Question about GE Spectra JBP78 Electric Kitchen Range
Milk boiled over and leaked into glass window on oven door. Can I take it apart to clean it? Oven is self cleaning..will this be a problem?
  • 304 Answers
Yes...you can disassemble. Consult the owner's manual for door removal instructions. The manual can be found at this link with the instructions for removing the door on page 22.
JBP78 Owner's Manual
The link below will show you the door construction. Lay them out in the order they came apart. Make notes if you think you'll get lost. It will be no problem if you reassemble correctly. Good Luck
JBP78 Door Assembly Breakdown
Posted on Sep 12, 2009
How to clean inside glass oven door
Taking the door off the oven and lay door on a soft surface so as to prevent scratching ,taking the door apart ( Carefully ), allow for a large work space, lay out your screws, the glass you are trying to reach is an inner glass, so obviously self clean is not going to help. Good luck!
Oct 02, 2014 | GE Profile JTP56 Electric Double Oven
WHILE MAKING HOT CHOCOLATE THE OTHER DAY, THE MILK BOILED OVER AND SOME OF THE MILK WENT THREW THE SLITS AT THE TOP OF THE OVEN DOOR BETWEEN THE TWO GLASSES IN THE DOOR. IS THERE ANY WAY TO OPEN UP THE...
First, you will need a heavy blanket to place the door on once you have removed it from the oven. Open the door slightly, until it stays open by itself, about 15 degrees. Lift the oven door off of the hinges and place on the heavy blanket. (The hinges may snap shut when you pull the door up and off, but this is actually normal. It takes a bit of finesse to get the door back on the hinges if they will not stay out.)
Remove the 4 screws across the bottom of the door. Next, stand the door up with the bottom on the blanket and the front facing you.(Hold the door by gripping firmly around the middle edges to maneuver door)
Now, while holding the handle, remove the 2 screws that hold the handle on, unscrewing them just enough until the handle is free. (You do not want the spacers dropping off the screws) Hold the door together with one hand while placing the handle out of your way.
Once again, grab the door firmly by the middle outer edges and lie the door down, the inside facing down. You should be able to lift up the outer panel and glass and clean the inside of the outer glass.
Reverse the above procedure to reassembly the door. You can also take the door apart further if you have stains inside the other glasses. Here is a link to a schematic for your oven door.
http://www.searspartsdirect.com/partsdirect/partsdirect/showSubComp.pd?imageUrl=http%3a%2f%2fc.searspartsdirect.com%2flis_png%2fPLDM%2fR0211500-00004.png
Apr 15, 2011 | Kenmore Ovens
GE 1978 Slef Cleaning oven JKP26002wh 3 Layers of glass in door...How do I clean between the glass in the self cleaning aluminum window mechanism?
You will have to take the door apart to get to the glass that needs to be cleaned out. I would not recommend doing a self clean on an oven that is that old.
Dec 07, 2010 | GE JTP75CMCC Oven
Took apart glass oven door on a whirlpool. Where
Hello, bd_lft_up.gif bd_top_bg.gif bd_rt_top.gif bd_lft_bg.gif OVEN DOOR bd_rt_bg.gif bd_wpl_oven_door1.gif bd_wpl_oven_door2.gif clear.gif bd_lft_btm.gif bd_btm_bg.gif bd_rt_btm.gif Oven Door
#1 -- Oven door liner
#2 -- Oven inner glass
#3 -- Oven door hinge
#4 -- Retainer, glass
#5 -- Bracket, handle
#6 -- Door glass seal, top
#7 -- Door glass seal, side
#8 -- Oven outer door glass
#9 -- Door handle
#10
Read more: http://www.appliancepartspros.com/bd_whirpool_oven_parts.aspx#ixzz0pj5Z78oi
http://www.appliancepartspros.com .
Hope this helps.
Thanks
May 30, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Oven door window has streaks
you have to let the oven dry and clean and you should not put any oily foods on it..
Apr 11, 2010 | Frigidaire 27 in. Electric Double...
Over window cleaning
you have to take the door apart. by taking the frame of, many of the new oven doors will come out or of the oven by puling on the door up and it will come off the hinge.
Dec 07, 2008 | KitchenAid KERC507 Electric Kitchen Range
Cleaning glass on oven door
The marks may be on the inside part of the glass. If so then the door will need to be taken apart for cleaning. You can use a razor blade scraper and glass cleaner to soften the buildup. Self cleaning won't remove if it is on the inside.
Oct 01, 2007 | Crosley CE35100AA Electric Kitchen Range
G E Profile walloven
Unfortunately, you will probably have to call for service. It is a very detailed task with many screws, seals and insulation involved.
Sep 26, 2007 | GE Profile JTP56 Electric Double Oven
GE Spectra JBP78 Electric Kitchen Range Logo
178 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
 Fix Your Board
Fix Your Board
Are you a Kitchen Range Expert? Answer questions, earn points and help others
