Question about Apple iBook G4 (Z0AZW13397068) PC Notebook
How do i find out if i have protection on my g4ibook laptop
  • 600 Answers
It depends on what protection you want, if you go to system prefrences then select security you options, if you leave your computer unattended then check (put the curser on and click) the "disable automatic log in" option and you can decide if the other options are good for you ,these are all in the general tab, the next tab is file vault, the header says it all, if you need this choose a password that is strong but do not forget it or your information is lost unless you have mates in the CIA! The last tab is firewall, the options are explained I usually dont bother and as yet there are no OSX mal ware known exceppt some minor problems with Office 07 (I think) You can get 3rd party anti virus but it seems pointless just now.
Posted on Sep 12, 2009
    President:
  • 778 Answers
Register it at apple.com to see it it's still under warranty? Once the machine's serial number is registered you should see the AppleCare status.
  • Frank  Fernandez
    Frank Fernandez Sep 12, 2009
    I must have misunderstood, I took "Protection" to mean like warranty or service protection. Instead of "Protection" as in maybe a better word "Security"?
Tracking protection
ask sony for hdd protection software, or got sony site and download software for your laptop
Jan 19, 2014 | Sony VAIO Notebook
I purchased the Toshiba A665-S6086 approx 1 month ago. The battery on the computer seems very loose. Should it have "give" in it or should it be more stable? Also, the sound vibrates when you...
- The battery should fit snuggly. Have that checked.
- As for the sound problem, most likely, you have the "Hard drive protection utility" installed and enabled.
When you move the laptop, the hard drive protection kicks in and the read/write heads go into park position freezing the laptop for a fracture of second. Apparenlty this causing the sound to statter.
You can disable the hard drive protection for a while and see if it fixes the problem.
Also, try reducing the movement detection sensetivity in the hard drive protection utility.
Dec 31, 2010 | Toshiba Satellite A665-S6086 Laptop
How to remove write protection from pendrive?
Is the pendrive is protected in your laptop or in other laptop also? if its protected only with your laptop then follow the following steps.
  1. Go to registry, follow the path
  2. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\StorageDevice Policies
  3. There you will find a key "WriteProtect", check the value.
  4. If value is '0' then OK, if '1' then make it '0'
  5. To change the value, double click at the key "WriteProtect", one manu will pop up. change the value.
Note: Be careful while working with registry.
Aug 22, 2010 | Computers & Internet
I do not have a startup disc ,how can i start my macbook.i tried all the key combinations for intel-base mac. only the apple logo and rotating don,t know what appear on screen.please help.
does it have ram inside. safe boot is a must. it took me 5hours to hack g4ibook 4 my 1rst time fscky aka command line. or on your other mac do superduper app.
Apr 20, 2010 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Emachines model MS2257 HDD password
Can you get into it at all. If you can't, try to reset to the factory presets. You can do this with:
  • A restore CD
  • A XP/Vista disk and choose to re-format and re-install it again (probably your best bet)
  • *If you can get in as a guest* Re-install from hidden Restore drive. (Usually by pressing ALT - F10) You
Sep 04, 2009 | Computers & Internet
Simpletech external hard drive is showing as write-protected disk
Usually a protected hard drive has been in a laptop and the hard drive password is setup from the laptop's BIOS configuration. This password is embedded on the hard drive's chip.
This password protects the data from unauthorized access and must be removed before reuse in another laptop or as an external hard drive.
There are no backdoor passwords available and needs to be removed using that laptop's BIOS configuration, you need to know the password to enable you remove the password peotection.
Mar 29, 2009 | Sony Computers & Internet
How do I take my AG-8520 Audio/Video Receiver out of Protect Mode
go to the help and support section of your laptop, and type in protect mode. This should pop up a list of options for you to take it out of protect mode.
Nov 13, 2008 | Acer Aspire 3690-2196 Notebook
Cannot undo write protect
If you are talking about the shock sensor warning it is a hard drive protection that retracts the heads when the laptop is bumped and that will reset.
Oct 25, 2008 | IBM ThinkPad X60 Tablet PC
Computers & Internet Logo
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
