Question about Motorola Mobility MOTORAZR2 V9 Cellular Phone
How can i open my motorazr2??
My phone got all sticky with soda in side. and i want to clean it up because i know it still might work. the bottons are all stick from the inside. i want to open it so i can clean it up and see it can still work.
(i have clean it from the outside and i want to clean it from the inside).
  • 121 Answers
Place it in sunlight after removing battry......
open from back remove battry& place it in sunlight.............
Posted on Sep 12, 2009
We have a side by side Whirpool Ref Model #ED25PQ. It makes ice and despense ice inside the ref into the ice tray. Our problem is with the door closed we are unble to get ice thru the door into the...
I don't know if this is your problem, but my sister had this problem before. When I checked the area, it was clogged with dried soda. The kids allowed it to splash up when ice dropped into the glass. The sugary drinks will dry sticky and not allow the dispenser to dispense. I used very hot soapy water several times to melt the sticky buildup. Her fridge has been working every since. Good luck, it this is your solution
Aug 18, 2013 | Whirlpool ED5FTGX Side by Side...
Spilled soda on my camera sticky lens
Buy lens cleaner, to wipe off what you can, but in truth the lens should be dis-mantled to clean it properly not to mention the rest of the camera.
Mar 29, 2012 | Sony Cyber-Shot DSC-H70 Digital Camera
I have sticky keys (e, i, alt, space), how do i fix this? Also I can see dirt/grime when the keys are lit up, is there a way to clean it? Thanks
Hi
IF you know how to open phone. you can do it.
clean all key button with alcohol(91 % alcohol normally used for first aid)
that will remove all sticky material.
and you will have your phone works.
thanks.
Sep 09, 2011 | RIM BlackBerry Curve 8520 Smartphone
Acer aspire one 10.1 inch netbook. how to clean keyboard after soda spilled on it...it works but keys are very sticky
man, i hate when this happens. soda (sugar) and electronics do not go together very well at all.
there are keyboard foam cleaners u can buy at computer stores.. they do a well job on soda problems, but im sure not 100% unless of course u remove the keyboard from the unit and clean it with this, electrical cleaner and alchol on a q tip...
hope this help,s let us know if it does not
Jan 14, 2011 | Acer Aspire One AOD255-2136 Netbook
I wet my g1
I hated that happened to you but I hope that you have insurance on it. Anyway for the stickiness very lightly damp a  Q-tip or the tip of a towel and rub against the buttons that are sticky. Use water and a very small drop of rubbing alcohol. Now for the warning signal maybe just leave the phone alone for several hours or days and then test it later or open the phone take the battery out and see if it looks like the soda had gotten down in the phone . If it doesn't it might have a good chance of coming back on but if it does place the phone in a draining position so that the remainder of the soda can drain on a cloth or something. Please do not use a blow dryer if it is still wet because it might make it worse that what it is. But even though i don't recommend it if you want to try it hold the blow dryer back a few inches and move the phone in different positions as you do it. If all these fail (I'm not an expert) call customer service.
Mar 07, 2009 | HTC G1
I Cannot connect to Phone Tools via USB with Motorazr2 V9m?!?!?!?
I have the same problem as your's mine is also not listed on the List. What I did the first time I configured my MOTORAZR2 V9 is Open the main menu (I hope you do the same) >Select CONNECTION> CHOOSE between BLUETOOTH LINK or USB SETTINGS> In Bluetooth > Select SETUP>SELECT POWER ON. Now you have tour BLUETOOTH ON. USB SETTINGS is more easier all you need is USB TRANSFER DATA CABLE (as I understands it comes with your hand phone as in mine)
Feb 24, 2009 | Motorola Mobility MOTORAZR2 V9 Cellular...
Keypad of my motorola RZR2 V9 not working except for red button
clean pcb boar specially keypad board.. check vol. swicth and all switch located at side of fone if shorted...
Feb 19, 2009 | Motorola Mobility MOTORAZR2 V9 Cellular...
Sharp calculator
I had the same problem happen to me. What I did was carefully take the calculator apart using a T-10 Torx screwdriver to remove the back cover. I then used a compressed air can and blew air into all the crevices and holes in the calculator. I was able to dry almost all of the soda the spilled, however some of the soda dried and turned into somewhat of a sticky mess. I was able to carefully wipe the sticky parts clean with a tissue. After doing all of that my calculator worked perfect.
Nov 15, 2008 | Texas Instruments TI-84 Plus Silver...
Keypads not working in my motorola v9
check the side buttons...my v9 was shorted at the lowest button in the right side..... i remove bottons and now its all working!!
Sep 15, 2008 | Motorola Mobility MOTORAZR2 V9 Cellular...
Motorola Mobility MOTORAZR2 V9 Cellular Phone Logo
67 people viewed this question
Top Motorola Mobility Cell Phones Experts
Rami Obeid
Level 1 Expert
Richard Lane
Vernon Taylor
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
