I have a 2000 Ford Focus and the A/C compressor pulley is making a scraping noise when he A/C is turned off. The noise stops when the compressor is turned on. When the A/C is off the pulley makes erratic turns.
  • 2 more comments
  • maxmiddleson Sep 12, 2009
    What should the pulley be doing while the A/C is off?
    Should the pulley be rotating freely while the A/C is not running?
  • 10,515 Answers
if the noise goes away when you turn on the a/c then you either have a bad a/c belt or more likely a problem with the a/c pulley. The pulley and/or clutch may be failing and need to be replaced. Is this something you are planning on fixing yourself?
If you want to get it fixed from a tech, if it is the a/c compressor it can cost as much as $1000 to fix. If it is just a belt it should only be around $75.
If you do not want to get if fixed right now, only option would be to leave the a/c on while driving it until you get it fixed or remove the belt. I would advise to do this as soon as possible to keep anything from breaking.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Sep 12, 2009
  • taran_2005
    taran_2005 Sep 12, 2009
    Thanks for your response!!
    The bearing that carries the A/C pulley can act that way. Remove the
    belt and spring the pulley by hand and you should be able to feel the
    roughness.
    Might be a case that Due to Vibration, you might be hearing a noise but when it's running, it's in motion, so you might not hear any noise.
    Thanks.
    DO ACCEPT THE SOLUTION IF 100% SATISFIED!!
  • 11,896 Answers
The pulley will have to be lubricated on the bearings, or you will have to get gear puller and pull of the pulley and replace
  • Nate Stansfield
    Nate Stansfield Sep 21, 2009
    Yes it should. It spins freely.
Rattle noise coming from pulley area when ac is on in 2008 ford focus
If you have not performed any service, might be a good idea to replace the components that you have mentioned and check to see if the problems go away.
Jun 24, 2017 | 2008 Ford Focus
2005 ford focus zx4 ac compresser making noise when ac is turned on
Yes, it could be the ac clutch or the compressor itself.
Jul 08, 2012 | 2005 Ford Focus
My 2000 Ford focus was making a grinding noise when driving the power stering went out and I look under the hood and the belt was loose what do I do... O battery light is now on.
sounds like your belt broke. replace with a new belt. battery light is on because the belt is not spinning the alternator. If it busted you should be able to pull it right out. Make sure to check the tensioner pulley, alternator pulley, power steering pump pulley and ac compressor pulley for free play(if you can make it spin with your hand it's good) and make sure that they're not binding or making any grinding noises. If the belt has never been replaced, then most likely it gave out.
Sep 24, 2011 | 2000 Ford Focus
Grating noise from engine compartment then belt thrown off. Is this the water pump?
I would check a few things before saying its the water pump.I would check the idler pulley and the belt tension er and all the other pulleys on the alternator and power steering pump to see if they wobble or grind because of worn bushings or bearings.Then while you have the belt off free spin the water pump and listen for any noises and wiggle the shaft to check for any movement.If it wobbles and scrapes it would have to be replaced.
Jan 31, 2011 | 2000 Ford Focus
2000 Chevy Cavalier making a noise when air is shut off
This problem sounds like the aircompressor pully, the bearing is shot.
With the engine running and the air conditioner off there is a grinding noise, look at the compressor pully, does it wobble? Then turn on the air conditioner and the noise stops, look at the compressor pully again, the wobble stops? If so that's the problem.
Jun 27, 2010 | 1996 Chevrolet Cavalier
My 2005 ford focus making screeching noise!
Serpentine belt , idler pulley bearing?
Jan 24, 2010 | 2005 Ford Focus
Ford focus serpintine belt squeal
Yes a new belt the old one has gotten briitle and stiff from all the heating and cooling cycles.
Good luck dont forget to rate.
Jan 05, 2010 | 2000 Ford Focus
Just had aircon regassed on 2002 focus bowers working aircon light on but not cold at all
If freon was added because of a leak, it could have leaked down again. If freon levels are too low, the compressor will not switch on. Check to see if the center (it is connected to the compressor shaft) of the compressor pulley is turning.
Sep 02, 2009 | 2000 Ford Focus
Heating & Cooling Logo
15 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
