Question about Water Heaters
Water dripping from brass nut under water tank
  • 636 Answers
You will have to shut your water main off to repair. Drain plug , you may need a new o-ring replace 0-ring and turn water main back on, remember to relieve the air pressure with the relief valve.
Posted on Sep 12, 2009
Problem keeping my Rheem hot water heater light
What brand, model, and approximately how old is water heater?
This is important because water heater designs are changing quickly.
Did you remove door over combustion chamber to access thermocouple?
Newer Rheem water heaters have air intake under combustion chamber that has to be blown out using compressed air.
If this is different brand, then use mirror under water heater to see air intake.
Set water heater on bricks to avoid high water. Make sure drain line out of drip pan is 3/4" and terminates in good drainage location.
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html
Put brass garden hose cap over drain valve.
http://waterheatertimer.org/How-to-replace-water-heater-drain-valve.html
Aug 29, 2012 | Rheem RHG Pro40-40F Pro Series Natural Gas...
Water seems to be leaking from the top lid of my ge water heater
Make sure any water valves (Cold or Hot) for water heater are not leaking first. Gate valves may leak at the packing nut over time and drip on top of tank. If water is leaking from the top of the water heater itself the tank is corroded and water heater will need to be replaced.
RJ
Jul 16, 2011 | General Electric GE SmartWater Household...
Drain valve leaking. Gor replacement part. Cannot get old valve off . Does the whole valve come off , unscrew or pull off? serial number is RN1296A 18392. Will the new part fit the same New...
If valve is dripping, buy garden hose cap and screw onto valve.
Whole valve unscrews counterclockwise.
If valve is plastic, expect it to break off.
If valve is brass, use cheater bar on your pipe wrench.
I don't know that serial number or part number, but drain valves are standard 3/4" pipe thread.
Drain valve can be rusted in place and impossible to remove without draining tank and putting water heater on it's side.
Install new water heater so drain valve is accessible, and buy new water heater with brass valve instead of plastic.
Jun 15, 2011 | Rheem Water Heaters
It is leaking out of the top. not out of the hot or cold valves but out of a nut by the cold side.
Your tank is rusted out and needs to be replaced.
Link below is a troubleshoot for leaking water heater.
http://waterheatertimer.org/Leaking-water-heater.html
Protect yourself first:
If your tank is rusted, there is danger of rupture.
My friend welded his leaking tank, but he assumes the risk.
Ruptured tank can cause massive damage and water runs until it is shut off.
Hot water tank is under pressure because hot water expands and pushes against tank wall.
Turn off water to tank.
Turn off power supply:
Electric: turn off circuit breaker.
Gas: rotate knob to pilot so pilot stays lit but burner will not fire. To turn back on, rotate knob to ON.
Open hot side bathtub valve and relieve pressure on tank.
You can limp by with rusted tank by turning water heater on when hot water is needed.
Shower uses 5-9 gallons hot water
Bath uses 12-15 gallon hot water
Ordinary gas heater makes 41 gallons hot water per hour
Ordinary electric heater makes 20 gallons hot water per hour.
I buy water heaters at Lowes, Home Depot, Ace.
Look for scratch and dent models.
Buy drip pan for water heater.
Wrap electric heater totally with insulation except TP valve.
Buy new flexible connectors for water lines.
Offer 15% less than marked price on tank, because the store makes money on additional items.
> Most people can install their own electric heater since you just connect water pipes and electric wire, and it's done. Read link below since there are tips that help you buy and install electric.
> Generally people are nervous about installing gas water heater, so step-by-step instructions are shown on link below. Remember gas line is under less pressure than water line, so if you can install a water pipe, you can install gas line to water heater with crescent wrench, and soapy water to check for leaks.
How to install gas water heater:
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on water heater, or any do-it-yourself project.
Jan 13, 2011 | Water Heaters
We have a brand new rheem 40 gal elec water heater, after installation we have water leaking from the base of the relief valve, pooling up in the plastic fitting and making it way over the side all over...
Water heater should be set in a drip pan.
Otherwise, put 1 gallon bucket under TP release pipe to catch water.
http://waterheatertimer.org/Water-at-bottom-of-water-heater.html#drip-pan
When you say relief valve, I assum you are talking about brass valve located on top of tank or near top of tank. This is TP valve and a pipe connects to this valve and runs down to within 6" of bottom of tank. TP valve has a small lever on it.
If you are talking about tank drain valve located at bottom of tank, then add a comment.
Following information is for TP valve.
Dripping TP valve can be caused by 3 different thing:
1) Obstruction inside TP valve. Open TP valve for a moment to flush away particles and slowly lower lever back down. See if water stops dripping, if not, then replace TP valve
2) Defective TP valve: replace TP valve. Turn off electricity to water heater. Let heater cool for several hours so you do not get scalded. Close shut off valve located above tank on cold side. Open tub spout to relieve pressure, open tank drain or open TP valve and empty water below TP valve level. If TP is located on top of tank, not much water has to be drained. Tank is under press when hot, so be careful. Put teflon tape on new valve and install with big pipe wrench by turning clockwise until TP valve is very tight.
3) Overheating tank. TP valve is temperature-pressure valve. If tank water is over 150 degrees, the TP valve starts drizzling hot water to relieve tank pressure.
Lower tank pressure two different ways:
a) turn down thermostat
http://waterheatertimer.org/How-to-adjust-water-heater-temperature.html
b) install expansion tank on incoming cold water line
http://waterheatertimer.org/Water-at-bottom-of-water-heater.html#expansion-tank
Dec 19, 2010 | Rheem Water Heater Pressure Relief Valve
A SMALL DRIP CONTINUES TO COMe out of the drain valve. I drained the tank and refilled it but it continues to drip. It appears there is a white plastic drain knob which is where I attach my hose to drain...
Hello CHUCK The drain can be replaced with a LONG stem brass hose bib.The plastic is a piece of s*#$.They also sell brass drain caps for a easy way out.Just screw it on.
Aug 05, 2010 | Rheem 40 Gallon FVR NATGAS Low WATER...
Pop off valve dripping Rheem 50 gal electric valve at bottom
If you are reffering to the drain valve at the bottom of the hot water tank. It may be leaking due to the O ring being cracked or worn out. You can either drain the tank and replace the valve or you can buy a hosebib brass cap and thread it on the existing valve. There is no cause for alarm when doing this as this valve is just to drain the tank when replacing your hot water heater
Feb 23, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
New Westbrass water dispenser does not have the lines marked "red" or "blue" as described in the directions.
This faucet is the hot only version so it has two copper lines and one Santoprene rubber line. The copper line directly under the handle is the inlet from the wall - the second copper line attaches to the hot water tank by the corner. The Santoprene line attaches to the middle of the hot water tank. This faucet cannot be installed without the hot water tank.
Jun 13, 2009 | West Brass NEW Oil Rubbed Bronze Instant...
Nut in oil tank of 1991 toyota corrolla is stuck
You might want to repost this because it is listed in the plumbing section. You will probably get more answers on the car side.
Mar 20, 2009 | West Brass NEW Oil Rubbed Bronze Instant...
Water Heaters Logo
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
