Question about LG DU-27FB32C TV
Key Lock that will not unlock
I have a 37LG30 LG Television. It somehow got into key lock. The manual states to choose the menu selection and click to turn the key lock off; however, the keys are locked. No keys on the remote or the buttons on the television work to get to the menu screen. I have attempted unplugging the television hoping that it would reboot it, but have had no such luck. I am unsure as to what else to do that would work.
5 Suggested Answers
h_leslie
  • 27 Answers
SOURCE: unlocking the menu button on my tv
you just need a universal remote to program to your tv and remove the lock you can purchase one at walmart
Posted on Dec 12, 2008
SOURCE: LG RU-27FB30C. It's blocked.
http://www.newtvremotes.com/Mfrs/Zenith/ZenithTV/LP702.htm
VISIT THE ABOVE LINK AND ALSO SEARCH
RU-27FB30C on internet and you will get the manual
Posted on Mar 12, 2009
  • 43 Answers
SOURCE: how to unlock the locked
A lot of the main codes are 1234 or 0123 or longer in sequent (12345) give those a try...if no luck write back I will research.
Posted on Feb 21, 2011
  • 317 Answers
SOURCE: bought used tv -says key
try operatingguides.com or servicemanuals.co.uk
Posted on Jun 26, 2011
How do I get the caps lock light to turn on and off?
Unlock the Caps on Computers The All-Caps or "Caps Lock" function causes all letters to appear as capital letters when typing into word processing documents, emails or other files. This is convenient when needing to type numerous capital letters or All-Caps phrases, as you do not have to hold down the "Shift" button with one finger as you type the words. When All-Caps is stuck and does not respond to the "Caps Lock" keyboard button, a simple procedure overrides and shuts down the function. Open a word processing program. Press the "Caps Lock" button located on the left side of the keyboard to turn Caps Lock off. Type inside the document. If lower case letters appear in the document, Caps are successfully unlocked. Proceed if the text is in All-Caps. Hold down "Shift" on the keyboard. Press the letter "P." A lower case "p" appears in the document. Release the "Shift" button. Type the phrase "rint" directly after the lower case "P." The word "pRINT" is now in the document, and the document cursor is after the phrase's "T." Press "Enter" on the keyboard. The cursor goes down one line and "pRINT" becomes "Print." The "Caps Lock" function is turned off. Restart the computer to save the setting.
Enable the Caps Lock Key The "Caps Lock" key is loved by some and disliked by others. The key turns all letters into capitals as you type. While this feature is useful in some situations, a more common occurrence is that the key is accidentally hit and all the text typed is capitalized. The person typing must then delete the capitalized type and rehit the key to turn off "Caps Lock." If the "Caps Lock" key needs to be enabled, it indicates that someone has disabled or remapped the key. If a user wanted to, the "Caps Lock" key can be disabled and enabled through the registry or remapped through the control panels. Updating the registry for the keyboard will enable the "Caps Lock" key. Open the Notepad program. Type the following: [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Keyboard Layout] "Scancode Map"=- Select "Save As" from the "File" drop down menu. Navigate to the computer desktop as the save file location and choose "All Files" from the "Save as type:" drop-down menu at the bottom of the Save As window. Type "enable.reg" without quotes in the "File name:" field and click "Save." Minimize all open windows to view the desktop. Double-click on the "enable.reg" file. A box will pop up asking if you are sure you want to run the file. Select "Run" or "Yes" and then click "Yes" for the Registry Editor warning. Reboot the computer. The registry will be updated and the "Caps Lock" key will be enabled. b> Manually Update the Registry b> Click the "Start" menu, type "regedit" without the quotes and press "Enter." In older versions of Windows, Click the "Start" menu, select "Run," type "regedit" without the quotes and press "Enter." This will launch the Registry Editor. Navigate to "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Keyboard Layout" to view the settings. Right click on the "Scancode Map" setting and choose "Delete." Click "Yes" to confirm the deletion. Reboot the computer. The registry will be updated and the "Caps Lock" key will be enabled.
b> b> b> Disable the Caps Lock Key in Windows Your computer's Caps Lock key has likely only collected dust since you first brought the machine home. The Caps Lock key is beneficial if you want to type a long string of words entirely in capital letters, but this form of typing is not needed often. Consider disabling your Caps Lock key if you do not need it, or if you are tired of hitting the key accidentally while rapidly typing.
