Question about Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water
I have an Amana TG21VW refrigerator and it seemed to have trouble turning on until you reset its built in timer. Thinking that the timer might have a problem, I got another compatible timer and put it in. Now it turns on but it has trouble turning off and everything is getting freezer burn. I put the level between 2-3 out of 8 and when it is at 3 it turns on but does not shut off by itself. The timer I bought and the timer I replaced it with are identical and say that they are 10 hour timers...also the fridge does not seem to have much other control components or switches or anything like that other than the timer. All the wires go into the timer from the cold level control switches and then go to the back into the compressor. Is their a sensor or thermostat that I am missing and where is it because it is nowhere inside the control panel that pops down when you take out the screws in which you find the timer. Please help.
  • amituttam82 Sep 12, 2009
    Please, where is this operating thermostat on the refrigerator. When I open the inside panel, all I see is the assembly for the control switches but no part it connects to except the compressor mechanism in the back of the fridge. Am I missing something? Once again it is an Amana TG21VW.
  • 415 Answers
It seem like you are stating 2 different things here and if you saying you are setting you thermostat setting for the frig and it runs and runs then the defrost timer will not solve this problem it is the operating thermostat that needs replaced not the defrost timer its the one that turn on the frig when you select a higher #
Posted on Sep 12, 2009
Red dial On A Amana bx21
If the fans are not coming on that would tell me the defrost timer=> R0131577 Defrost Timer is worn out and or stuck in defrost. Turn that red dial clockwise slowly until you hear compressor and fan restart.. If this solves turning on the refrigerator then you will need to replace the timer with the red dial because the clock inside is stuck and will contine to cause problems until replaced. Let me know if you have questions, Thanks Sea Breeze
7_8_2012_6_48_53_pm.jpgR0131577 Defrost Timer
Jul 08, 2012 | Amana ARB8057CSR Bottom Freezer...
My bottom freezer is seems to be running continuously with some ice now forming on back of freezer, but refrigerator is not getting cold.
  1. Defrost problem or the fan but as it is an amana it's a defrost terminator and /or heater.
  2. You will need to find your defrost timer(pict.3) and advance, turning the cam until you hear the compressor quit.
  3. Romove the rear inside panael in fridge.
  4. Inspect defrost heater(pict.2) and terminator(pict.3)
mastatech_2.jpgmastatech_1.jpgOne is not working but from experience I would say the first picture, the defrost terminator is not closing.
Good Luck Mastatech
Aug 22, 2011 | Amana 22.6 cu. ft. Side-By-Side...
Coil has ice up all the way what can i do as in fixing the problem?some step would be nice?
behind the vented kick panel on the front of the refrigerator is a defrost timer, when the refrigerator is running manually turn the timer until you hear a click which should indicate it has gone into defrost. let it defrost and then make sure the timer is turning, if not replace the timer.
Jun 07, 2010 | Amana ARS266ZBS Side by Side Refrigerator
The freezer isnt working, it is running not cold enough model number ARB190ZCS
Your model has a simple defrost timer inside fresh food compartment and behind control panel. I would see if I could manually turn the timer clockwise until defrost comes on and compressor stops. If after 25 minutes it does not turn itself back on turn the time again clockwise slowly until it restarts. Part number 67001036 Defrost Timer
Dec 16, 2009 | Amana ARB190ZCS Bottom Freezer...
Model BC21VW Amana Lower Freezer works, Upper Fridge not cooling
I want you to see if you can manually get the refrigerator into defrost. At the bottom of the front of your refrigerator and behind the kick plate is a defrost timer part number 10530703 I want you to pull the kick plate away from the bottom and there should be a metal mount with a hole in the center. Take a flathead screwdriver and slowly turn clockwise until the compressor stops. The refrigerator should remain off for about 25 minutes. During that time open the freezer door and listen for crackling and sizzling sound. That should be sounds of defrost taking place. If timer is not working properly you may need to turn again slowly clockwise after the 25 minutes and replace the timer. The only other 2 things that may be causing this is the defrost heater or defrost thermostat inside the back of freezer and behind the rear panel. Try this first and let me know what you find, Thanks, Sea Breeze
Sep 17, 2009 | Amana ABB1927DE Bottom Freezer...
Light is on, fan runs, compressor will not come on, compressor has never made a noise. Amana Distinctions model ARS2665A S/N 0010242568..side by side refrigerator freezer with ice maker.
Below bottom grate is a defrost timer. Turn slowly clockwise until you hear compressor start. If this works, replace defrost timer.
Let me know, Thanks, Sea Breeze
Mar 19, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Have trouble with frost build up with Amana with bottom freezer.
could be thermostat or defrost heater or defrost timer.you can check the heater with meters that check continuity.the thermostatis located on top coil and sometimes they will seperate.so look for those 2 things.most likely it will be one of the 2.the defrost timer is most likely good,if you hear your machine turn off and back on then the timer is good.
Mar 09, 2009 | Amana ABB1927DE Bottom Freezer...
Amana bottom freezer working fine but refrigerator not/ warm since 24hrs.
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Apr 28, 2008 | Amana ARB2517CC / ARB2517CB / ARB2517CW...
Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water Logo
280 people viewed this question
Top Amana Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
