Question about Samsung Bargaincell Original OEM Accessory Bundle SGH T809, D820, SGH T509, SGH D807, SGH T519 Trace, SGH T629, Sync SGH A707, SGH D900, Blackjack SGH I607, SGH T629, Ph M610, Sch U420, Sch U740, SGH T219
UNLOCK CODE FOR SAMSUNG SGH M610 i dont know how i happened but my daughter managed to lock herself out of her phone and now it wont do anything at all. on start up it simply says puk blocked. can anyone help.
    Guru:
  • 188 Answers
This is the code n it would work
#*7337#
Posted on Sep 13, 2009
  • 1 more comment
  • Babar Swatty
    Babar Swatty Sep 13, 2009
    This is the code:
    #*7337#
  • Babar Swatty
    If u failed to unlock it by that code, then here's a gift 4 u:
    (try these at your own risk)
    #*4864# = Index Voice RESET
    #*5376# =ALL SMS DELETED
    #*7337# = "EEPROM Reset" (Unlock and Resets Wap Settings)
    *2767*226372# = E2P Camera Reset
    *2767*3855# = E2P Full Reset
    *2767*7822# = E2P SVC Reset
    *2767*927# = E2P Wap Reset
    ...and the rest of it
    #*0227# = GPRS Switch ClassC CS EXECUTED
    #*1300# = IMEI
    #*1400# = IMSI
    #*2027# GPRS Switch ClassBrevert CS EXECUTED
    #*2252# = Current CAL: For Cmd set DEBUG AUTONOMY in ci hard.opt
    #*2255# = "command #*2255 Doesnot Exist"
    #*2256# = Calibr.-Info For Cmd set DEBUG AUTONOMY in ci hard.opt
    #*22671# = AMR REC START 1 HOUR'S FAR AND LOCAL RECORDING STOP KEY STRING: #-22672#
    #*22672# = Stop AMR REC (File name: /a/multimedia/sounds/voice list/ENGMODE.amr)
    #*22673# = Pause REC
    #*22674# = Resume REC
    #*22675# = AMR Playback
    #*22676# = AMR Stop Play
    #*22677# = Pause Play
    #*22678# = Resume Play
    #*2286# ="command #*2286 Doesnot Exist"
    #*2337# = Permanent Registration Beep: NOT YET IMPLEMENTED
    #*2351# = restart
    #*2474# = Info AvBat.: 3630mV Bat.: 3618mV AvTemp.: 38Deg Temp.: 38 Deg
    #*2527# = GPRS switching set to (Class 4, 8, 9, 10)
    #*2558# = "Time ON"
    #*2562# = ??? White for 15 secs than restarts.
    #*2565# = "No Blocking General Defense"(Check Blocking)
    #*2637# = Invalid no of parameter
    #*2677# = Please use function 2637
    #*2679# = Copycat feature ACTIVATED/DEACTIVATED
    #*2775# = ??? White for 15 secs than restarts.
    #*2787# = CRTP ON/OFF
    #*2836# = AVDDSS Management DEACTIVATED/ACTIVATED
    #*2886# = AutoAnswer ON/OFF
    #*3273# = EGPRS multislot (Class 4, 8, 9, 10) Mobile must be restarted!
    #*3282# = Data DEACTIVATED/ACTIVATED
    #*3353# = "General Defense Code Erased"(Check Code)
    #*3370# = Please use function 2637
    #*3676# = "Flash volume Not implemented"
    #*3737# = L1 AFC: DeltaF 40 NbAfcCorr 1792 AdjustFoi 50 Cumfoi -57
    #*3797# = Command #*3797 Doenot Exist
    #*3837# = ??? White for 15 secs than restarts.
    #*3838# = ??? White for 15 secs than restarts.
    #*3849# = ??? White for 15 secs than restarts.
    #*3851# = ??? White for 15 secs than restarts.
    #*3876# = ??? White for 15 secs than restarts.
    #*3877# = ??? White for 15 secs than restarts.
