After first turning the computer on, the monitor screen image will sometimes display: off center vertically or horizontally, tinted off color, as lines, or not present at all.
SOMETIMES pushing the monitor power on-off switch will produce the corect image. When this fails, disconnecting the power plug and reconnecting it once or sometimes several times will produce correct image so screen is fine and useable after the fussing with the tweaking proceedures described.
I have tried changing the monitor cable...no change.
This acts like some sort of signal variation at start up and I am wondering if that or whatever is causing the problem is fixable at reasonable cost.
Monitor is a Sony SDM-HS73 LCD 17 Inch which I especially like and has no other problems meaning I would spend a moderate amount for repair or repair myself if it needs a part replacement and part is availab;le.
Comments:
Sep 12, 2009
- Thank you for your reply.
I will try another monitor with video card first.
Will take time to get monitor,
Will try to get back to you tomorrow. (Sat 9/12)
This sounds like a video card issue. I would try changing all settings to default or update video card drivers. Adjust screen on monitor if it has adjustments. Try different monitor with video card, and monitor on different pc if possible.
The screen should have a auto adjust feature. If you are using the Blue - VGA cable this may happen sometimes, it happens on my fully working asus monitors when I use a VGA cable instead of DVI.
to adjust the screen or run a auto adjustment .
Press Menu, press up or down and select A - screen and press the OK button.
Press up or down to select Auto and press the OK button Make the appropriate adjustments of the screen’s phase, pitch and horizontal/vertical position for the current input signal and store them.
press up or down to select the enter or a U turn like symbo and press the Ok button to return to the mennu screen, close the menu.
will not show display power button does not work(stays on) when connected to 110 display says -no...
(More)
will not show display power button does not work(stays on) when connected to 110 display says -no computer connection-- tried new cable and other computers--same result
I have a Sony SDM-HS73 Monitor and the screen gets distorted and them will go crazy with lines and...
(More)
I have a Sony SDM-HS73 Monitor and the screen gets distorted and them will go crazy with lines and then will go back to the normal screen.
plugged it into my laptop and did the same thing, so it is the monitor which is only 5 yrs old. Is...
(More)
plugged it into my laptop and did the same thing, so it is the monitor which is only 5 yrs old. Is this all I can get out of this monitor? Maybe need another brand?
