Question about Whirlpool CAM2752RQ Coin Operated Commercial Washer
The coin mechanism is hard to push the coin slider, but it works.
I opened the opening to the timer/mechanism and removed the hex bar but the coin holder would not come out. Can anyone help? I appreciate any advice.
Hank
  • 93 Answers
Coin mech is held in place with 4 screw heads in key hole slots.
Move the mechinisim UPWARDS about 3mm and wiggle it around to disengage the screws.
The hex bar is only used to stop the mech going upwards.
Posted on Sep 12, 2009
Testimonial: "I found this advice very useful and accurate. Thanks."
I tried to remove and replace the timer in my GE coin-op washer, after I removed the coin slider out of the box, I still couldn't take out the timer. What is the proper way to remove the timer?
YOU MAY HAVE TO REMOVE THE WHOLE COIN BOX NOT JUST THE SLIDE OUT PANEL, THE BOX IS SCREWED IN AT THE BOTTOM , UNDERSIDE OF THE LID BE VERY CAREFUL AS THE LID CAN BE DAMAGED IN REMOVAL
Feb 06, 2017 | GE Washing Machines
Drivers side slider on 2001 Ford Windstar is jammed. How canI get it to open?
The door lock is not working. Operate the remote keypad, the driver's armrest door lock switch, and the overhead switch until you hear the latch work, then open the door. If this approach fails, 10A FUSE 11 in the central junction box may be open or the rear electronic module may have failed. Once you have the door open, apply WD-40 to the mechanical parts of the latch to prevent future problems.
May 07, 2017 | 2001 Ford Windstar
Speed queen commercial dryer model sdg109wf, the coin compartment is stuck because of compartment was full, after emptying the coin slider doesn't come out so we cant use the dryer. what is the...
Oh your bringing me back to the early days of my appliance repair career when i only serviced coin operated washers and dryers. Not in the coin box but the cover on top where you would get access to the timer is a bolt that holds the coin slide to the coin box asm. remove that bolt(if i remeber from 25 years ago its a 5/16th inch hex head and brass colored) and the coin slide will come out and then gotta kinda genlty presuade it in with a hammer so the coin will drop through or pull on the handle ya would push, to free it up and remove stuck coin
Aug 20, 2011 | Dryers
Washing machine wont come on but i check the plugs and the push button are okey . you know any other parts that needs to be replace ? thank you.
If this is a kenmore front loader (boxy type made by frigidaire), the button must be
depressed for several seconds. The second problem with this model is the "coin
mechanism" cam must be in the correct position to operate the machine. If someone
puts in coins two times without starting, it can get out of sequence with the timer.
If you have a key, open coin box and move the metal arm back until the cam advances
to just before the big dip. (with the unit unplugged). The next cycle will allow the
arm to drop and engage the microswitches. If you don't have a key put coins in the
slide mechanism as though you were going to start the machine and
depress button until machine starts, this will reset the cam to the correct position.
Hard to explain but if you look at the coin mechanism, it will become obvious.
If you need a new mechanism it is called the "start mechanism" for front loaders.
Hope this helps.
Apr 16, 2011 | Kenmore 3.1 cu. ft. Coin Operated Extra...
We have a maytag dryer that is coin operated in our home. We want to shut the coin operated part off. how do we do that?
remove change acceptor usually 5/16 stud bolt in timer mechanism, theb remove change slot stops and reinstalll mechanism and bolt then just push in and pull out just like if you would of used change but dont need two
Jan 31, 2011 | Maytag Coin Operated Stacked...
Coin operated machines: slide mechanism is not moving back.
I had a coin washer and dryer.The slider has little fingers(metal)that slide over the coins.If the coin isn't placed and the slider is pushed hard will jam. Mine had a side cover with a lock. Open that and there is a long rod that has to be unscrewed to remove the lock box,then you should is what went wrong.Hope this helps>
Jul 04, 2008 | Whirlpool CAM2752RQ Coin Operated...
Whirlpool coin operated washer and dryer
you need to take the coin slot out by using a socket wrench. then you need to flip the slot over and take the screws off. there is going to be two more screws to unscrew. take off that piece and also the claw like coin catcher. form here on out you should be able to remove as many slots as you need to.
Sep 06, 2007 | Washing Machines
DVD loader mechanism
It is called the slider assy. The slider moves the laser assy back to home or start position. It is a small belt underneath or there is gunk or hair in the gear mechanism. A very common problem with CD/DVD players/recorders. Very good though that you saw it was not comming back to home place. I wish I had a manual to assist you but I do not. Im telling you the most common problems with the slider mechanism. Good Lck
Oct 08, 2006 | Sanyo DVW-6000 DVD Player/VCR
Maytag MAT12CSDAW
Leep, open the hatch that the timer sits under. You will see the timer and actuator that the coin tray pushes to start the wash cycle. You can rotate this cam clockwise until it gets to it's home position, ususally right around the 12:00 position. Good luck
Jun 20, 2006 | Maytag MAT12CS Top Load Washer
Washing Machines Logo
536 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
