Question about NetGear DG834G Router
'The settings saved on this computer for the network do not match the requirments of the network'; this the error I get when I try to connect to my wireless home network. Is there a way to reset my router and change the settings?
  • 1,272 Answers
Well, follow the steps below for a better way to configure your connection:
Please follow the steps on a computer connected to the router so as to check the network key:
1. Open the browser(Internet Explorer or Mozilla Firefox).
2. Access the router usually http://192.168.0.1 else try http://www.routerlogin.com
3. Login to the router with the Username as admin and password as password (unless you have changed it).
4. Click on Wireless Settings'(under Setup) from the left menu.
5. Check if 'WEP (Wired Equivalent Privacy)' or 'WPA-PSK (Wi-Fi Protected Access Pre-Shared Key)' is selected under 'Security Options'.
6. If WPA-PSK is selected, copy the code entered in the passphrase.
7. If WEP is selected, copy the code entered in the key that has been checked.
This is the code required for connecting the wireless computer to the routers' wireless network.
In some cases, for security reasons the passphrase might show as asterisks. In this case type a new password and click apply. You will then have to use the same password for all the wireless devices connecting to the network.
Now perform the steps below on the wireles vista computer:
1. Click START, Click Control Panel then click classic view in left hand side menu.
2. In the main screen, open up NETWORK AND SHARING CENTER.
3. In the left hand side menu open up MANAGE WIRELESS NETWORKS.
4. If you see any name in the list, please select the name and click remove.
5. Once the list is empty, click on ADD, select the first option, ADD A NETWORK THAT IS IN RANGE OF THE COMPUTER.
6. Click on your network name SSID and click on connect. If you have a password setup on the router enter the security key.
7. This should setup the wireless network.
I hope the steps above will help resolve the issue. If you need any further help please email us back so that we can continue to work on a solution.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
Posted on Sep 13, 2009
  • NetGear Master
  • 32,281 Answers
You can check the router settings and change the wireless card to match.
If you want to restore the Netgear back to the default settings then :-
On the back of the router there is a small hole marked RESET, insert a straighten paper clip into this hole for a few seconds until the LED lights flash.
To access the router configuration open a browser and type http://192.168.0.1
then login = admin and PW = password
Don't forget to change the password.
After you configure the wireless settings then you need to configure the wireless with the same settings.
Posted on Sep 12, 2009
Our laptop won't connect to our network set up on our desktop home computer. The desktop is running Windows XP Home Edition V2002, and the laptop is running Windows Vista Home Premium V2006. When we try to...
In your laptop Open Control Panel > Network internet > Network and Sharing Center > Set up new connection or network > match with setting in your PC > Finish. Try to reconnect.
Feb 02, 2011 | Acer Computers & Internet
Wireless security settings on laptop do not match network settings
You will need to change the existing connection to match the "new" settings. I have had this issue with visita as well. If you open the wireless connections, go to advanced settings click on the "saved" SSIDs you can either delete the exisiting one, and start over (easy) or you can modify the settings to match the "new" upgraded system. Visita and XP store these for future use, problem is if one changes it "Doesn't match" so just delete the existing one and recreate it.
If they changed the password for the system or the type of encryption WEP to WPA etc this will correct the issue.
You may want to turn off the IPv6 which can also cause issues with Wifi in some locations.
Sep 05, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
I have set up my USR9111 but message says" The
The reason you get this error is the name used for this current network was previously saved with settings when used before. All you have to do is,delete this network from the preferred network list from your compute and re-connect your computer to the network and you will not receive this error message again.
Hope this helped. For further assistance please feel free to contact us.
Jan 21, 2011 | U.S. Robotics (USR8054) Router
Settings saved on other computer for the network do not match the requirements of the network now
This error message usually occurs in windows vista & win7 if the settings saved on the computer doesnt matches with the settings in the router...
You can get rid of this message by deleting the list of preferred networks from your computer...
To delete the preferred networks, follow the method given below...
Open control panel > open Network & Internet(double click) > open Network & Sharing center(double click)
On the far hand side left you will have an option called "Manage wireless networks" If you click that, you will see the list of preferred networks that are already saved in your computer... Now select your network, make a right click and select "Remove network" Select "ok" for all the warnings...
Thats it..! you are done..! Now search for the list of available wireless networks in range, you must be able to see your network name without any error mesages... Select your network and click connect, it will ask for the network key(if you have setup one)... Enter the key and get connected...! You must be able to go online now..!
Dec 14, 2010 | NetGear WNR2000 Wireless Router
The settings saved on this computer for the network do not match,
You need to remove the wireless network from your preferred networks list and reconnect to it.
1. Right click on the wireless icon (picture of a computer) on your system tray.
2. Click on Network and Sharing Center.
3. On the upper left hand side of the page , click on Manage Wireless Networks
4. Right click on you network name and click Remove/delete
5. Now reconnect to your network.
Jun 09, 2010 | Belkin Wireless-N Wireless Router with...
My question is ''thes settings saved on this computer for the network do not match the requirements of the network'' how to connect the wireless internet on my computer now? PLEASE see
See there are some old settings saved on your computer for the same wireless network name.
I believe the operating system on your computer is windows VISTA / 7 .
Now you will need to remove the network from the preferred network list. then add the new network on your computer and you will be able to connect to the network. Make sure that you have all the wireless settings of your network. If you are not sure about the wireless settings of your network then you will need to check the wireless settings of the network.
Apr 08, 2010 | WiFlyer - Portable, shareable WiFi base...
After we turn the computer on it is telling us that the "the settings saved on this computer for the network do not match the requirements of the network"
This may work for you. This is for Vista
Under network & sharing center ...... go to manage wireless network ...... Configure the wireless settings manually .....try to connect to network ......
Hope this helps.
Nov 08, 2009 | Belkin (F5D7230-4) Router (587009)
Can not connect to the internet via router
use the network set up wizard, new connection.
Oct 01, 2009 | Computers & Internet
NetGear DG834G Router Logo
550 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