    #*3888# = BLUETOOTH ……. Device Under Test mode
    #*3940# = External looptest 9600 bps not available in SYSOL2!
    #*3941# = "External looptest 115200 bps not available in SYSOL2!"
    #*4700# = Please use function 2637
    #*4760# GSM ACTIVATED/DEACTIVATED
    #*4773# = Incremental Redundancy Deactivated / Activated
    #*5133# = L1 HO Data Async HO2 Sync HO 37 HO Fail 0 SDCCH 22 TCH 26
    #*5171# = L1P1 Pi51 96 Pi52 14 ReselPi51 14 ReselPi52 14 PiDsc 0
    #*5172# = L1P2 PiConfig 0 Paging Action 1 SplitPgCycle 0 NcMode 0
    #*5173# = L1P3 DI 36 UIDyn 35 UIExtDyn 0 UIFix 0
    #*5176# = "L1 Sleep T0I N: 54 T0I P: 444"
    #*5187# = L1C2G trace ACTIVATED/DEACTIVATED
    #*6837# = "Official Software Version: 34000200 35000102"
    #*7200# = Tone Generator Mute
    #*7222# = "Operation Typ : Class C GSM"
    #*7224# = "!!! ERROR !!!"
    #*7252# = "Operation Typ: Class B GPRS"
    #*7271# = "CMD: Not Available"
    #*7274# = "CMD: Not Available"
    #*7276# = Invalid no of parameter
    #*7276## = "command #*7276# Parameter out of range"
    #*7287# = GPRS Attached
    #*7288# = GPRS Detached/Attached
    #*7326# = Accessory: nothing
    #*7352# = BVMC Reg value Set BVMC LOW_SWTOFF
    #*7372# = Resetting the time to DPB variables
    #*7462# = "SIM Phase 3"
    #*7524# = KCGPRS: FF FF FF FF FF FF FF FF 07
    #*7562# = LOCI GPRS: FF FF FF FF FF FF FF FF FF FF FF FF FF 07
    #*7632# = Sleep mode Debug: For cmd set DEBUG AUTONOMY in ci hard.opt
    #*7638# = Sleep mode Debug: Not Available in ci hard.opt
    #*7666# = SrCell Data RAC 26 NM0 2
    #*7673# = Sleep mode For cmd set DEBUG AUTONOMY in ci hard.opt
    #*7683# = Sleep variable 10000008 PACK IDLE MODE SLEEP DSP ALLOW
    #*7693# = Sleep Deact/Act
    #*7722# = RLC bitmap compression activated/deactivated Mobile must be restarted!
    #*7728# = RSAV done
    #*7785# = Reset wakeup & RTK timer variables
    #*7828# = Task screen be done
    #*7878# = restart
    #*7983# = "Voltage/Freq CMD: Set SWITCH VOLT FREQ FTR in ci hard.opt"
    #*7986# = "Voltage CMD: Set SWITCH VOLT FREQ FTR in ci hard.opt"
    #*8462# = Sleeptime since SwitchOf Caution: Set DEBUG AUTONOMY in ci hard.opt
    #*8465# = Time in L1 CMD: Set SWITCH VOLT FREQ FTR in ci hard.opt
    #*8466# = "Old Time Caution: Set DEBUG AUTONOMY in ci hard.opt"
    #*9795# = wtls key
    #7263867# = RAM Dump (On or Off)
    #7465625*228# = Activa lock deactivated
    #7465625*2827# = Auto CP lock deactivated
    #7465625*28638# = Auto Network lock deactivated
    #7465625*28746# = Auto SIM lock deactivated
    #7465625*2877# = Auto SP lock deactivated
    #7465625*28782# = Auto subset lock deactivated
    *#06# = IMEI number:
    *#1111# = "S/W Version VM610.02"
    *#1234# = "Dev. Version M610DXGI4"
    *#2222# = "H/W Version REV1.1"
    *#232337# = "Bluetooth-A ddr nap uap lap 0012:47:0000 01"
    *#4777*8665# = GPSR Tool
    *#7465625# = Interrogate menu
    *#7465625# = Interrogate (Check the phone lock status)
    *#8377466# = S/W Version VM610.02 H/W Version REV1.1
    *#8377466# = Same SW/HW version thing (S/W Version VM610.02 H/W Version Rev1.1)
    *#92782# = User Agent
    *2767*688# = "command *2767*6 Doesnot Exist"
    *2767*782257378# = Invalid no of parameter
    *7465625*228# = Activa lock personalised
    *7465625*2827# = Auto CP lock prequisited
    *7465625*28638# = Auto Network lock personalised
    *7465625*28746# = Auto SIM lock personalised
    *7465625*2877# = Auto SP lock personalised
    *7465625*28782# = Auto subset lock personalised
    U wud luv to play wit these codes............just as i did.........!!!
