Question about Poulan/Weed Eater No. Bvm200le 711482 24cc Gas Blower/Vac
Poulan/Weed Eater No. Bvm200le kills when taking it off choke or giving it gas.
  • 124 Answers
Most likely low compression caused by stuck piston rings or a scored piston and cylinder. This unit was made by Poulan and they have had an epidemic of this problem. The solution is to tear the unit down and put in new piston rings. Before you install the new rings you need to get a sheet of glass and some 600 grit wet dry sand paper. Sand each ring down about .002 to .003 and reinstall. This should solve your problem as long as you have good fire and the piston and cylinder is not scored.
You might also need to rebuild the carb.
Posted on Sep 14, 2009
Blower only runs with full choke. When I switch to half choke, it dies and won't start.
it may simply need the high speed jet opening up a bit (2 screws near eachother on the carb and the high speed is furthest from the engine)
failing that it needs a carb kit.... this is a serviceable item changed regularly.
Mar 14, 2011 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
It will run good on half choke but dies when it is put on run
You will need to a Poulan Tool and Adjust the Carb. There will be 2 round nobs on the top of the Carb. You can get those tools at any Lawnmower Repair shop for a few buck. Be sure to Take your machine in and show the guy because there are different nobs on different Carbs. If you own a Poulan you will need it all the time anyway. LOL Good Luck!!
Oct 23, 2010 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Powerpro 17" McCollich weed eater
hey harry the float inside the carb is stuck i would suggest rebuilding the carb
Jun 27, 2010 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
What spark plug does it take
just take the old one into the parts shop and they will know what one to give you, it may have a difrent number on the new one but it will be the same heat rateing,,,
Oct 24, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Weedeater will not run with choke open.
check your air filter,, and try if do the same thing you have to clean carb. out,, if you dont how just ask me,, thanks hope this help you
Sep 02, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
I have apoulan 446t pro I can get it started with it full choke but it will die as soonn as I try to turn the choke off what should I do
how long will it run on choke? the newer equipment are jetted really lean to comply with EPA requirements. it should run once it warms up.....if not the air fuel mix needs to be richer.
Jul 05, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Poulan/Weed Eater No. Bvm200le 711482 24cc Gas Blower/Vac Logo
448 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
