Question about Metabo WE14-150 Quick Angle Grinder
Just replaced the brushes in a Metabo WE14-150Quick Angle grinder
One side of the brushes has already worn down in just a matter of a few days, the other side still is good, what could be causing just the one side too wear down so fast, can you help me?
  • 2,176 Answers
When you replaced the brushes did you notice the tool throwing sparks? Generally when I work on these after replacing the brushes I have to clean the commutator to seat the new set. You could also have other problems, e.g. bad brush holder (did you replace as assembly or just brush) Let me know what happened to the first set and if when you plug in and try it does it come up to full speed.
Posted on Sep 12, 2009
    Problem Solver:
  • 5 Answers
The Ohio Carbon part number for the brushes for this grinder is #20-870 and they are $3.53 each. There is a minimum order amount. Though it sounds like this is more of a commutator/spring pressure problem there is a chance the brush grade was incorrect. Ohio Carbon Industries is a manufacturer and distributor of carbon brushes for nearly all electric motors. Call our sales dept. at 419-496-4456 or email them at sales@ohiocarbon.com.
Posted on Mar 20, 2012
    Problem Solver:
  • 10 Answers
If you mean that one brush is wearing faster than the other, chances are good that one of your brush springs has become weak allowing one of the brushes to float a bit and to arch. Observe the brushes while running the tool to see if one archs more than the other. If necessary, replace BOTH brush holders (they come with springs).
If you mean that the brushes are wearing unevenly, chances are good that there is very excessive vibration and, or, a high concentration of dust (ie. concrete) passing through the tool. Excessive vibration is usually caused by incorrect, or damaged accessories. It could also be a bent spindle or worn out spindle bearing.
Posted on Sep 29, 2009
How can i replacethe carbon brushes on my angle grinder as they are totally and completely worn off
Buy the new brushes from the manufacturer. You already have the old ones out - put the new ones in the same way you took the old ones out.
Jul 27, 2014 | Makita 9005B 5" Electric Angle Grinder
Sparks are coming from my metabo w6-115 angle grinder where the bushing are and it seems to be grinding a bit
There are always some sparks with power tools from the brushes.
You should remove the brushes for inspection to check wear.
Be sure to reinstall in the same direction.
Jul 16, 2011 | Metabo 06204 4 1/2" 900W Ang Grinder
Once in a while my grinder W7-125 doesn't start, then I'll have to losen the carbon brushes, put them in again, and now and then the grinder starts again and now an then I'll have to repeat...
I would look at the switch action sometimes the rod doesn't want to fully engage the actuator. Also look for debris that might be in the brush area. And lastly look at the brush shunt/spring to ensure there are no restriction to the shunt (wire) that will not allow it to easily move in the brush holder. The brush should slide with no pressure in the holder. Let me know if you need more assistance.
May 08, 2011 | Metabo W7 125 Angle Grinder 5" 9,000 Rpm...
Need to put metabo w14-150 ergo back together
Hello. There are actually a few different grinders (style of) with this product number. Here is the link to the Metabo home site. They have downloads available of parts lists and specifications that should be of assistance to you. Should that fail, use their contact information, and have them supply the required information. If this helps, please rate this answer a four-thumbs up - Thank You.
http://www.metabo.us/
Apr 02, 2011 | Metabo W14 150 ErgoD Angle Grinder
Grinder runs about 2 minutes then shuts off. I replaced the heat sensor- no change. What else could be the problem?
check the condition of the brushes, make sure not sticking in the brush tube and also look at the commutator for a really dirty surface.
Dec 21, 2010 | Metabo 01451 We14 150 Quick Electronic 6...
I had been using this grinder for about 2 weeks with no problems. A few days ago while using it it just popped and hasn't worked since.
These are great grinders. I have two of them. One version (more expensive one) has soft start and good overload system. Other version is basic grinder. if it (popped) most likely a short in the motor. Is it possible you got an unusual amount of grinding dust into the grinder? This grinder has a safety feature on the brushes, that keeps from burning up the armature when the brushes wear out. I doubt you've worn out a set of brushes in 2 weeks, unless you've been using it non stop. At least one of the brushes has a small plastic insulating pin inside the carbon. When the brush wears down enough to expose the plastic pin, the spring loaded pops out, lifting the brush from the armature , which opens the circuit. You could remove the brush holders and inspect the brushes. If it is 2 weeks old it is under warranty, and you should return it where you bought it.
Jul 14, 2010 | Metabo ® 12 Amp 9000 RPM Model WE14150...
Carbon brush sizes
They are exactly the same brushes. Part number 316041640 .
Sep 15, 2009 | Metabo WE14-150 Quick Angle Grinder
Magnetic brush size
Yes and no. From 1999 to early 2008, excluding the slightly beefier "Ergo" models, the size / part number is the same. However, on the newest models there are differences in density between some models. Wire placement is different from the older models.
Sep 13, 2009 | Metabo WE14-150 Quick Angle Grinder
Drill and grinder only work upside down
The only time I have encountered this problem is when the field coil is loose in the motor housing, or one or more of the leads has come loose. By tipping the unit back the coil slides to the rear and makes contact. Then contact breaks when the tool in tipped forward.
Apr 28, 2009 | Metabo 600242420 BHE22 7/8" SDS-plus...
Metabo WE14-150 Quick Angle Grinder Logo
403 people viewed this question
Top Metabo Saws Experts
Vernon Taylor
Spud Howell
JOHN LAPIER
Are you a Metabo Saw Expert? Answer questions, earn points and help others
