Question about Linksys Wireless-G Broadband Router
I have a wt54-g broadband router. when trying to go wirless everything went through fine except 1 problem it says cannot connect to the internet. Any way to solve this?
  • 11,896 Answers
Unplug house connection or router for 30 seconds, then do the linsys for 10 seconds and plug back in. This should reset everything to work correctly. If needed, reset ip address on your pc. Set up home network if necessary.
Posted on Sep 12, 2009
After using TP-Link TL-R480t+ Router Video streaming from internet at sites such as youtube does not work at all
Hi ,This is Clare Su from TP-LINK support technical force.To you issue,I have the following recommendations:1. try to use only one line to connect to the internet,and see if you can watch the video on youtube2.if you can see the video with one line connected to the internet.Then,you can get another internet line with the router.And you can try to set the rule to the website: youtube, let the flow from youtube come in and out just from one wan port.if you can't solve the issue with my recommendation,you can email me. I will help youas soon as possible.My email is:clare.su from tp-link.com
Nov 20, 2011 | TP-LINK TL-R480T+ Broadband Router 2xWAN,...
How to configure linksys wireless-g 2.4ghz broadband router i am using windowes xp,i have two LAN card in my pc.through internet sharing i connect linksys wirless router.wifi is working fine .i am able to...
try to factory reset your linksays and then connect your device.
after connection of your device re configure your linksys again with 192.168.1.1 IP address
Mar 16, 2010 | Computers & Internet
Cant connect to internet using the ethernet cable on virgin broadband
OK find a computer thats already connected to it, and match everything to it except the ip address, if you don't have another computer connected to it go to the routers settings and pull up all the info about wep, dsn servers, write it all down then write everything in the security settings of local network then you should get internet.
Feb 09, 2010 | NetGear DG834G Router
My Wireless-G Broadband Router was working fine until yesterday when I lost the connection. I have tried everything I know to do to get the connection back. I turned off all the computers; the modem, and...
If you can access the configuration page of the router then check the IP configuration. Check WAN and LAN configurations. IP 192.168.1.1 or 192.168.0.1 will able u to access configuration page. Username and password hopefully be admin admin.
Regards;
Hasan
Dec 27, 2009 | Linksys Wireless-G Broadband Router
I have a WRT54G ver.6. Was working fine until I went fron DSL to Broadband(cable) Now system won't connect. ???????
Are you attempting to use the device as a router or a switch?  Because if when you switched to cable you got a new router with it this device may be trying to steal this devices capabilities. Im assuming there are five ports, one to plug the Internet into and another to plug in the devices you wish to connect. Try plugging the Internet Ethernet cable (directly from your cable modem) into one of the four device ports and NOT the singular Internet port.
Nick
Sep 03, 2009 | Linksys Wireless-G Broadband Router
Laptop finding router but no internet connection
If you can connect directly to your virgin Media Broadband and get internet then your laptop and broadband router is fine.
The wireless router appears not to have a DNS entry and you will need to add that manually.
I suggest that you connect directly to the Broadband modem, be sure you can get onto the internet. Once you have confirmed you can get onto the internet you need to get the dns information from your Broadband modem for later.
once connected directly to the broadband modem, click start>run> then type "CMD" then click open. you will get a prompt type the following and record the DNS Server ip addresses.
"ipconfig /all" then hit enter
this will display your ipaddress information but mostly you need the DNS server ip addresses.
once you have recorded them rerun the install, but this time instead of at the end of the install where it shows the Wireless router information you can modify or change it and add the DNS server entries.
Also by default most wireless routers ip address is 192.168.1.1 and you can type that from a internet explorer and change it from there as well. I believe it's no ID or user name and the password is admin.
Good luck
Jan 28, 2009 | NetGear WGR614 Wireless Router
Internet wont work
hello!
-- who is your internet service provider
-- what is the operating system of your computer?
-- is this working fine before or is this a brand new router
you may try this and see if this help solve your problem. make sure your computer is directly connected to the router
Step 1: Shutdown the computer.
Step 2: reset the router while power on then Unplug the router’s power cable.
Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear stable.
Step 5: Plug in the router's power cable once the modem’s lights appear stable.
Step 6: Power on the computer on and configure the router settings
Step 7: test the Internet connection.
May 08, 2008 | D-Link AirPlus DI-524 Wireless Router
Netgear Wirless Router
You need to make sure your internet is still working. Its possible the storm caused some damage to the dsl line
Can you plug a normal broadband modem in and connect to the internet?
If you can, then try unplugging your router and plugging it back in, give it a few mins to boot up and try again (if you havn't tried this already)
If still no luck you'll have to do a master reset and set your router back up and try that, however at this point I'd guess the storm killed your router.
If you havn't got a broadband modem that plugs strait in, then ring your ISP and ask them if they've had any problems thier end.
hope this helps
Tony
Feb 27, 2008 | NetGear RP614 Router
How to connect linksys router with aztech adsl modem
To setup your router
first check..
Connect the Broadband modem to the computer using an Ethernet cable without the router installed and make sure that the Internet connection is active. If it is not, contact your Internet Service Provider. If it can go online,
to setup connection..
Step 1:
Connect the Broadband modem to the router’s WAN or Internet port.
Step 2:
Connect the computer to any available numbered port (1, 2, 3 or 4).
NOTE: In this example, we’ll connect the computer to port number 3.
Step 3:
Make sure the power adapter is plugged to an available power outlet.
Step 4:
check if you are able to go online wired..
if not your router has to be configured first,
to config your router i need some more information
your internet service providers (isp)name , and how many computers do u have totally..
Nov 16, 2007 | Computers & Internet
I want fast help..how to get connection between linksys router and aztech modem
first check..
Step 1:
Step 2:
Step 3:
Step 4:
Linksys Wireless-G Broadband Router Logo
170 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