Restart your computer before beginning the process of disabling your Caps Lock key. Download the registry file necessary to disable your Caps Lock key. You have the option to disable your Caps Lock key or change the key to a number of different keystrokes. For example, you may choose to use the "ChangeCapsToShift" registry file if you want the Caps Lock button to function as a shift key. Double-click the registry file you have downloaded. A prompt will appear on your screen asking if you would like to add the registry file to your computer's registry. Select "Yes" to install the registry file. Restart your computer, once again, to complete the registry change. Upon reboot, your Caps Lock key will no longer function as a traditional Caps Lock key.
Disable the Caps Lock Key on a Computer The Caps Lock is an easy key to hit by accident, and often the user does not realize it immediately. When this mistake occurs, usually you must correct some text errors and your time is wasted. If you think the Caps Lock key is more of an aggravation than it is good, follow these steps to disable your Caps Lock key. Click on "Start" and select "Run". Type "regedit" into the textbox and hit "OK". This command will open the "Registry Editor" window. Select "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control". Double click on "Keyboard Layout" to open the folder. Open the "Edit" menu and choose "New" then "Binary Value". A new file will appear on the right side of your screen with the file name highlighted. Type "Scancode Map" for the new file name. Double click to open and type in "00000000 00000000 0200000000 003A00 00000000" into the Value data box. Hit the "OK" button. Close the "Registry Editor" by selecting "Exit" from the "File" menu. Restart your computer for the change to go into effect and enjoy life without the Caps Lock Key.
Feb 04, 2013 | ASUS R503u-rh21
CAP LIGHT DOES NOT COME ON
Disable the Caps Lock Key on a Computer The Caps Lock is an easy key to hit by accident, and often the user does not realize it immediately. When this mistake occurs, usually you must correct some text errors and your time is wasted. If you think the Caps Lock key is more of an aggravation than it is good, follow these steps to disable your Caps Lock key. Click on "Start" and select "Run". Type "regedit" into the textbox and hit "OK". This command will open the "Registry Editor" window. Select "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control". Double click on "Keyboard Layout" to open the folder. Open the "Edit" menu and choose "New" then "Binary Value". A new file will appear on the right side of your screen with the file name highlighted. Type "Scancode Map" for the new file name. Double click to open and type in "00000000 00000000 0200000000 003A00 00000000" into the Value data box. Hit the "OK" button. Close the "Registry Editor" by selecting "Exit" from the "File" menu. Restart your computer for the change to go into effect and enjoy life without the Caps Lock Key. Hope this helps
Jan 21, 2013 | Acer Computers & Internet
How to tell if caps lock is on
Some keyboards will have a light that goes on when caps lock is turned on
Type the following:
"Scancode Map"=-
Hope this helps
Nov 05, 2012 | Computers & Internet
Forgot lock code for lg vx3100
hi..
To lock the phone:
  1. Press the left soft key for Menu.
  2. Select Settings then press OK.
  3. Select Security then press OK.
  4. When prompted, enter the 4-digit lock code (the default code is the last four digits of the cell phone number).
  5. Select Lock Mode then press OK.
  6. Choose your preferred option then press OK:
    • Never
    • On Power Up
    • Always
To unlock the phone:
  1. Press the right soft key for Unlock.
  2. When prompted, enter the 4-digit lock code (the default code is the last four digits of the cell phone number)
thanks for rating
Jun 02, 2011 | LG VX3100
What's the best way to unlock a Caps Lock key that won't unlock by simply pusing the Caps Lock key to unlock it?
goto start > run > type "osk" and click ok...
On-screen keyboard will be displayed...
select keyboard in the menu bar... select 102 keys...
