Question about GE Washing Machines
I realized that my GE washer was not spinning because the lid actuator pad is missing. I can pull the hook to make it work, but it needs the pad. They cost about $30 for a small piece of plastic! Is there anything else I can do?  I believe the piece fell behind the clothes barrel into the machine.  Could I somehow open part of the machine to get it out?
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 105 Answers
All that lid pad is ;is a strong magnet in plastic. find a strong magnet in a craft store. fridge magnets wont work they arent strong enough.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/stephen_171aeeebef53a898
Posted on Sep 12, 2009
Testimonial: "thanks so much!"
Washing machine not spinning, stops & the letters LE flash, washing machine is a NEC NW-892 Millenium
It sounds like your lid switch is not working correctly, look to see if there is supposed to be a finger that protrudes from the bottom of the lid and enters a hole in the top of the washer, this is a safety switch to ensure the lid is closed, it is possible the actuator finger is broken or missing, If this is the case, I have heard of people manually actuating the switch to finish the load, I am not suggesting that because there is a safety issue, but it has been done. Your washer might not have an exposed actuator,it could be hidden under the washer top, but the LE error code indicates the lid is open.
Nov 10, 2012 | Washing Machines
GE Profile washer shows d5 how do I eliminate that so I can wash
Hi and welcome to FixYa, I am Kelly.
D5 is a lid switch error. It comes on when there are 3 complete cycles without a lid switch actuation. Either the lid switch has failed or something is causing the lid switch to not sense lid movement. This is a proximity type switch that uses a magnet to actuate the switch. Check to see that both the switch is in place and that the lid itself is not loose at the hinge or shifted to one side.
The lid switch is item 90 of this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5130746
http://www.appliancepartspros.com/part_details.aspx?part_id=3204102
You can try to unplug it for 6 minutes and plug it back in again to clear the code but if the lid switch is bad you will get the D5 code again. Not only that if you have children around it is not safe to leave the washer un-attended with a bad switch because the machine will not stop spinning in the spin cycle with a bad switch. If they lift the lid and stick their hands inside the end result can be quite horrific.
Thanks for choosing FixYa,
Kelly
Mar 27, 2011 | GE WHRE5550K Top Load Washer
My whirlpool gold top loading washing machine no longer spins the clothes
If it fills with water and agitates, then it is the lid switch that is bad or the actuator for it is broken or missing. Lift the lid and look on the right side of the body of the washer for a small oblong hole right next to the opening of the tub. There should be a paddle that looks like it seals the hole. That is the lever for the lid switch. If it is not tight to the hole, or is missing, the lid switch must be replaced. If it is there, check the lid for a plastic pin on the under side of the lid that would depress the lid switch. If it is missing, the actuator must be replaced. You can check the lid switch to see if it is making contact by using a small screwdriver or pencil to depress the lever. Do it slowly and you should hear a click. If the timer is on and calling for the machine to spin, the tub might begin to spin. If it does, you know it is the lid switch.
Mar 03, 2010 | Whirlpool Gold GS6SHEXNQ 25.6 Cu. Ft....
Spin cycle on a Whirlpool washing machine does not work
underneath the 2 solenoids that rock when the motor is running are 2 vertical metal actuating arms. With the lid closed and in the spin cycle this arm is moved by the rocking soleniod actuator that is pulled up by the solenoid when the usnit is supposed to spin. This in turn pulls the actuation arm reaward allowing the spin tube to drop the clitch pads onto the drive plate. If the solenoid is bad or the gliding inverted U shaped solenoid actuator center pin has sheared it will not pull the actuation arm to the rear and the unit will not spin because the clutch pads never are moved onto the drive plate.
Jan 11, 2010 | Washing Machines
GE spacesaver stack washer & dryer: The
the dryer won't heat up. everything else works. the drum goes around with clothes in it. it just won't heat up .
Jan 03, 2010 | GE Spacemaker Washer and Dryer Electric...
