Question about Nokia 6790 Surge Cell Phone
Nokia surge voicemail setup problem
I press 1 & go to my voicemail.
it gives me 2 options,
1: place call to a number on that system
2: go to my voicemail on that system.
but no set up voicemail.
i do not have a voicemail on this system
but i have tried both options & i still cannot figure this problem out.
i really need help.
How Do I Get A New Voicemail Password?
You must do a factory reset when a password is forgotten.
Sep 28, 2016 | Samsung SGH t340G Straight Talk Cellular...
Cannot find my voicemail app
On my model, it is not an app. You just press & hold the #1 button. If settting it up for the 1st time, it will give you directions. If you've already set it up, it will dial into your voicemail & let you know if you have any messages
Mar 10, 2015 | Tracfone Wireless ZTE Valet
Forgot my voicemail password how can I find it or change it
Try
step-by-step procedures.
1. Press and hold 1 or Voicemail key to call into the voicemail system from your wireless device.
2. Press the * key to skip to the Main Menu, otherwise go to Step 3,if you have new messages.
3. Press 4 for Personal Options.
4. Press 2 for Administrative Options.
5. Press 1 to Change Password.
6. Follow the prompts to enter a 4- to 15-digit password
7. Press the # key.
Oct 01, 2014 | Samsung Galaxy S II
Dont know how to set voicemail and directory
1.Press the "Menu/Select" button.
2.Use the up or down arrows to navigate to the "Voicemail Setup" option and press "Menu/Select."
3 .Navigate to the "Access Number" option and press "Menu/Select."
4 .Use the number pad to enter your voice mail access telephone number provided by your telephone company. Use the "Mute/Remove" button to delete any numbers entered by mistake.
5.Press "Menu/Select" to hear the confirmation code.
6 .Program the "Password," "Play," "Erase," and "Skip" options following the above steps, substituting the "Access Number" option in step three with the option you desire to program.
7 .Dial your voice mail by using the "Voicemail" button on the telephone.
8 .Listen and follow the prompts provided by your telephone company to set up your voice mail's greeting.
9 .Use the "Voicemail" button any time you wish to dial into the system to listen to voice mail. Use the programmed "Play," "Skip," and "Erase" options to navigate through your messages.
Apr 15, 2011 | Vtech Lands Phones
How do I change the number of rings before call goies to voice mail?
1. Press the star (*) key on your phone. Follow this symbol with the number "61." Press star (*) once more. Then, click "Send" to place the call.
2. Type the number one (1) and then enter the number for your voicemail box.
3. Press star (*) twice
4. Enter a time amount. This number will be how many seconds your phone rings before the call goes to your voicemail. This number can only be changed in multiples of five. The maximum time you can enter is 30 seconds.
5. Press pound (#). Your settings will be changed.
Mar 12, 2011 | Computers & Internet
Employee forgot his password and need to change the voicemail for new employee. Is there a way to reset the phone. Phone model is a Superset 4025. My phone number to the phone is (563) 690-3230 or email...
Each mailbox password is held in the system programming of the voicemail system. You need the system admin password for voicemail. Dial the access code for voicemail, if from a phone with voicemail then press * to get to the main greeting. At the main greeting dial * then the system admin mailbox number which is 99 for 2 digit ext numbers or 999 for 3 digit ext numbers or 9999 for 4 digit ext numbers then you will be prompted for the system admin passcode(default 1234). Press 2 for add/edit/delete (Never press 1 for new installation or you could delete all current voicemail programming and messages). Press 2 to edit mailbox, you will be prompted for the mailbox to edit, enter the mailbox number. Press # to skip to the passcode reset, enter the new passcode or press * to reset to default(999) then press # for each of the remaining parameters until you are returned to the mailbox menu which prompts for press 1 to add mailbox, 2 to edit mailbox, and 3 to delete mailbox, then hangup.
Dec 07, 2010 | Mitel Superset 4025 Corded Phone...
How do I set the voicemail number on my Motorola razor V3?
By pressing the number 1 then talk or holding down the 1 this will prompt you to set up your voicemail. An automated system should walk you through the setup of the voicemail. Listen careful and you'll be set up in no time. Good Luck!
Aug 12, 2010 | Cell Phones
Not able to access our main voicemail on Vodavi Starplus STS
To access the System Administrator Mailbox:
1. Dial into voice mail: From any phone on system dial 150
2. When the system answers, dial [*] + [#] followed by the System Administrator Mailbox number: (# 0 0 )
The system will announce: “Mailbox 15-00”, which is the System Administrator Mailbox number.
3. When requested, enter the System Administrator password. Default = [9]+[#]+[56].
How to program greetings
1. Access the System Administrator Mailbox as described above. The System Administrator Mailbox Menu plays.
2. Press [1] to access system greetings. The system will prompt you for the greeting number
3. Enter the desired greeting number.
For example:
1 = Default Day greeting
2 = Default Night greeting
3 = Default Temporary greeting
4. You will be prompted with the following three choices:
Press [1] to Review.
Press [2] to Record. You will be prompted to record the greeting
When you finish recording, press [#] to save the recording.
You can then
Press [*] + [*] + [*] to exit the system completely
Jul 07, 2009 | Vodavi Starplus SP7314-08 Corded Phone
Accessing Voicemail on LG KS360?
When you press numbers do they appear on screen as if you had pressed?
Is it that when you press a key your voicemail just does not respond to the option number you pressed?
If the answer is yes to these it sounds like you have turned off DTMF tones. If it is off, key presses look like they work but actually the phone is blocking the tone for that button from being sent down your line. People sometimes turn off by mistake or to stop their mobile number being visible when calling someone. If you look in menu and make sure DTMF tones are ON it should solve your problem? Hope that helps?
Apr 26, 2009 | LG KS360 QWERTY Keyboard Phone BRAND...
Voicemail answering
Contact your mobile service provider's helpdesk for further assistance on activating your VM
Aug 28, 2008 | Motorola Mobility RAZR V3
Nokia 6790 Surge Cell Phone Logo
806 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