Use the Lock key in the on-screen keyboard... it will turn OFF/ON the CAPS lock
Jan 15, 2011 | Microsoft Computers & Internet
Unlock my sony ericsson for free
To unlock the keypad:
Press the * key and select Unlock.
To manually lock the keypad:
Press the * key and select Lock.
To activate automatic keylock:
  1. Select Menu > Settings > General (tab).
  2. Select Security > Automatic keylock > On.
May 24, 2010 | Sony Lands Phones
It unlocks easy in my pocket and calls people
ENV3 right? two options: option 1:go to settings and tool from the main menu (flipped open and pressed ok) Go to 6: Phone settings. Click security. Type in the last four digits of your cellphone #. Go to 4: Lock phone now. To unlock it: type the last four digits again. If you want to lock it on power up. Go to 3: Phone Lock on that same menu
2nd option: Click over on the keypad surrounding the ok button. Key guard will have a picture of a lock. Click OK on key gaurd. Go to 3: Unlock options. Go to press once or press twice. Then it will unlikely to dial numbers in your pocket. Go to 2: Keygaurd Timer. Set it for 7 seconds. Then, click cancel. Go to 1: Lock Now on the same menu for instance results.
Dec 02, 2009 | LG enV3 VX9200 Cell Phone
I want to put password for my Nokia N73 mobile
  1. Press the Nokia Menu key to the left of the 1 and 2 keys then choose Tools.
  2. In the Tools screen click on Settings
  3. In the Settings screen click on Security
  4. In the Security screen click on Phone and SIM
  5. Scroll down and select Lock Code
  6. Now type ‘12345’ and then choose OK with the left Selection key. ‘12345’ is the default lock code for the Nokia N73
  7. Next type your new lock code then choose OK with the left Selection key. Your lock code can only include the numbers 0 to 9. You will be asked to enter it again. Do this then choose OK with the left Selection key again. You will see a message that says ‘Lock code changed’
  8. Next click on Autolock period. You can set your phone to lock itself automatically after a period of inactivity. To do this click on User defined with the scroll key. Now enter the number of minutes after which you want the phone to automatically lock itself and choose OK with the left Selection key
  9. You will have to enter the lock code you set up and then choose OK, and finally you get the message ‘Code accepted’. Now after the period of time you set the Nokia N73 will lock itself and a screensaver will appear to show that it is locked
Unlock the phone
To unlock the phone select Unlock with the left Selection key then type the lock code and choose OK with the left Selection key. The message ‘Code accepted’ will appear and you will be able to use the phone.
Disable autolock
If you decide you want to disable the autolock the go back to the Security Settings screen (see above), scroll to where it says Autolock period then click with the Scroll key and click. Choose None. You will need to enter the lock code and choose OK with the left Selection key. The message ‘Code accepted’ will appear and the Autolock period will be reset to ‘None’.
Oct 09, 2009 | Nokia Cell Phones
How do I lock the keypad?
You can manually lock the keypad to avoid pressing keys by accident. You can still answer an incoming call and the keypad will lock again when the call is finished. The keypad remains locked until you unlock it manually.
Depending on your phone model, you can activate the automatic keylock. When the automatic keylock is activated, the keypad locks shortly after you stop pressing keys.
Please note: with some phones you can still use external keys when the keypad is locked. If you wish to lock the external keys you must lock them separately.
K530i To manually lock the keypad:
  1. From standby, press the * key.
  2. Select 'Lock keys'.
  1. From standby, select 'Menu' > Settings.
  2. In the General (tab), select Security.
  3. Select Automatic keylock > On.
  2. Select 'Unlock'.
Mar 31, 2009 | Sony Ericsson K530i Cellular Phone
Lock the keypad
K800i To manually lock the keypad:
  2. Select "Lock keys".
  1. From standby, select "Menu" > Settings.
  2. Select "Unlock".
  3. hope this helps Thanks and God bless
Dec 15, 2008 | Sony Ericsson K800i Cellular Phone
Televison & Video Logo
314 people viewed this question
Computer Repairing
Computer Repairing