  • Babar Swatty
    Babar Swatty Sep 19, 2009
    *2767*226372# uSe this coDe it might wOrk............but if it dOnt let me Know.............k....!
I entered a code in samsung sgh m610 #*7337# then the network is limited service
Posted on Feb 06, 2010
Country code
hi to purchase the unlock code visit theunlockspot here they ask the country and the network name to which your mobile is locked then the imei number of your mobile .finally they will send you the codes to unlock your mobile.
Jan 19, 2012 | Samsung SGH-M610 Cell Phone
Unlock sim card
Using the codes you can unlock your mobile because its safe for your mobile......Get the unlock code for your samsung SGH-M610 model mobile from this site Unlocking4u.com , here it gives the easy instructions to get the mobile unlocked.......
Jan 04, 2012 | Samsung SGH-M610 Cell Phone
Unlock network lock samsung sgh-m610
With the help of the codes you can unlock your mobile network ,
Get the network unlock code for your samsung mobile through this site Theunlockspot.com , it has the best instructions and simple methods for getting the unlock code for your mobile at a safe way........
Nov 08, 2011 | Samsung SGH-M610 Cell Phone
You'll need to purchase an unlock code.
You will probably find a number of companies via google a I have used a couple, which I'm not sure I'm allowed to post here so I recommend you visit Unlock-Zone.com, which is nearly perfect and they were recommended highly in the cell phone forums.
Click the unlock your phone and select the mobile phone, current service provider to get the available unlocking service which ranges from $5 to about $25, depending on the model of phone you have.
Nov 08, 2011 | Samsung Bargaincell Original OEM...
Hi.my step daughter has locked herself out of her phone and we dont know wot the puk code is. for a pink flip samsung phone gte1150i please can you help
Hi there.
As much as we want to provide you a PUK code, PUK codes are sim card dependent. It is not like locked phone that we can unlock using codes or apps. The PUK code can be found in the sim package. It is on the card where you took out the sim card. If you no longer have it, you can call your service provider and ask for it.
Hope this helps.
Thank you!
Aug 10, 2011 | Cell Phones
Need to unlock samsung SGH-M610 - comes up with Network Lock - but I am not sure what network it was with? Thankyou
To get the security code to unlock the cell phone from the current cell phone provider so you can use it with a different phone provider, Please click on this link and follow my instructions :-
http://www.fixya.com/support/r4049238-unlock_cell_phone
If your phone provider does not help you then this WEB site it provides security codes for a small price.
http://www.mobileunlockstore.com/?gclid=CKDb2_y2558CFSlJagodxBkDHw
Try this WEB site also - Unlock Free
http://www.unlock-free.com
Mar 23, 2010 | Samsung SGH-M610 Cell Phone
Puk blocked
hi,
you can try downloading the phone's user guide for reference by clicking HERE. It may also help if you can call your service provider for instructions on how to use the PUK code.
Hope this helps.
May 10, 2009 | Cell Phones
Samsung Bargaincell  Original OEM Accessory Bundle SGH T809, D820, SGH T509, SGH D807, SGH T519 Trace, SGH T629, Sync SGH A707, SGH D900, Blackjack SGH I607, SGH T629, Ph M610, Sch U420, Sch U740, SGH T219 Logo
5,428 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
