Question about Toshiba TDP D2 Multimedia Projector
Toshiba TDP D2 Projector
A shadow appears on the screen image, covering about a third of the screen image.  Replacing the lamp has not changed anything.
A mirror got loose in the opening from where the bulb sends the light to the "panel" It is blocking part of the light.
I'm not talking about one of the tiny mirrors that makes up the DLP, but there is silver box where the bulb light initially goes. the walls are lined with mirrors whose adhesive fails when exposed to great heat.
I can easily fix it, as i have fixed many of them from this problem.
Posted on Aug 26, 2008
Try cleaning the lens, if that doesnt work try taking the fan out and cleaning the place where the light goes.
Posted on Jul 01, 2008
How do you reset lamp hours on a Toshiba TDP-Tw420 projector?
1. Turn-off the projector by pressing the "ON/STANDBY" and unplug the power cord.
2. In the meantime, hold down buttons "ON/STANDBY", "MENU" and "INPUT and plug-in the power cord .
3. The lamp operation counter will automatically turn to zero.
4. Check if the lettering "0H" appears on the lamp operation counter in the status display.
Jul 31, 2011 | Toshiba TDP-TW420 DLP Projector
It suddenly stoped playing clearly. i can see some extremelly pale picture.my lamp is around 2000 hrs the projector is a 2004 model toshiba TDP-D2.any ideas?thanks panos
You need a new lamp. You can purchase one at:
http://www.shopvsc.com/Toshiba-Replacement-Projector-Lamps-s/143603.htm?searching=Y&sort=7&cat=143603&show=50&page=1&f-TDP%20D2=143381
Oct 25, 2010 | Toshiba TDP-D2 Projector Lamp
After replacing the lamp in the projector Toshiba TW300, it shall then appear on the screen saver, and then after a few seconds off. then it beeps and lit LEDs ON and LAMP. How to fix this problem? lamp is...
1. check the lamp and the rating for this unit it may not have the proper rating for the DLP and is shutting down to protect the circuit.
You may not have the right lamp installed.
Feb 09, 2010 | Toshiba TDP-TW300U Multimedia Projector
Toshiba lcd projectors tlp xc 2500
Verify "Key Lock" function is not enabled
Jun 14, 2009 | Toshiba Replacement Projector Bulb...
How to change toshiba TDP-S35 lens
i got a problem with my projector, the colored break up into pieces, i want to know if how much is the price to repair it.
Mar 19, 2009 | Toshiba TDP-S35 DLP Projector
HOW TO RESET TOSHIBA TDP-S8 LAMP
after installing the new lamp, hold the volume top & bottom key simulteniously, when green light indicate at panel start the projector & go to service there you may found reset lamp ? press yes the lamp will reset.
Feb 01, 2009 | Toshiba TDP-S8 Multimedia Projector
Bulb Replacement
the bulb hot indication has nothing to do with the lamp counter.u would have reset the counter as suggetsed by the manufacturer,
this problem is because of the following:
1) wrong bulb
2) cooling fans not working adequately
3) defective ballast
check the above for a solution
Jan 08, 2009 | Toshiba Replacement Projector Bulb...
Toshiba TDP S8 projector shuts down suddenly
The reason why the projector is shutting off is so the lamp doesn't explode. It's more of a safety feature on the projector, you can reset the lamp and it might work for another 500hours. If the picture is still pretty bright I can get you the reset procedure, but be warn that when the lamp does eventually blow it could shatter the glass inside, so be careful, it shouldn't hurt the unit.
Dec 09, 2007 | Toshiba TDP-S8 Multimedia Projector
Faulty projector
You will have to give a Make and Model of your Projector.
Could either be your lamp that needs replacement or a faulty Ballast ( lamp's powersupply )
Nov 09, 2007 | Toshiba TDP-T45U DLP Projector
Toshiba TDP D2 Multimedia Projector Logo
269 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
