Question about Nokia N95 Cellular Phone
Music player stuck on mute
The volume control decreses volume levels but does not increase the volume. At present it is at it's lowest and in the Mute position. How do you "Un Mute" the volume. Phone calls and message received tones play as normal and quite loud.
Everything lights up and is working,but i have no sound
Do you accidentally have it muted? The Mute button, located on PASSPORT's top panel and SmartCord. Have you turned up the volume on it? Volume Control (VOL) To increase or decrease the audio volume, press and hold the (+) or (-) volume control buttons located on the top case. A sample alert tone will be generated, along with a corresponding bar-graph on the display. Once you have reached your desired volume level, simply release the button. This level will be stored in memory. In Preferences Auto Volume is the default. This feature will increase the audio alert level automatically when the ambient noise in the vehicle is high. Good luck.
Mar 06, 2011 | Passport 9500i Radar/Laser Detector
Tip
To connect a music player or other audio device to your laptop
<br />If your laptop has a line-in jack, follow the instructions above for connecting a music player to a desktop computer. But to connect a music player or other audio device to most laptops, you'll have to plug it into a microphone jack. To do so, follow these steps:<br /><br />Click to open Sound. <br /><br />Click the Recording tab, click Microphone, and then click Properties.<br /><br />Click the Listen tab, click the Listen to this device check box, and then click Apply.<br /><br />Click the Levels tab and make sure the Mute button looks like this . If the button looks like this , click it to turn on sound for this connection, and then click Apply.<br /><br />Play some music or other sounds on your device to test the volume coming through your computer speakers. Select the slider under Microphone, drag it right or left to increase or decrease the volume of your audio device, and then click OK. You might also want to adjust the volume on your device.<br /><br />Note<br />If you hear noise coming out of your speakers, try reducing the volume on both the music player and in the Levels tab. The microphone jack is designed to receive sound from a microphone, which is different than sound coming from a music player
on Dec 14, 2010 | Computers & Internet
Tip
To connect a music player or other audio device to your desktop computer 1After...
    1After you've plugged a music player or other audio device into the line-in jack and turned the device on, follow these steps:
  1. Click to open Sound.
  2. Click the Recording tab, click Line In, and then click Properties.
  3. Click the Levels tab and make sure the Mute button looks like this
  4. If the button looks like this , click it to turn on sound for this connection, and then click Apply.
  5. Click the Listen tab, click the Listen to this device check box, and then click OK.
    Notes
    • If you don't hear anything, make sure the volume is turned up on the device.
    • You can also change the line-in volume on the Levels tab. Select the slider under Line In, drag it right or left to increase or decrease the volume of your audio device, and then click OK.
My hands free is on mute and won't come off mute .
Hi, Motorola H700 Wireless Headset does not go on mute, it might be from the volume control of the Motorola H700 Wireless Headset or from the cell phone volume control.
You can use this quick guide to know how to increase and decrease the volume control.
motorola.com/mdirect/manuals/QG-H700_9499A88O.pdf
Hope it helped.
Have a nice day.
Mar 01, 2011 | Motorola Mobility H700 Wireless Headset
My Sony Vaio VGN-FS690P has stopped playing sound. The sound card states it is working correctly. It does play one sounds, the sound when it starts and show the VAIO screen.
Hopefully this helps. Right click on your volume control icon. Open the "Volume Mixer," and make sure that nothing has the mute X on. Then right click on "Volume Control," and make sure that the volume control is checked to play all sounds, and that your Speaker box is checked. Next step is your music, if the sound was muted directly @ the music playback, this could be the problem. Open your Media Player and try to play music, if you cannot hear it, click on the mute button to the song playing. If your Player was shut off in the "mute" mode, then you will not hear sound. It Happened to me once. You will need to check all of your "Players" to see if any of them were shut off in "mute."
Ponder/Meditate/Pray for Peace.
Mary Oliveau { hugs }
Sep 26, 2010 | Sony VAIO VGN-FS690P Notebook
Acertravelmate4000 got it used,don,t know how to turn off mute,turn on or up volume
The volume may be muted. In Windows, look at the volume
control (speaker) icon on the taskbar. If it is crossed-out, click on
the icon and deselect the Mute option.
The speakers may be turned off. Press Fn-F8 to turn the speakers
on (this hot key also turns the speakers off).
The volume level may be too low. In Windows, look at the volume
control icon on the taskbar.
Fn-? Volume up Increases the sound volume. Fn-? Volume down Decreases the sound volume.
If this helps u let me know
regards
Jan 12, 2010 | Acer Computers & Internet
My windows media player has no sound,ya the volume
Assuming you did not get a device error while attempting to play there is a sound device thing in control pannel open it and tell it to place a sound icon in the taskbar once the icon is in the taskbar double click it and make sure all volumes are on high and make sure none are checked mute. If this does not work for you you may have a more serious problem and will need to repost.
Nov 24, 2009 | Microsoft Windows XP Home Edition
How can i set up the microphone on my acer ( aspire 3680 )
Go to Start - Control Panel - Sound - Recording - Recording and you will see a list of connected devices. Check that the Microphone is live and has a green tick and also that the driver name is present. Double click or Right Click the Microphone for setup options. If it is not working you may have to reinstall the sound driver.
If this is not working then check Start - Control Panel - Device Manager - Sound, Video and Game Controllers to see if there ay alerts or errors (highlighted in Yellow and Red respectively).
Also check Start - Control Panel - Device Manager - System Devices to see if there ay alerts or errors (highlighted in Yellow and Red respectively).
If there are no errors then you should be able to use the microphone successfully.
The volume may be muted. In Windows, look at the volume control icon on the taskbar. If it is crossed-out, click on the icon and deselect the Mute option.
• The volume level may be too low. In Windows, click on the volume control icon on the taskbar, and then use the slider control to increase the volume level.
• If headphones are connected to the headphone jack on the computer, your computer's built-in speakers will be turned off.
Oct 02, 2009 | Acer Aspire 3680 Laptop
Amplification does not work
It sounds like a source slecton issue. Try the following and if that does not help I would start with a simple stereo setup and source and work up from there.
The RV-8 is powered on, but there is no audio.
1. Make sure volume level is audible. Volume level can be
increased with the front-panel volume knob or the remote
control VOL �� and �� buttons.
2. Make sure audio has not been muted. The message “MUTE
ON” or “FULL MUTE ON” will appear in the on-screen and
front-panel displays when audio has been muted. To deactivate
mute, press the Mute button or adjust the volume level.
3. Check the INPUT SETUP menu DIGITAL IN and ANALOG IN
parameters to ensure the appropriate audio connector is assigned
to the selected input.
4. Make sure the RV-8 is receiving an audio signal. To do this,
follow the instructions that begin on page 2-29 to open the
STATUS menu for the current input source. Hint: (Use the "STAT2" Button on the remote.)
Apr 29, 2009 | Lexicon RV-8 V2.0 Amplifier
Disabling the mute in the music player
sometimes a gadget just gets confused and restoring factory settings can fix that problem. Go to menu-tools-settings-general-factory settings the phone asks Restor original settings phone will restart press yes it asks for security code. The default code for nokia is 12345. If this doesnt work enter this code *#7370# and the phone will reset. You then set it up as new
Jul 03, 2007 | Nokia N95 Cellular Phone
Nokia N95 Cellular Phone Logo
350 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
