Zenith H27F36DT 27" TV
Problem for Zenith H27F36DT 27" TV
Burning smell
By buse on Dec 10, 2007
Found capacitor in hv area burned and replaced. I have seen a lot of these in my shop and the result is the same....once the capacitor is replaced the set fires up but tyhere is always a phase problem with the picture and a tear. What else needs replacement?
Same Problem
Mar 28, 2009
-   CX3218 (160V, 2.2uF, 85 degrees Celcius) is the obvious blowout (well...the top's domed) and my set just clicks off from a circuit protection element (ZNR?) resetting (the power supply then tries again from the get-go.)
Not just capacitors but also series resistance of the downstream transistors can become deranged. Sometimes a resistor to ground can chill out an NPN element, sometimes that's not it; and resistors that can tough out the voltage needed are perhaps as expensive as replacing the transistor, even speculatively (e.g. by socket before committing the part.)
-   Saigua
Mar 28, 2009
-   Saigua
Dec 15, 2007
-   I have a 36 inch zenith with a burnt up cap in the power supply area. How do I find the caps value so I can replace it with the right one. Thanks for your help!!-   HUNTT
Solution #1
posted on Apr 04, 2009
Not Rated)
Saigua
Rank: Wiz
Rating: 80%, 228 votes
Simply replacing CX3218 worked...for 2 hours. It was destroyed shorted and the top domed enough to note.
So: I replaced that with 4 of the same value (a parallel pair of pairs in series, for the same value,) and they still get quite hot, but it lasts longer. More than 2^4 so far.
I'm not relearning Jet Grind Radio very fast, though.
Comments:
Apr 05, 2009
- The pic looks good; no tears, maybe visible side edges from less deflection, but they're straight edges in most scene lighting, never far off.  Likely either resistors or the horizontal output transistor base stage are falling off spec.  If they stop making plasma screens and it has to play The Sundance Channel  and IFC rather than Scooby Doo, I'll get in there with a bridge or other ESR meter.  Luckily neither the sweep phase circuit nor overall voltages (driven via the horizontal drive, typically primary to the flyback transformer) were disaffected.
Was this helpful?
Yes
No
Solution #2
posted on Apr 12, 2008
Not Rated)
jerryg50
Rank: Wiz
Rating: 84%, 887 votes
Get an ESR meter and check the ESR of all the caps in the horizontal scan area. I don't know the particulars of the model of set, but I would not rule out damage to the flyback, or any of the other components in the drive circuits to the deflection yoke. This type of fault can take some time to troubleshoot and work out.
You can read about capacitor ESR at this site:
http://wiki.xtronics.com/index.php/Capacitors_and_ESR
Jerry G.
Was this helpful?
Yes
No
Popular Solutions for Zenith H27F36DT 27" TV
Questions and Unsolved Problems for Zenith H27F36DT 27" TV
Do you recommend Zenith H27F36DT 27" TV?
Answer
Answer
I need to program a 27" Zenith Television Model # H27F36DT with a master remote from commercial... (More)
Answer
the menu button will not work; what should i do
Answer
Dear Service Professionals, My Zenith H27F36DT 27" TV will only go to 50% volume. How can I... (More)
Answer
i have a picture but no sound, i can hear some norse but that it
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Zenith H27F36DT 27" TV:
Top Standard Television Experts
Rank: Guru Guru
Solutions: 773
Experience: 30 Years of professional repair and design.
Ask Me
Find more Standard Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