My washer will not spin out the water all the way - most things are sopping wet still! it's only about 5 years old
If I understand your concern it's draining some water, but not all, correct ?
This would appear to be an issue of a "kinked" drain hose, broken lid switch, or a partial blockage along the drain system. Missing any socks, undies etc. ?
It could also mean the unit isn't spinning, so the water in the clothing is settling to the bottom and not being "spun" out.
1) See if the lid switch actuator is ok, and the switch itself. the easiest way to check is to close the lid with your ear to the cabinet and listen for a "click" as the switch activates/closes. You could also stick a pen/pencil or small screwdriver in the slot where the actuator would "make" against the switch lever. (these test's must be done with the timer in a spin cycle, power to the unit and timer in the "on" setting, so be careful of any loose clothing, jewelry, long hair etc.
2) If it spins...even momentarily, check and see if the hose in back is kinked or collapsed, you should be able to visually inspect this part. (Not draining due to a kinked hose or obstruction can also prevent a proper spin and actually stop the basket from spinning almost immediately) If that isn't the issue, you'll need to pull some hoses off to search out where the flow is being obstructed.
If it doesn't spin...you'll likely need a lid switch assembly, part number 547225 retailing for $29.95US at repairclinic.com (no I have no affiliation, I work for Sears Canada)
These are the most common and likely problems. If they don't appear to be the problem you have, let me know we can go further into the trouble shooting.
hope this helps,
Good Luck :)
Oct 21, 2009 | Roper RAS6233KQ Top Load Washer
GE® 3.5 Cu. Ft. King-size Capacity Washer will not spin/adgitate
I would check the lid switch. On many machines there is no motion at all if the lid is up. If the switch is bad it may not realize the lid is down and nothing will happen after the machine fills. You can try a web search for how to test or replace the lid switch for your specific model. There are also several appliance repair sites with how-to procedures as well as parts. It's not too difficult to change the switch yourself on most washers.
Jun 10, 2009 | GE Washing Machines
Whirlpool Thin Twin washer/dryer
Check the lid switch, the machine will not spin or drain without the lid switch being activated. You should be able to see if the switch actuator is broken or missing, look in the slot where the lid's plunger drops into, if you can see the gray plastic actuator, set the machine in the spin cycle and try to depress the switch with a flat screwdriver, if it runs, the switch is cracked and needs replaced, if the actuator looks fine, and you can hear a distinct "click" when you press down on it, it may be a problem in the timer, but check the lid switch first, that's most likely the problem.
Sep 18, 2008 | Whirlpool LTE6234D Top Load Stacked...
LSQ9549LWO WHIRLPOOL WASHING MACHINE TOP LOAD NO SPIN @ RINSE CYCLE
You could have a bad lid switch or the hinge may need to be bent to make better contact with the switch. If your washer has a oval cut out on the right side and an actuator on the rt side of the lid... the next time it acts up don't open the lid and turn the tub, simply push down on the rt side of the lid, if it starts to work replace the lid switch. If there is no hole or actuator on the rt side, then the lid switch is on the back left corner, when you open and close the lid you should hear a click. If you don't hear a click or if you hear it when the lid is almost closed you need to adjust the hinge. There are 2 screws on the back of the endcaps on the control panel remove them and flip up the control panel, use a screwdirver to pop out the spring clamps on the rt and lt sides of the top panel. approx 3-4 inches from the sides. just insert the tip into the front most part of the clamp and pry back. unclip the lid switch, and pull the cabinet forward. You should be able to bend the hinge a little so it makes better contact with the lid switch. hope this helps.
Aug 21, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Spin cycle doens't work
Your hand probably won't depress the lid switch far enough to actuate it. Use a pencil, pen or old toothbrush handle to press the switch down and see if spin starts. If it starts, the lid actuator is likely broken or out of alignment.
Apr 09, 2007 | GE WBSR3140DW Top Load Washer
Washing Machines Logo
59 people viewed this question
Top GE Washing Machines Experts
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
