as normal. Good luck
Dec 02, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Sidekick LX Wont Turn On !!
NO THEY PROBALY WONT FiX iT.....THE PHONE HAS WATER DAMAqE
Nov 02, 2008 | T-Mobile Sidekick
Sidekcik Lx will not charge.
alright..my sidekick does he same thing but i fund a temp fix....the guy at the store says its the charging port..idk.....first plug it in....let it charge 4 ten min....then try to put in on...it will say the low battery sign...dont worry...then t8 sumting pointy and push it in the little reset hole behind the screen as you swivel it...as soon as you see the little box with the circles in it you press and hold the space button... hopeully it will start by showing the four butttons....if it does start and cuts off at the tmoblie sign jus let it charge longer and do it agian....hopefully it will work on yours it worked on mine....gud luk
Jul 02, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Phone will not turn on
Sounds like your charger port is busted. Ti is a common problem on sidekick 3 and can effect sidekick IDs as well. A fairly cheap workaround is to get an external battery charger. It will have a slot to charge the sidekick battery external formthe phone. They sell on ebay fior about 25 dollars.
The sidekick ID and sidkeick 3 batteries are the same so it will work. Check then out here
Sidekick ID battery charger
Feb 24, 2008 | T-Mobile Sidekick ID Cellular Phone
T-Mobile won't fix my Sidekick 3
hey, my sidekick3 screen won't light up
and my buttons wont light up either.
and suggestions?! please help
Aug 20, 2007 | T-Mobile Sidekick® 3 Cellular Phone
T-Mobile Sidekick® 3 Cellular Phone Logo
97 people viewed this question
Top T-Mobile Cell Phones Experts
Computer Repairing
Computer Repairing
SHIVAJI YADAV
SHIVAJI YADAV
Are you a T-Mobile Cell Phone Expert? Answer questions, earn points and help others
