Question about Canon PIXMA MP210 Photo All-In-One Printer
Paper Jam printer says E3 and printer status there is a paper jam when there is no paper stuck in the printer
In my case “E3” (paper jam error) was caused by a hidden tack pin that had fallen into the printer where the paper is loaded. The pin was lodged between the grey paper pickup roller and a tiny black plastic sensor in the back of the printer. The sensor’s function is to detect paper under it. One can turn the printer upside down and **** giving the printer a little shake to try and dislodge any obstructing objects. Be careful not to let scanner bed flop open or you might damage the printer I have found dead moths, lady bugs, cedar bugs, staples, paper clips, food, and tack pins in various printers which I have serviced. Failing that I would test the paper sensor for proper movement. The paper sensor is located 5 ½ inches or 14 cm in from the right front side of the printer approximately one inch (2.54 cm) below the centre of serial number decal which is behind a white ribbon cable which has blue writing on it. One can test the sensor’s movement by using a toothpick and applying slight pressure to the top part of the black sensor arm. Press very gently. Caution, do not push the sensor arm more than 1/8 of an inch (approximately 3 mm) or you might damage the sensor. If the sensor does not move or does not spring back then the sensor is either obstructed or broken. Before I fixed the printer, the paper sensor would move slightly but would not fall back into the correct position. I ended up disassembling and reassembling the printer to remove a hidden obstructing tack pin. It took me about 30 minute to figure out how to get into the printer. I’m a Tech and do not recommend disassembling this printer as there are many plastic tabs and some hidden screws. If however you want real challenge and don’t care about the warrantee or have nothing to lose then give it a shot. Hope this resolves your “E3” problem or at least sheds some light on it. TLC
Posted on Sep 17, 2009
2 Suggested Answers
Joed911
  • 4338 Answers
SOURCE: have pixma150. error code e3 (paper jam) do not
Perform an EEPROM reset:
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting for menu selection)
4) When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)
The number of the Reset button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset See waste ink counter reset
procedures below.
5 times Orange Destination setting See Destination setting
procedures below.
6 times Green Print head deep cleaning
11 times Orange Button / LCD checking
12 or more times Returns to a menu selection
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response.
Thanks, Joe
Posted on Jan 06, 2011
My paper had a paper jam because an object was stuck on it. After removing the object the printer still indicates E3 or paper jam. What do I do?
clean it easy with cleaner and check it proper if cut pieces in roller so that error regular show you open the casing and check it properly
Sep 25, 2011 | Canon PIXMA MP160 All-In-One InkJet...
Error 3 indicated - what is it and how do I fix it
E3 means that there is a paper jam. If you are getting the E3 error and there is not an actual paper jam you may need to do is simulate a paper jam. Try inserting paper crooked to cause a jam so that when it starts trying to feed the paper through it gets jammed. Then lift the cover up and take the paper out. You'll then get a bunch of the lights flashing. Turn the printer off and then back on and you should be good to go.
Mar 04, 2011 | Canon PIXMA MP150 All-In-One InkJet...
I have a Canon MP 210 with an E3 error message (paper jam) though there is NO paper jam. The paper feeder is spinning but doesn't grab the paper. Please help! Thank you, Robin
I think there is a paper jam or something stuck in the sensor that is making it think there is a paper jam. It may be a very small piece of paper which you have missed. Look again.
Jan 04, 2011 | Canon PIXMA MP210 Photo All-In-One Printer
My printer is showing E3 and there is no paper jam. How do I correct this so my printer will print
mp140/145 e3 error paper jam but no paper ,in my experience ,nag karoon nga ng paper jam at wala na ang papel pero still E3 pa rin !!!!!! ----na dis align yung sensor padel na tuwing tatamaan ng papel na syang swits on/off (example) sa pag pasok at labas ng papel
Nov 17, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Paper jam (e3) BUT no paper jam
make sure you open all check points, if yours has a rear feed through, look in there also. it only takes a tiny piece of paper to cause it to say that. use a flash light, have had to use one to find several that way.
Feb 03, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Error code E3 with no paper jam
it is problem your printer can not feed paper properly or problem paper feed sensor please try to resum button press when occard this E3 signal or clean sensor or claugth
Nov 21, 2009 | Computers & Internet
My canon pixma mp150 have an E3. How can I fix
The E3 error indicates paper jam. If there is no paper jammed then look that if something is stuck inside the rollers. This may solve your problem.
Aug 31, 2009 | Office Equipment & Supplies
Canon pixma mp 145
check if there is any paper stuck inside..E3 is for paper jam...
Feb 11, 2009 | Canon PIXMA MP150 All-In-One InkJet...
E3 code error mssg on printer MP160
As you will probably know E 3 on Pixma is paper jam.
Double check that there is no paper inside, and turn printer upside down shaking it a bit to check if there is any small foreign object (screws, pins, coins etc.) stuck inside.
When there is no jam in the paper path, this problem is typically caused by a broken part in the paper feed mechanism, in the page unit.
The paper feeding mechanism has two white plastic gears connected together with a central spring, near to the waste ink tank, at the bottom of the printer.
This are quite delicate, they often get stuck or boken, or you lose the spring, and the printer stays stuck with E3 error.
Nov 18, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Printer Error E3
E3 error -
If paper has jammed in the machine, clear the jam, reload the paper in the machine correctly and then press [Black] or [Color].
The above is direct from the user manual.
If there is no paper jam - look for any small pieces of paper that could be located near the roller sensor.
Oct 23, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Canon PIXMA MP210 Photo All-In-One Printer Logo
403 people viewed this question
old marine
old marine
