Question about Brother DCP 115C All-In-One InkJet Printer
Paper Jam my dcp-115c printer always showed paper jam,i checkd all option and open the cover but there's no paper left alone..is there a solution that i can bypass the paper jam problem..?tnx 4 whom can help me this probs..
Says paper jam but is not does'nt feed paper
This error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
Oct 27, 2010 | Brother DCP 115C All-In-One InkJet Printer
My printer says peper jam, but i see no paper
power down printer, wait for 30 seconds then power up again.
Sep 30, 2009 | Brother DCP 115C All-In-One InkJet Printer
ERROR MESSAGE DOC.COVER OPEN WHAT CAN i DO
replace the left side hinge.that may be broken
Jun 03, 2009 | Brother DCP-8040 Copier
Unable to clean problem
turn the rpitner of then check there is not any paper jam.
also refix crtridge after clean it.
Jan 03, 2009 | Brother DCP 115C All-In-One InkJet Printer
Hi there
My DPC-115 Show aways Paper jam.
Aug 07, 2008 | Brother DCP 115C All-In-One InkJet Printer
DCP 115C does not print
Check for foreign objects, such as a clip or ripped paper, inside the machine.
Open the scanner cover by pulling up on the lower right corner of the cover. Look inside the machine and remove any foreign objects. If you see jammed paper or another item inside this area, gently pull it out and then close the scanner cover securely
the manual states for this problem
"The machine has a mechanical problem.
OR
A foreign obstacle such as a clip or ripped
paper is in the machine."
Aug 05, 2008 | Brother DCP 115C All-In-One InkJet Printer
Paper jam
see here how to open your dcp (same procedure as the mfc215):
http://www.hstt.net/refill-faq/inside.html#Brother_mfc215c
The flashing of lights means that you are in the maintenance mode.
Apr 18, 2008 | Brother DCP 115C All-In-One InkJet Printer
Paper jam
try another photopaper of less weight. It could be that the rubber of the paperfeeder is stained with paper dust.
What you also can try is:
take paper tray out.
use a sponge with a rough side (to clean very dirty pans) to scratch
along the grey rubber and to give the rubber more grip.
Mar 22, 2008 | Brother DCP 115C All-In-One InkJet Printer
Paper jam
could your problem be room humidity? in fast, the paper doesn't have time to get saturated with moisture. see if the rollers that feed the paper are making contact with the sheet. perhaps the bottom idler roller isn't coming up far enough.
Sep 10, 2007 | Brother DCP 115C All-In-One InkJet Printer
Brother DCP 115C All-In-One InkJet Printer Logo
233 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
